vedeja
How to install pyaudio
Sun Dec 09, 2012 8:49 pm
Can someone please bother to describe how pyaudio is installed on the Pi?
ZacharyI123
Re: How to install pyaudio
Tue Dec 11, 2012 7:26 pm
sudo apt-get install git
git clone http://people.csail.mit.edu/hubert/git/pyaudio.git
Don't be mean, I'm only thirteen 8-)
vedeja
Wed Dec 12, 2012 10:20 pm
For the record, here's what I did:
$ sudo apt-get install git
$ git clone http://people.csail.mit.edu/hubert/git/pyaudio.git
$ sudo apt-get install libportaudio0 libportaudio2 libportaudiocpp0 portaudio19-dev
$ sudo apt-get python-dev
$ sudo python pyaudio/setup.py install
SpaceGerbil
Fri Mar 15, 2013 12:17 am
Many thanks. I wanted this on my laptop as well and had to make a few changes.
In root:
$ sudo git clone http://people.csail.mit.edu/hubert/git/pyaudio.git
$ sudo apt-get install python-dev
$ cd pyaudio
$ sudo python setup.py install
simple-simon
Mon Jul 01, 2013 12:05 pm
I have been hacking around and stress that I am no expert being new to Linux and Pi. I found this...
sudo apt-get install python-pyaudio
It seems to install everything required
bohemier
Wed Oct 09, 2013 8:38 pm
Thanks...
works like a charm
jim.b
Sun Nov 16, 2014 11:26 pm
This only appears to setup pyaudio for python2.x. I've tried a few things to get it to work with python3 on my brand new pi and wolfson. Any ideas what I might be missing? I tried: "sudo python3 setup.py install" but still cannot "import pyaudio" in the python3 interpreter. I'm using python 3.2.3. thanks!
DirkS
Mon Nov 17, 2014 12:29 pm
For python 3
needs to be changed to
sudo apt-get install python3-dev
http://www.raspberrypi.org/forums/viewt ... 32&t=54658 suggests that it can work with python 3
Gr.
Dirk.
smrtsmrf
Sat Jun 13, 2015 5:56 pm
I've tried these methods, and PyAudio seems to install fine, but then when I try to run the example on the PyAudio documentation site (on my Pi 2), I get slow/choppy/garbled audio which eventually stops. Playing audio with aplay from the command line works just fine, so it must be something with PyAudio.
Does anyone have any help they can offer? I've scoured the web, but can't find any solutions.
Thanks in advance.
zgt
Tue Jun 23, 2015 7:57 pm
I'm exactly with the same problem, smrtsmrf.
I am using the B+, Python 2.7.3, PyAudio (0.2.8 and 0.2.4) and I also get slow/choppy/garbled audio...
When I play the sound with pygame it works pretty good though. So it should be something with PyAudio...
Did you find what was causing that?
jonwitts
Raspberry Pi Certified Educator
Sat Mar 12, 2016 2:06 pm
jim.b wrote:This only appears to setup pyaudio for python2.x. I've tried a few things to get it to work with python3 on my brand new pi and wolfson. Any ideas what I might be missing? I tried: "sudo python3 setup.py install" but still cannot "import pyaudio" in the python3 interpreter. I'm using python 3.2.3. thanks!
To install pyAudio for Python 3 try:
sudo apt-get install python3-pyaudio
Just hacking around with it now...
jonwitts
Sat Mar 12, 2016 3:14 pm
The following code allows me to record from my USB microphone. It does output a lot of errors first, but it works!
#!/usr/bin/env python3
import pyaudio
import wave
CHUNK = 512
FORMAT = pyaudio.paInt16 #paInt8
CHANNELS = 1
RATE = 44100 #sample rate
RECORD_SECONDS = 5
WAVE_OUTPUT_FILENAME = "pyaudio-output.wav"
p = pyaudio.PyAudio()
stream = p.open(format=FORMAT,
                channels=CHANNELS,
                rate=RATE,
                input=True,
                frames_per_buffer=CHUNK) #buffer
print("* recording")
frames = []
for i in range(0, int(RATE / CHUNK * RECORD_SECONDS)):
    data = stream.read(CHUNK)
    frames.append(data) # 2 bytes(16 bits) per channel
print("* done recording")
stream.stop_stream()
stream.close()
p.terminate()
wf = wave.open(WAVE_OUTPUT_FILENAME, 'wb')
wf.setnchannels(CHANNELS)
wf.setsampwidth(p.get_sample_size(FORMAT))
wf.setframerate(RATE)
wf.writeframes(b''.join(frames))
wf.close()
kevstev01
Mon Dec 04, 2017 10:20 am
Here's what I did for raspian Jessie (see also https://stackoverflow.com/a/21014700/2088280)
1) sudo apt-get install python-dev
2) sudo apt-get install portaudio19-dev
3) sudo pip install pyaudio
Return to “Python”
Who is online
Users browsing this forum: No registered users and 2 guests
