ke5fuj
Beginner Pi4 GPIO CLI Control
Thu Sep 19, 2019 8:22 pm
Hello Community! I am brand new to the Pi world and wanted to see what these things can do. I have my Pi4 setup running the latest version of Raspbian and can SSH to it and everything. I found a tutorial on Youtube that talks about how to use the CLI to issue simple commands to set and test the GPIO pins to turn on an LED. Well I can't get it to work. So I switched to a multimeter and tried it directly on the pins and still can not see the change of state on the pins using the CLI to issue simple commands like this...
gpio -g mode 18 output
gpio -g blink 18
or
gpio -g write 18 1 (to turn it on)
gpio -g write 18 0 (to turn it off)
Here is what I have done so far....
git clone git://git.drogon.net/wiringPi
This does not work for somer reason... I get this... response
fatal: unable to connect to git.drogon.net:
git.drogon.net[0: 188.246.205.22]: errno=Connection refused
git.drogon.net[1: 2a03:9800:10:7b::2]: errno=Network is unreachable
before anyone asks, yes I can get to the internet with the Pi4 and it is unrestricted access. I'm a network engineer, so I promise its not the network. :)
What I did find was that the "GPIO" commands were already in the OS. So I did this....
gpio -v
gpio version: 2.50
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
Type: Unknown17, Revision: 01, Memory: 0MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 4 Model B Rev 1.1
* This Raspberry Pi supports user-level GPIO access.
From what little I've found about this, the "unknown17" seems to be a problem.
Some more googling and I've tried this....
wget unicorn.drogon.net/wiringpi-2.48-1.deb
And got this....
Resolving unicorn.drogon.net (unicorn.drogon.net)... 46.43.1.171, 2001:41c9:1:41e::171
Connecting to unicorn.drogon.net (unicorn.drogon.net)|46.43.1.171|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 52740 (52K) [application/x-debian-package]
Saving to: ‘wiringpi-2.48-1.deb’
wiringpi-2.48-1.deb 100%[==================================>] 51.50K 193KB/s in 0.3s
2019-09-19 15:01:29 (193 KB/s) - ‘wiringpi-2.48-1.deb’ saved [52740/52740]
So that's about where I'm at for now. I'm just looking to control the outputs from the CLI for now to make sure I am comfortable doing it, and then I will start learning how to use the inputs to monitor one-wire temperature sensors next.
Any help would be greatly appreciated!
neilgl
Re: Beginner Pi4 GPIO CLI Control
Thu Sep 19, 2019 9:37 pm
Ah wiringpi is excellent (thanks Gordon) but he has stopped supporting it (sorry) so this might work for GPIO2:
raspi-GPIO set 2 op on dl
And see this for the various parameters
https://www.raspberrypi.org/documentati ... xt/gpio.md
ke5fuj
Thu Sep 19, 2019 11:59 pm
Thanks for the reply Neilgl. Unfortunately, it does not like the "set" command. Take a look....
[email protected]:/home/pi# gpio -h
gpio: Usage: gpio -v
gpio -h
gpio [-g|-1] ...
gpio [-d] ...
[-x extension:params] [[ -x ...]] ...
gpio [-p] <read/write/wb> ...
gpio <mode/read/write/aread/awritewb/pwm/pwmTone/clock> ...
gpio <toggle/blink> <pin>
gpio readall
gpio unexportall/exports
gpio export/edge/unexport ...
gpio wfi <pin> <mode>
gpio drive <group> <value>
gpio pwm-bal/pwm-ms
gpio pwmr <range>
gpio pwmc <divider>
gpio load spi/i2c
gpio unload spi/i2c
gpio i2cd/i2cdetect
gpio rbx/rbd
gpio wb <value>
gpio usbp high/low
gpio gbr <channel>
gpio gbw <channel> <value>
[email protected]:/home/pi# gpio set 18 op on dl
gpio: Unknown command: set.
UPDATE:
So I just found this posting and these commands make the IO change state and you can monitor the state of the IO. Is this just a different way to do it? Right, wrong, etc?
https://raspberry-projects.com/pi/comma ... mmand-line
Fri Sep 20, 2019 6:50 am
Using the sysfs interface is just another way to do it. The gpio commands can be more friendly though.
neilgl said to use the raspi-gpio command, not the gpio command. If it isn't installed you can get it with sudo apt update && sudo apt install raspi-gpio
However, I believe
should have been
raspi-gpio set 2 op np dl
raspi-gpio help
shows available options.
neilgl
Fri Sep 20, 2019 9:25 am
Yes it should have been raspi-gpio. The iPad auto corrected it...
And a different GPIO number would be better than 2 due to its 1.8k pull-up resistor.
ke5fuj
Fri Sep 20, 2019 1:40 pm
Thanks guys!
I did say I was a beginner.... :lol:
I thought the raspi in raspi-gpio was part of the command line label on his machine. Like "[email protected]:~#" Doh! ;)
So I found that this worked.
raspi-gpio set 24 op pn dl
raspi-gpio set 24 op pn dh
Now I just have to figure out how to write python and control it from a web page and with automation.... This is going to be a fun process for sure...
