johnrxx99
Power supply on/off switch
Sat Sep 14, 2019 5:57 am
Hi, I have a RPi3b+ and a new RPi4b. I have the following problem on both but mainly the 4b. The problem/issue is the lightening bolt voltage warming appearing a lot on the 4b, sometimes on the 3b.
I've read this is caused by non-official power supplies. I have bought 2 non-officials because they have an on/off switch but the cable is of course cheap and I assume that is causing this issue. I like to turn my Raspberries off after use as I didn't want to damage the input socket by over removal and insertion.
My question: before I splash out on 2 official supplies, why don't they have an on/off switch?
Cheers.
raspianhacks
Re: Power supply on/ switch
Sat Sep 14, 2019 6:25 am
Hello
You can simply buy a plug-in strip with a switch on/ switch off. :idea:
Lg
johnrxx99
Re: Power supply on/off switch
Sat Sep 14, 2019 7:05 am
I'm in the Philippines, what is a plug in strip?
LTolledo
Sat Sep 14, 2019 9:41 am
this...
switched sockets.jpg (14.2 KiB) Viewed 86 times
Some people be like:
Sat Sep 14, 2019 9:47 am
Cheers.
The reason no on / off switch is included is because if a clean shutdown is not undertaken it can and does corrupt the Operating System.
adieu
johnrxx99
Sat Sep 14, 2019 10:04 am
Ah, OK, idiot proofing. Understand.
johnrxx99
Sat Sep 14, 2019 10:05 am
Also, got the switchable power rack.
Many thanks all.
Return to “Beginners”
