pygmalion
Poor WiFi signal with Raspeberry Zero W
Sat Sep 14, 2019 8:05 am
I have recently bought Rasberry Zero W. Since I wanted to get original top quality item I bought it at PiHut.
Nevertheless, I still have problems with the unit; as it has incredibly poor WiFi signal. When about 2 m from the AP (one wall in between), signal is only -72dBm to -82dBm depending on the unit orientation, as checked by iwconfig command.
I have tried two different SDcards, two different power supplies, without significant change. I also put my Raspberry Pi 3 on the same spot and I got signal -56dBm (I haven't tried different orientations, just for comparison).
Is such small signal normal for Raspberry Zero W? Should I perhaps asked for a replacement?
graphicw
Re: Poor WiFi signal with Raspeberry Zero W
Sat Sep 14, 2019 8:12 am
Is the Zero W in any kind of case? Metallic cases may interfere with wireless.
pygmalion
Sat Sep 14, 2019 8:15 am
No metallic or any other case, of course. I am well familiar with the concept of Faraday cage.
neilgl
Sat Sep 14, 2019 11:41 am
What does the signal level look like if you measure it on your smartphone e.g. using the free WifI Analyzer for Android, with the phone near the pi? On mine I get -33dBm on the phone, -37dBm on the pi and both are 2m from the router, no walls between.
pygmalion
Sat Sep 14, 2019 11:57 am
With smartphone Galaxy S10e I get around -45dB
So to summarize:
- smartphone -45dB
- Raspberry Pi 3: -55dB
- Raspberry Pi Zero W: -75dB
