nielsgeode
Install Oracle Java on RPi 4
Mon Sep 16, 2019 7:49 am
My RPi 4 has Raspbian Buster installed and I want to run a java program called Simple Stackshot Controller. When I have OpenJDK installed and run it in verbose method I get a ton of output. The problem could be that it requires Oracle Java and not Open Java. I have googled on how to install it, but did not have any success yet.
How do I install Oracle Java on my RPi 4? I'm a complete beginner with linux.
markkuk
Re: Install Oracle Java on RPi 4
Mon Sep 16, 2019 10:24 am
"Verbose" means that you are supposed to get a ton of output. All the messages are tagged "info", so there isn't any problem that needs fixing.
neilgl
Mon Sep 16, 2019 11:12 am
Have a look at this post for Oracle java:
https://www.raspberrypi.org/forums/view ... 1&t=231460
