AiyaPK
gpio button works on pi3 but not pi4... but LEDs on pi4 works?.....
Sun Sep 15, 2019 6:45 pm
trying to get this stupid simple circuit to output the readings I'm expecting.....
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
buttonA=23
buttonB=24
GPIO.setup(buttonA,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.setup(buttonB,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
print (GPIO.input(buttonA))
print (GPIO.input(buttonB))
so when I run the code, both print statements give me 0
So my understanding is that setting up the button for GPIO23 wired to ground, I should be using PUD_UP to pull the voltage up to 3.3V. so by default I should get a reading of 1 when the button isn't pressed, and a reading of 0 when the button IS pressed.
Alternatively, GPIO24 wired to the 3.3v should be using PUD_DOWN, and give me a reading of 0 by default, and a reading of 1 when I press the button?...
So I would expect the reading from GPIO24 to be 0.... but how come I don't see 1 for the first print statement?
Just to go further, I actually had if statements coded out after that actually printed the status of the button, those didn't do anything and I'd constantly get a reading of 0 regardless.
Leading me to wonder if my gpio is even working for buttons. I say buttons specifically because I hooked up LED's to these and they seem to work fine.
asavah
Re: can't get super simple gpio button tutorial to work
Sun Sep 15, 2019 7:01 pm
I don't think you need resistors for push buttons.
Sun Sep 15, 2019 7:09 pm
Try this:
buttonA=23
buttonB=24
while True:
Having the resistors is OK, that protects things if the GPIO is set as output and the button gets pressed.
This is a doctor free zone.
neilgl
Sun Sep 15, 2019 7:39 pm
It looks like your wiring is dodgy (or switches the wrong way round) as if you run your code without anything attached to any GPIO pin, you get:
python simple.py
1
0
I am running that from a terminal, no IDLE, no THONNY, no GEANY
And @Dougie's idea is a good one to have a while loop looking at the buttons forever (maybe add a short delay in that loop ).
pcmanbob
Sun Sep 15, 2019 7:56 pm
If you are using the small push button switches as shown, the legs on them are often to short to make a good contact with the breadboard terminals.
Try testing your code using a short Dupont cable in place of the switch.
AiyaPK
Sun Sep 15, 2019 10:33 pm
@dougie
Yes I should probably do a while True loop just for ease of reading. I figured without the loop I should've at least expected the correct response at least once. But I totally should use the loop anyway.
@neilgl
Could you clarify on the 'dodgy' aspect? I have zero experience with circuits and never took it in school (these days I really wish I did though. I'm also curious about the push buttons and how they might be placed wrong. I was under the impression that there's no particular orientation other than making sure the claws point up/down along the rows and that pressing the button connects all 4 legs together.
@pcmanbob
Ooooooo I always wondered about these small push buttons when used with breadboards... so in my circuit I guess I could in theory just short it with wires instead of buttons, thus emulating a 'button down' scenario just to see if I get the correct readings.... I will def try that!
drgeoff
Sun Sep 15, 2019 10:56 pm
You are under the wrong impression.
Most of those switches have the 2 legs on one side connected together and the other two legs connected together. Pressing the button joins the two pairs together. When you don't know the correct orientation just use either of the two pairs of diagonally opposite legs and leave the other two diagonal legs not connected to anything.
Get yourself a multimeter. Even the $5 (or less) ones are adequate for testing and troubleshooting RPi circuits. Use a resistance range to identify the switch connections.
Or use a LED and series resistor plus the 3.3 volts from the RPi as a continuity tester.
As hinted above the short length of the legs and the distance that the conducting strips are below the surface of the breadboard can hinder getting a connection between them.
neilgl
Mon Sep 16, 2019 11:08 am
Yes what @drgeoff said about the small pushbuttons. And did it give 1,0 with nothing connected (yes)?
For "dodgy" (i.e. not working well) wiring, it could be poor (i.e. loose or damaged) connections inside the breadboard, or a connector on the dupont cable may be loose, or the conductor inside the insulated wire may be broken (that one got me some time ago - it looks ok but it isnt.)
AiyaPK
Re: gpio button works on pi3 but not pi4... but LEDs on pi4 works?.....
Mon Sep 16, 2019 2:54 pm
ok so I went back and tested my buttons and wiring with the multimeter.
Continuity is there where I would expect it and the button seems to function normally.
So the twist is that my code and the buttons seem to work fine on my pi3B+....
but on the pi4 (which is what I've been using initially for these tests), the buttons don't work...
However, the LED's on those same GPIO pins on my pi4 work fine
I think at this point I've tried the buttons on at least 3-4 different GPIO pins, and it doesn't work. It's almost as if there's either something wrong with my pull_up_down coding, or my pi4 just isn't setup to work with buttons somehow?.......
(I have changed the subject of this thread to better reflect the problem)
neilgl
Mon Sep 16, 2019 3:27 pm
Ah, what does your code (simple.py) give on the pi3 with nothing attached and the pi4 with nothing attached? Start a terminal and run the script (no Thonny/IDLE...)
on my pi4 I get
python simple.py
1
0
on my pi3B+ I get
python simple.py
1
0
AiyaPK
Mon Sep 16, 2019 5:53 pm
I got it!!!!
I have everything working now.
I came across this thread while looking into pi4 specific problems with the gpio:
https://www.raspberrypi.org/forums/view ... p?t=244375
All this time I had thought it was my bad wiring and so I didn't realize this was a pi4 specific issue that needed an update.
I ran:
$ pip3 install --upgrade --pre rpi.gpio
and everything works as normal now!!
Thanks everyone for the help!!
neilgl
Mon Sep 16, 2019 6:38 pm
Ah, I had foolishly assumed you had done an update / upgrade on the pi4.
pcmanbob
Mon Sep 16, 2019 6:47 pm
I ran:
If this fixed your problem then it suggests you have never run an update on buster since flashing you SD card.
There have been a lot of updates for buster and the pi 4 , so I would suggest you do an update of the OS .
sudo apt update
sudo apt full-upgrade
AiyaPK
Mon Sep 16, 2019 8:09 pm
I too thought I had run it before since on that thread it mentioned that sudo apt update/upgrade should cover that...
I had run this multiple times for my pi3
I had only recently acquired this pi4 but in my excitement completely forgot to update and dove right into gpio tutorials haha
my bad my bad... thus earning me the beginners tag ;)
neilgl
Mon Sep 16, 2019 8:37 pm
Ok no problem.
