I work a lot with the PI3 B+ and serial communication on it's full featured PL011 UART.
I use the 'dtoverlay=pi3-disable-bt' in /boot/config.txt to get this uart back on pin14/15 of the 40-pin header.
(Don't use bluetooth at all)
When i start omxplayer -o alsa <link of mp4> the audio is played well on the analog output mini-jack.
Now i am working with the new PI4 and also perform the above adjustments, but if i start omxplayer the analog audio is distorted/crackled.
When i comment/hide the 'dtoverlay=pi3-disable-bt' in /boot/config.txt (# dtoverlay=pi3-disable-bt } and reboot the Pi, the audio with omxplayer
on the analog output jack is okay.
I cannot figure out what the swapping of the uart's has to do with the analog audio output.
Does anyone have a suggestion on this?
Thanks in advance, erik
