SkiBum326
Static IP address of Raspberry pi Zero W
Mon Sep 30, 2019 8:09 am
Hi Everyone,
I am trying to set up a static IP address for my Raspberry Pi Zero. Following instructions online, I added the following to the end of /etc/dhcpcd.conf
interface usb0
static ip_address=192.168.42.42/24
static routers=192.168.42.1
static domain_name_servers=102.168.42.1
After rebooting the pi, I see the following from ifconfig:
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.42.42 netmask 255.255.255.0 broadcast 192.168.42.255
inet6 fe80::8f00:84d:1c7b:fe22 prefixlen 64 scopeid 0x20<link>
ether f6:8b:8a:8c:6e:b5 txqueuelen 1000 (Ethernet)
RX packets 490 bytes 76712 (74.9 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 583 bytes 57833 (56.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
However, when I try to ping this IP address, I just see Request timeout for icmp_seq...
Does anything stand out that I could be doing wrong?
Thanks in advance for the help!
Re: Static IP address of Raspberry pi Zero W
Mon Sep 30, 2019 8:12 am
Hi Everyone,
interface usb0
What is connected to the other end of the USB Cable you use for networking ?
SkiBum326
Mon Sep 30, 2019 4:34 pm
Sorry, I forgot to include that detail.
I'm using a MacBook running Mojave 10.14.6.
Andyroo
Mon Sep 30, 2019 5:46 pm
In networking (system preferences) have you set an IP address on the RNDIS adapter?
I find it best to have a separate network for Ethernet / WiFi on the Mac to that of the USB device.
e.g. 192.168.1.x is the normal house network with 192.168.2.x being the USB network present in dhcpcd.conf and the RNDIS adapter.
You also need to check the default route - it is possible this has gotten a bit mixed up and does not know about the Mac end of the network. Use the
route
to check this on the Pi.
Mon Sep 30, 2019 5:57 pm
So you are running the RPi Zero in "Gadget Mode" ??
