What you'll need
- 64-bit ARM OS I recommend Saki's Gentoo implementation. I can't guarantee this works on any other OS as they may not have the latest audio and video driver fixes.
- A Pi 4 and the necessary hardware/software to run it
How you'll do it
1. Install the 64 bit OS
2. Install openmw
a. If using gentoo just do sudo emerge openmw
b. If not using gentoo check for a prebuilt package
c. If no package is available you can build from source
3. Run the openmw installer (this needs the original game files it can read it straight from the disk if you have one)
4. Launch openmw with this command
OPENMW_DECOMPRESS_TEXTURES=1 openmwIf you're getting audio issues or crashing on loading new areas you'll need to do an update for the pi drivers/software. I'm running the game at 720p and I get 30fps outdoors with medium view distance and water effects off. 60fps indoors.
