dizzo
Error messages when running apt-get update
Wed Sep 18, 2019 6:46 pm
Can anyone give me a hand with the following. I've found a couple of threads with similar but not identical problems and their solutions haven't worked. When running sudo apt-get update I get the following error messages:
Last login: Wed Sep 18 14:22:12 2019 from 174.205.9.217
Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.
Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.2 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Ign:3 https://downloads.plex.tv/repo/deb public InRelease
Get:4 https://downloads.plex.tv/repo/deb public Release [5,815 B]
Get:5 https://downloads.plex.tv/repo/deb public Release.gpg [821 B]
Hit:6 http://linux.teamviewer.com/deb stable InRelease
Get:7 http://archive.raspberrypi.org/debian buster/main armhf Packages [229 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Get:9 https://downloads.plex.tv/repo/deb public/main armhf Packages [1,192 B]
Fetched 13.3 MB in 27s (495 kB/s)
Reading package lists... Done
W: Skipping acquire of configured file 'staging/binary-armhf/Packages' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'staging/i18n/Translation-en' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'staging/i18n/Translation-en_US' as repository 'http://archive.raspberrypi.org/debian buster InRelease' doesn't have the component 'staging' (component misspelt in sources.list?)
I've looked in sources.list and raspi.list but can't find any clues as to what's throwing the error messages.
Re: Error messages when running apt-get update
Wed Sep 18, 2019 7:43 pm
Neither Plex or TeamViewer are by default available from the Raspbian Buster repositories. Have you been installing software without checking compatibility ?
On a virgin install of Raspbian Buster all that is needed:
sudo apt update
sudo apt full-upgrade
sudo reboot
RPi 4B 4GB (SSD Boot)..
