john_alan
Weird issues with apt-get
Sat Sep 21, 2019 10:59 am
Hello
I like to try and keep my Pi boxes up to date and was doing a usual apt-get update/upgrade and I came across this issue:
[email protected]:~ $ sudo apt-get update
[sudo] password for pi:
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Hit:3 https://download.docker.com/linux/raspbian stretch InRelease
Hit:4 https://deb.nodesource.com/node_11.x stretch InRelease
Reading package lists... Done
[email protected]:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  python3-systemd
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  base-files libfaad2
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 219 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://ftp.heanet.ie/mirrors/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u11
  404  Not Found
Err:2 http://ftp.heanet.ie/mirrors/raspbian/raspbian stretch/main armhf libfaad2 armhf 2.8.0~cvs20161113-1+deb9u2
  404  Not Found
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/b/base-files/base-files_9.9+rpi1+deb9u11_armhf.deb  404  Not Found
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/f/faad2/libfaad2_2.8.0~cvs20161113-1+deb9u2_armhf.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
No matter how long I wait, the old reliable HEANET (which is near me in Ireland) keeps giving a 404.
My source was set to:
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
and I changed it to this which seems to work:
deb http://mirror.ox.ac.uk/sites/archive.raspbian.org/archive/raspbian buster main contrib non-free rpi
Is that ok?
A bloke here (https://raspberrypi.stackexchange.com/q ... -respibian) says that might stop me getting RPF additions/modifications?
rpdom
Re: Weird issues with apt-get
Sat Sep 21, 2019 11:38 am
I think it's most likely a timing issue with the servers being updated while you were running the commands.
The versions of software that apt is trying to pull in have been replaced by newer versions, so it can't find them.
Try the apr-get update again, then the upgrade.
The Debian repositorydoesn't suffer from this issue as they have bigger servers and keep all the old copies of the software available instead of just the current versions, but their software isn't compatible with the Pi1 or Zero range.
john_alan
Sat Sep 21, 2019 12:44 pm
Thanks for the reply,
Issue still persists, is there any caveat to changing the mirror as I have done?
Seems to work well, and it's an official mirror, but I am concerned it might cause issues later.
puccaso
Sun Sep 22, 2019 11:21 am
you know, i have the same issue
i cant update my system because it cant locate the files
thought i can ping the http://ftp.heanet.ie address and i get a responce
i thought it was something to do with ip6 so i disabled that but nope,
Err:1 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpgv armhf 2.2.12-1+rpi1+deb10u1
  404  Not Found [IP: 87.44.34.235 80]
Err:2 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gnupg-utils armhf 2.2.12-1+rpi1+deb10u1
Err:3 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpgconf armhf 2.2.12-1+rpi1+deb10u1
Err:4 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpg-agent armhf 2.2.12-1+rpi1+deb10u1
Err:5 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpg armhf 2.2.12-1+rpi1+deb10u1
Err:6 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpg-wks-server armhf 2.2.12-1+rpi1+deb10u1
Err:7 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf dirmngr armhf 2.2.12-1+rpi1+deb10u1
Err:8 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpg-wks-client armhf 2.2.12-1+rpi1+deb10u1
Err:9 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gnupg-l10n all 2.2.12-1+rpi1+deb10u1
Err:10 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gpgsm armhf 2.2.12-1+rpi1+deb10u1
Err:11 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf gnupg all 2.2.12-1+rpi1+deb10u1
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpgv_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gnupg-utils_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpgconf_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpg-agent_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpg_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpg-wks-server_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/dirmngr_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpg-wks-client_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gnupg-l10n_2.2.12-1+rpi1+deb10u1_all.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gpgsm_2.2.12-1+rpi1+deb10u1_armhf.deb  404  Not Found [IP: 87.44.34.235 80]
E: Failed to fetch http://ftp.heanet.ie/mirrors/raspbian/raspbian/pool/main/g/gnupg2/gnupg_2.2.12-1+rpi1+deb10u1_all.deb  404  Not Found [IP: 87.44.34.235 80]
[email protected]:/etc/apt/apt.conf.d#
bastien8060
Sun Sep 22, 2019 2:37 pm
Same here in Ireland (Dublin) since yesterday, i confirm this is not an issue with your installation.
I tried with Raspbian jessie, stretch and buster (with raspberry pi 3b, Zero, and 4b) without any success.
rpdom
Sun Sep 22, 2019 3:39 pm
No, there shouldn't be any problem with changing the mirror - unless that mirror has a problem. Then you won't be able to download anything and won't get redirected to another working mirror.
In the meantime, you have a working connection, so no need to worry :)
lfarrell12
Sun Sep 22, 2019 4:05 pm
It might be an issue with the mirror - I am getting the same from Heanet - I will see if there is a contact there I can raise an issue with
