satadru
RPi4 Ethernet LED control
Wed Sep 18, 2019 1:48 pm
Is there any way to disable the Ethernet LEDs on the RPi4?
I see various methods using dtparam or a 3rd party tool as suggested here:
https://github.com/ccrisan/motioneyeos/ ... n-Off-LEDs
# Disable the Ethernet LEDs.
dtparam=eth_led0=14
dtparam=eth_led1=14
For other Raspberry Pi models, add this command to your /data/etc/userinit.sh:
lan951x-led-ctl --fdx=0 --lnk=0 --spd=0
But this doesn't work for the VL805, right?
trejan
Re: RPi4 Ethernet LED control
Wed Sep 18, 2019 2:17 pm
The VL805 chip is only a USB controller. Ethernet is separate on the Pi 4 with the MAC inside the SoC and an external PHY. The external PHY doesn't have any public documentation so AFAIK there is no way of turning off the LEDs yet.
The config.txt option and the utility are for the 3B+ and older model B Pi boards respectively. They don't work on the 4.
satadru
Thu Sep 19, 2019 11:15 pm
FYI, the PHY appears to be a BCM54213PE, mentioned here: https://github.com/rsta2/circle
The LEDs appear to be mentioned here: https://github.com/raspberrypi/linux/co ... a8575ee06b
Kendek
Mon Sep 23, 2019 3:11 pm
FYI, the PHY appears to be a BCM54213PE...
Thanks, I successfully disabled the ethernet LEDs in the drivers/net/phy/broadcom.c with BCM_LED_SRC_OFF:
static void bcm54213pe_config_init(struct phy_device *phydev)
	val = BCM5482_SHD_LEDS1_LED1(BCM_LED_SRC_OFF) |
		BCM5482_SHD_LEDS1_LED3(BCM_LED_SRC_OFF);
ahori0
Thu Jan 23, 2020 2:37 am
Hi may I asked how you did this?
Just pull their repo, make the change, and recompile?
Kendek
Thu Jan 23, 2020 5:07 am
This feature has been implemented:
dtparam=eth_led0=4
dtparam=eth_led1=4
Return to “Device Tree”
