flyingsubs
Re: [Guide] Kodi on Raspbian Buster
Fri Feb 28, 2020 8:45 pm
Ah okay cool. Thanks for the response. I'm assuming I'll have to wait for an update on the skin helper. I don't see any issues other that there are error warnings every time I start Kodi
Paul.D
Wed Mar 11, 2020 3:01 pm
JOHN009 wrote:
Fri Nov 01, 2019 9:17 am
i was facing error of Ares Wizard error i searched on google and found a article and now problem is solved i hope it will help others too
how you found this useful
flyingsubs
Tue Mar 17, 2020 8:37 pm
Anyone having issues with video? Live tv seems to be choppy and recorded TV is also having issues. Not sure If i touched a setting at all. Not sure if this is the right place to post logs about it?
Is this the best place to post about issues?
Thanks!
-Flyingsubs
Rascas
Wed Mar 18, 2020 12:00 am
Thanks!
-Flyingsubs
Does turn on/off "Adjust display refresh rate" and "Sync playback to display" fix it? Default are both disabled.
If it doesn't I recommend that you try Kodi with clean/default settings. Close Kodi, move/remove ~/.kodi and start Kodi again.
flyingsubs
Wed Mar 18, 2020 12:16 am
Thank for the response! That setting is already turned off. I can start again, would you want to see the log in case there is something that can be fixed? Or are you thinking this is related to the skin helper service?
The other issue which I believe is related is the audio cut out and changes. I have surround sound and then all I can hear is the background noise.
Thanks,
Flyingsubs
Rascas
Wed Mar 18, 2020 12:26 am
Thanks,
Flyingsubs
Start fresh like explained above a see if the problem still exists, if so, post your kodi debug log.
flyingsubs
Wed Mar 18, 2020 1:01 am
Thanks will do. Can I still use the skin mod or does it have to be clean kodi no addons?
Rascas
Wed Mar 18, 2020 1:05 am
Clean, default skin. If the problem is the skin I can't do anything, you have to post your problem in Kodi forum, sub topic of that skin.
flyingsubs
Wed Mar 18, 2020 10:50 pm
Thank you! I think I may have figured it out? I did a test going to Youtube and got no sound. DId a sound test and that didn't work either. I read some forums and went to the config.txt and uncommented out hdmi_force_hotplug=1 rebooted and so far not having an issue. Also I uncommented HDMI_drive=2
Thanks,
Flyingsubs
Rascas
Mon Mar 23, 2020 1:34 am
Kodi updated to 18.6
No specific Raspbian changes.
Just update and upgrade the packages has you normally do.*
*Note that this packages are not yet available on Raspberry Pi repos, only on the PiPplware repo, you have to wait a little bit.
aitlamsali
Tue Mar 24, 2020 12:33 am
Hi All;
I have installed Kodi on Raspbian 10 (buster), but when I want to install the PVR Iptv, I search on addons and the list is empty !!
So I can't find and select then install, please tell me what's the problem exactly ?
Thanks !
Rascas
Tue Mar 24, 2020 9:43 am
Hi All;
Thanks !
Please read the first post.
maxipower
Sat Apr 04, 2020 3:46 pm
For those who only use Kodi is it worth upgrading to Kernel 5.4?
Rascas
Sat Apr 04, 2020 3:59 pm
Don't thinks so. Kernel 5.4 is still in testing and from a quick look, performance looks like the same, nothing new.
Sat Apr 04, 2020 5:08 pm
It's too early. It's an alpha kernel, not even beta. My TV uHAT doesn't run so my Kodi testing stalled.
maxipower
Sun Apr 05, 2020 6:28 pm
thank you both… ;)
Return to “Raspbian”
