Tested:
(with Ethernet and power connected - no other connected devices, bluetooth is on, but no connected devices)
- Z-stick in all four USB ports - same result = not detected *
- Z-stick on other laptops - working
- Connected some other USB device (a Corsair Flash Voyager USB memory stick - really super old) - this was detected and working
From the above I made the conclusion that most likely there is not enough power to drive the Z-stick. Hence I used a standard multimeter to measure voltages with/without USB stick inserted. I've tested between TP1/2/3 and TP 7/8 - all show up as 5.19V regardless if Z-stick is inserted or not. From this I think that the power in is sufficient for the pi, do you agree?
I've also looked at results from vcgencmd measure_volts:
- core: volt=0.8666V
- sdram_c: volt=1.1000V
- sdram_i: volt=1.1000V
- sdram_p: volt=1.1000V
Using vcgencmd the core temperature is 53.0C.
Setup
I'm on a fresh out of the box Raspberry Pi 4 /4G and downloaded/flashed recent build of raspian from there to a 128GB SanDisk Extreme A2/160MB/90MB microSD card.
I've downloaded and built Open z-wave and tried with both downloaded version of domoticz and a version where I built the same. During this I noted a discepancy of time between how much time the build would take me towards the tutorial/guide suggested. That is - when the guide I followed said "this build would take quite some time - 20 minutes on my setup" (etc).... This would take significantly longer on my setup (not clocked - but say around x2-x3).
Let me know if any relevant information is missing. Is it a faulty board? A bad setup? What? I'm out of ideas on how to proceed. My next alternative would probably be to take another new pi4 board and test the z-stick on that. (possibly test on another knowingly working pi4 board.) I do however not have access to any other pies.
output of uname -v: #1253 SMP Thu Aug 15 12:02:08 BST 2019
output of lsusb (adding -v version further down):
- Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
- Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
- Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
- Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idProduct 0x0003 3.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
bcdDevice 4.20
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.66-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 12:02:08 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:20:07:C2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=4253612b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwdata, 2348K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 662 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28118 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000017] Switching to timer-based delay loop, resolution 18ns
[ 0.000236] Console: colour dummy device 80x30
[ 0.000260] console [tty1] enabled
[ 0.000301] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000323] pid_max: default: 32768 minimum: 301
[ 0.000585] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000603] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001345] CPU: Testing write buffer coherency: ok
[ 0.001748] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002387] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002543] rcu: Hierarchical SRCU implementation.
[ 0.003403] smp: Bringing up secondary CPUs ...
[ 0.004202] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005128] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006014] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006146] smp: Brought up 1 node, 4 CPUs
[ 0.006159] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006168] CPU: All CPU(s) started in HYP mode.
[ 0.006177] CPU: Virtualization extensions available.
[ 0.006952] devtmpfs: initialized
[ 0.017256] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017477] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.024769] pinctrl core: initialized pinctrl subsystem
[ 0.025608] NET: Registered protocol family 16
[ 0.028546] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030051] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030062] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030253] Serial: AMBA PL011 UART driver
[ 0.033294] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.068982] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071421] vgaarb: loaded
[ 0.071781] SCSI subsystem initialized
[ 0.071975] usbcore: registered new interface driver usbfs
[ 0.072026] usbcore: registered new interface driver hub
[ 0.072122] usbcore: registered new device driver usb
[ 0.090391] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:03, variant start
[ 0.100124] raspberrypi-firmware soc:firmware: Firmware hash is 9f8431fb7839c7f00f52b81f5822ddab2b31d0db
[ 0.111644] clocksource: Switched to clocksource arch_sys_counter
[ 0.189170] VFS: Disk quotas dquot_6.6.0
[ 0.189245] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.189394] FS-Cache: Loaded
[ 0.189576] CacheFiles: Loaded
[ 0.190077] simple-framebuffer: probe of 0.framebuffer failed with error -12
[ 0.198882] NET: Registered protocol family 2
[ 0.199524] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.199550] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.199620] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.199691] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.199808] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.199836] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.200131] NET: Registered protocol family 1
[ 0.200658] RPC: Registered named UNIX socket transport module.
[ 0.200668] RPC: Registered udp transport module.
[ 0.200677] RPC: Registered tcp transport module.
[ 0.200686] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.200701] PCI: CLS 0 bytes, default 64
[ 0.203796] Initialise system trusted keyrings
[ 0.203971] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.212884] FS-Cache: Netfs 'nfs' registered for caching
[ 0.213368] NFS: Registering the id_resolver key type
[ 0.213391] Key type id_resolver registered
[ 0.213400] Key type id_legacy registered
[ 0.213419] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.215619] Key type asymmetric registered
[ 0.215629] Asymmetric key parser 'x509' registered
[ 0.215739] bounce: pool size: 64 pages
[ 0.215784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.215934] io scheduler noop registered
[ 0.215945] io scheduler deadline registered (default)
[ 0.216102] io scheduler cfq registered
[ 0.216113] io scheduler mq-deadline registered (default)
[ 0.216123] io scheduler kyber registered
[ 0.244812] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.244830] brcm-pcie fd500000.pcie: could not get clock
[ 0.244889] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.244926] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.311677] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.311943] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.311958] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.311975] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.312017] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.312156] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.314877] PCI: bus0: Fast back to back transfers disabled
[ 0.314894] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.315051] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.315111] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.315279] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.317910] PCI: bus1: Fast back to back transfers disabled
[ 0.317926] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.317971] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.317991] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.318020] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.318038] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.318242] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.318423] pcieport 0000:00:00.0: Signaling PME with IRQ 55
[ 0.318580] pcieport 0000:00:00.0: AER enabled with IRQ 55
[ 0.318717] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.321911] iproc-rng200 fe104000.rng: hwrng registered
[ 0.322125] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.322619] vc-sm: Videocore shared memory driver
[ 0.323017] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.332965] brd: module loaded
[ 0.342528] loop: module loaded
[ 0.343247] Loading iSCSI transport class v2.0-870.
[ 0.344893] libphy: Fixed MDIO Bus: probed
[ 0.345300] bcmgenet fd580000.genet: failed to get enet clock
[ 0.345315] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.345332] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.345348] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.345370] bcmgenet: Skipping UMAC reset
[ 0.345598] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.371674] libphy: bcmgenet MII bus: probed
[ 0.412173] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.413057] usbcore: registered new interface driver r8152
[ 0.413119] usbcore: registered new interface driver lan78xx
[ 0.413171] usbcore: registered new interface driver smsc95xx
[ 0.413366] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.413396] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.415462] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.415627] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 56
[ 0.416239] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.416253] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.416265] usb usb1: Product: xHCI Host Controller
[ 0.416276] usb usb1: Manufacturer: Linux 4.19.66-v7l+ xhci-hcd
[ 0.416287] usb usb1: SerialNumber: 0000:01:00.0
[ 0.416796] hub 1-0:1.0: USB hub found
[ 0.416853] hub 1-0:1.0: 1 port detected
[ 0.417260] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.417282] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.417301] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.417635] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.417649] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.417660] usb usb2: Product: xHCI Host Controller
[ 0.417671] usb usb2: Manufacturer: Linux 4.19.66-v7l+ xhci-hcd
[ 0.417681] usb usb2: SerialNumber: 0000:01:00.0
[ 0.418164] hub 2-0:1.0: USB hub found
[ 0.418215] hub 2-0:1.0: 4 ports detected
[ 0.419295] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.444855] dwc_otg fe980000.usb: base=(ptrval)
[ 0.645186] Core Release: 2.80a
[ 0.645199] Setting default values for core params
[ 0.645226] Finished setting default values for core params
[ 0.845545] Using Buffer DMA mode
[ 0.845555] Periodic Transfer Interrupt Enhancement - disabled
[ 0.845564] Multiprocessor Interrupt Enhancement - disabled
[ 0.845575] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.845632] Dedicated Tx FIFOs mode
[ 0.846227] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34000 dma = 0x00000000ded34000 len=9024
[ 0.846250] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.846262] dwc_otg: Microframe scheduler enabled
[ 0.846325] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.846341] WARN::hcd_init_fiq:458: FIQ ASM at c07b5a8c length 36
[ 0.846358] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ 0.846402] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.846430] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.846462] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[ 0.846512] Init: Port Power? op_state=1
[ 0.846522] Init: Power Port (0)
[ 0.846777] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.846791] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.846802] usb usb3: Product: DWC OTG Controller
[ 0.846813] usb usb3: Manufacturer: Linux 4.19.66-v7l+ dwc_otg_hcd
[ 0.846823] usb usb3: SerialNumber: fe980000.usb
[ 0.847334] hub 3-0:1.0: USB hub found
[ 0.847383] hub 3-0:1.0: 1 port detected
[ 0.847951] dwc_otg: FIQ enabled
[ 0.847961] dwc_otg: NAK holdoff enabled
[ 0.847969] dwc_otg: FIQ split-transaction FSM enabled
[ 0.847982] Module dwc_common_port init
[ 0.848187] usbcore: registered new interface driver uas
[ 0.848296] usbcore: registered new interface driver usb-storage
[ 0.848461] mousedev: PS/2 mouse device common for all mice
[ 0.849613] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.849796] bcm2835-cpufreq: min=600000 max=1500000
[ 0.850386] sdhci: Secure Digital Host Controller Interface driver
[ 0.850395] sdhci: Copyright(c) Pierre Ossman
[ 0.850779] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.851152] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.854180] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.854319] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.854439] usbcore: registered new interface driver usbhid
[ 0.854448] usbhid: USB HID core driver
[ 0.855191] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.856738] [vc_sm_connected_init]: start
[ 0.864703] [vc_sm_connected_init]: end - returning 0
[ 0.865766] Initializing XFRM netlink socket
[ 0.865793] NET: Registered protocol family 17
[ 0.865875] Key type dns_resolver registered
[ 0.866272] Registering SWP/SWPB emulation handler
[ 0.866849] registered taskstats version 1
[ 0.866864] Loading compiled-in X.509 certificates
[ 0.874606] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.874670] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.877583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.878088] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.878685] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.878696] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.904756] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.924988] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.926595] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.928203] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.931082] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.932692] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.940913] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.943314] of_cfs_init
[ 0.943393] of_cfs_init: OK
[ 0.943970] Waiting for root device PARTUUID=4253612b-02...
[ 0.988348] random: fast init done
[ 0.991735] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.999602] mmc1: new high speed SDIO card at address 0001
[ 1.049599] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.050699] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 1.052056] mmcblk0: p1 p2
[ 1.077472] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.077512] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.078300] devtmpfs: mounted
[ 1.084683] Freeing unused kernel memory: 2048K
[ 1.111957] Run /sbin/init as init process
[ 1.173641] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.173655] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.173668] usb 1-1: Product: USB2.0 Hub
[ 1.175517] hub 1-1:1.0: USB hub found
[ 1.175758] hub 1-1:1.0: 4 ports detected
[ 1.537010] systemd[1]: System time before build time, advancing clock.
[ 1.624385] NET: Registered protocol family 10
[ 1.625584] Segment Routing with IPv6
[ 1.660919] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.661579] systemd[1]: Detected architecture arm.
[ 1.669355] systemd[1]: Set hostname to <raspberrypi>.
[ 1.674903] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.968518] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.968539] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.339072] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.347825] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.353093] systemd[1]: Created slice system-getty.slice.
[ 2.353341] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.354558] systemd[1]: Created slice User and Session Slice.
[ 2.374606] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.375334] systemd[1]: Listening on udev Control Socket.
[ 2.487671] i2c /dev entries driver
[ 3.074233] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.170946] systemd-journald[113]: Received request to flush runtime journal from PID 1
[ 3.688611] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 3.689813] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 3.690372] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 3.690852] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 3.729769] media: Linux media interface: v0.10
[ 3.771106] videodev: Linux video capture interface: v2.00
[ 3.796881] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.797709] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.798916] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.798931] [vc_sm_connected_init]: start
[ 3.803063] [vc_sm_connected_init]: installed successfully
[ 3.805516] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.820836] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.829778] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.844897] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 3.844911] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 3.852864] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 3.852879] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 3.860357] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 3.860370] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 3.874301] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.894838] bcm2835_audio soc:audio: card created with 8 channels
[ 4.143586] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.226570] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.258923] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.426079] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 4.426176] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.428316] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.428329] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.428338] [drm] No driver support for vblank timestamp query.
[ 4.428347] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.430144] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.442218] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.442851] usbcore: registered new interface driver brcmfmac
[ 4.660659] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.674464] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.308307] uart-pl011 fe201000.serial: no DMA platform data
[ 6.385677] random: crng init done
[ 6.385692] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.431057] 8021q: 802.1Q VLAN Support v1.8
[ 6.700387] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.755962] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.755971] brcmfmac: power management disabled
[ 7.026872] bcmgenet: Skipping UMAC reset
[ 7.122333] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.122468] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.151759] bcmgenet fd580000.genet eth0: Link is Down
[ 12.311805] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.311830] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.906633] Bluetooth: Core ver 2.22
[ 12.906680] NET: Registered protocol family 31
[ 12.906684] Bluetooth: HCI device and connection manager initialized
[ 12.907595] Bluetooth: HCI socket layer initialized
[ 12.907614] Bluetooth: L2CAP socket layer initialized
[ 12.907643] Bluetooth: SCO socket layer initialized
[ 12.915833] Bluetooth: HCI UART driver ver 2.3
[ 12.915841] Bluetooth: HCI UART protocol H4 registered
[ 12.915879] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 12.915990] Bluetooth: HCI UART protocol Broadcom registered
[ 13.110610] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.110617] Bluetooth: BNEP filters: protocol multicast
[ 13.110629] Bluetooth: BNEP socket layer initialized
[ 13.140913] Bluetooth: RFCOMM TTY layer initialized
[ 13.140925] Bluetooth: RFCOMM socket layer initialized
[ 13.140940] Bluetooth: RFCOMM ver 1.11
