Unfortunately kodi keeps crashing for me...
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri 1 Nov 01:08:49 CET 2019
Kodi Options:
Arch: aarch64
Kernel: Linux 4.19.75-v8+ #1270 SMP PREEMPT Tue Sep 24 18:59:17 BST 2019
Release: Raspbian GNU/Linux 10 (buster)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2019-11-01 01:08:46.691068395 +0100)
[New LWP 1769]
[New LWP 1833]
[New LWP 1798]
[New LWP 1842]
[New LWP 1800]
[New LWP 1801]
[New LWP 1843]
[New LWP 1844]
[New LWP 1809]
[New LWP 1802]
[New LWP 1808]
[New LWP 1835]
[New LWP 1810]
[New LWP 1839]
[New LWP 1834]
[New LWP 1805]
[New LWP 1806]
[New LWP 1836]
[New LWP 1811]
[New LWP 1841]
[New LWP 1845]
[New LWP 1803]
[New LWP 1807]
[New LWP 1838]
[New LWP 1837]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8 --lircdev /var/run/lirc/lircd'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x006c6be0 in MMAL::CMMALPool::CMMALPool(char const*, bool, unsigned int, unsigned int, unsigned int, MMAL::MMALState) ()
[Current thread is 1 (Thread 0xf2381c60 (LWP 1769))]
Thread 25 (Thread 0xe3ec70d0 (LWP 1837)):
#0 0xf640e8bc in __GI___libc_read (nbytes=4096, buf=0xed03ba60, fd=43) at ../sysdeps/unix/sysv/linux/read.c:26
#1 0xf640e8bc in __GI___libc_read (fd=43, buf=0xed03ba60, nbytes=4096) at ../sysdeps/unix/sysv/linux/read.c:24
#2 0xf63b3acc in _IO_new_file_underflow (fp=0xed00b718) at libioP.h:839
#3 0xf63b2b0c in __GI__IO_file_xsgetn (fp=0xed00b718, data=<optimized out>, n=4097) at fileops.c:1329
#4 0xf63a5e08 in __GI__IO_fread (buf=0xed03aa58, size=1, count=4097, fp=0xed00b718) at iofread.c:38
#5 0xf7818494 in () at /lib/arm-linux-gnueabihf/libudev.so.1
Thread 24 (Thread 0xe36c60d0 (LWP 1838)):
#0 0xf7f5557c in futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xe36c5978, expected=0, futex_word=0x3997c68) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f5557c in __pthread_cond_wait_common (abstime=0xe36c5978, mutex=0x0, cond=0x3997c40) at pthread_cond_wait.c:539
#2 0xf7f5557c in __pthread_cond_timedwait (cond=0x3997c40, mutex=0x0, abstime=0xe36c5978) at pthread_cond_wait.c:667
#3 0x005a1ed4 in std::cv_status std::_V2::condition_variable_any::wait_until<XbmcThreads::CRecursiveMutex, std::chrono::_V2::system_clock, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> > >(XbmcThreads::CRecursiveMutex&, std::chrono::time_point<std::chrono::_V2::system_clock, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> > > const&) ()
#4 0x005a1f9c in XbmcThreads::ConditionVariable::wait(CCriticalSection&, unsigned long) ()
#5 0x005a208c in CEvent::WaitMSec(unsigned int) ()
#6 0x00b48850 in PERIPHERALS::CPeripheralBus::Process() ()
#7 0x008725f8 in CThread::Action() ()
#8 0x008734f8 in CThread::staticThread(void*) ()
#9 0xf7f4e494 in start_thread (arg=0xe36c60d0) at pthread_create.c:486
#10 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 23 (Thread 0xeebfe0d0 (LWP 1807)):
#0 0xf7f58088 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xf6d315f4 <tvservice_notify_available_event+24>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f58088 in do_futex_wait ([email protected]=0xf6d315f4 <tvservice_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:115
#2 0xf7f581f4 in __new_sem_wait_slow (sem=0xf6d315f4 <tvservice_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:282
#3 0xf6d173b0 in tvservice_notify_func () at /opt/vc/lib/libbcm_host.so
#4 0xf6cddcb0 in vcos_thread_entry (arg=0xf6d31608 <tvservice_notify_task>) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#5 0xf7f4e494 in start_thread (arg=0xeebfe0d0) at pthread_create.c:486
Thread 22 (Thread 0xf09520d0 (LWP 1803)):
#0 0xf63e86d0 in __GI___nanosleep (remaining=0x0, requested_time=0xf0951724) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 0xf63e86d0 in __GI___nanosleep (requested_time=0xf0951724, [email protected]=0xf095171c, [email protected]=0x0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0xf6419fc0 in usleep (useconds=<optimized out>) at ../sysdeps/posix/usleep.c:32
#3 0x00d01844 in CAESinkPi::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#4 0x00cee2f4 in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#5 0x00cefa38 in ActiveAE::CActiveAESink::StateMachine(int, Actor::Protocol*, Actor::Message*) ()
#6 0x00cefbcc in ActiveAE::CActiveAESink::Process() ()
#9 0xf7f4e494 in start_thread (arg=0xf09520d0) at pthread_create.c:486
Thread 21 (Thread 0xe069f0d0 (LWP 1845)):
#0 0xf64196ac in __GI___select (timeout=0xe069ea68, exceptfds=0x0, writefds=0x0, readfds=0xe069e550, nfds=43) at ../sysdeps/unix/sysv/linux/select.c:41
#1 0xf64196ac in __GI___select (nfds=43, readfds=0xe069e550, writefds=0x0, exceptfds=0x0, timeout=0xe069e530) at ../sysdeps/unix/sysv/linux/select.c:37
#2 0x00b695a4 in JSONRPC::CTCPServer::Process() ()
#3 0x008725f8 in CThread::Action() ()
#4 0x008734f8 in CThread::staticThread(void*) ()
#5 0xf7f4e494 in start_thread (arg=0xe069f0d0) at pthread_create.c:486
#6 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 20 (Thread 0xe1ec30d0 (LWP 1841)):
#0 0xf795ff84 in Py_Initialize () at /usr/lib/arm-linux-gnueabihf/libpython2.7.so.1.0
#1 0x0065ff68 in XBPython::OnScriptInitialized(ILanguageInvoker*) ()
#2 0x0065c7b4 in CPythonInvoker::Execute(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) ()
#3 0x00c34774 in CLanguageInvokerThread::Process() ()
#4 0x008725f8 in CThread::Action() ()
#5 0x008734f8 in CThread::staticThread(void*) ()
#6 0xf7f4e494 in start_thread (arg=0xe1ec30d0) at pthread_create.c:486
#7 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 19 (Thread 0xe6db30d0 (LWP 1811)):
#0 0xf6415cd0 in __GI___poll (timeout=25000, nfds=1, fds=0xe6db26cc) at ../sysdeps/unix/sysv/linux/poll.c:29
#1 0xf6415cd0 in __GI___poll (fds=0xe6db26cc, nfds=1, timeout=25000) at ../sysdeps/unix/sysv/linux/poll.c:26
#2 0xf7cc7de4 in () at /lib/arm-linux-gnueabihf/libdbus-1.so.3
Thread 18 (Thread 0xe46c80d0 (LWP 1836)):
#0 0xf640e7b4 in __libc_openat64 (fd=45, file=0xe46c7618 "", oflag=2654208) at ../sysdeps/unix/sysv/linux/openat64.c:45
#1 0xf7828468 in () at /lib/arm-linux-gnueabihf/libudev.so.1
Thread 17 (Thread 0xef3ff0d0 (LWP 1806)):
#0 0xf7f58088 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xf6d32480 <dispmanx_notify_available_event+24>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f58088 in do_futex_wait ([email protected]=0xf6d32480 <dispmanx_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:115
#2 0xf7f581f4 in __new_sem_wait_slow (sem=0xf6d32480 <dispmanx_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:282
#3 0xf6d1b4d4 in dispmanx_notify_func () at /opt/vc/lib/libbcm_host.so
#4 0xf6cddcb0 in vcos_thread_entry (arg=0xf6d331c0 <dispmanx_notify_task>) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#5 0xf7f4e494 in start_thread (arg=0xef3ff0d0) at pthread_create.c:486
Thread 16 (Thread 0xeffff0d0 (LWP 1805)):
#0 0xf641851c in ioctl () at ../sysdeps/unix/syscall-template.S:78
#1 0xf6cf6010 in completion_thread () at /opt/vc/lib/libvchiq_arm.so
#2 0xf6cddcb0 in vcos_thread_entry (arg=0xf6d09318 <vchiq_instance+16>) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#3 0xf7f4e494 in start_thread (arg=0xeffff0d0) at pthread_create.c:486
#4 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 15 (Thread 0xe574a0d0 (LWP 1834)):
#0 0xf7f58e5c in __lll_lock_wait ([email protected]=0x39a8af0, private=0) at lowlevellock.c:43
#1 0xf7f50f44 in __GI___pthread_mutex_lock (mutex=0x39a8af0) at pthread_mutex_lock.c:80
#2 0x006a5fc4 in CZeroconfAvahi::doPublishService(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > const&) ()
#3 0x00b6fba8 in CZeroconf::CPublish::DoWork() ()
#4 0x00831e48 in CJobWorker::Process() ()
#5 0x008725f8 in CThread::Action() ()
#6 0x008734f8 in CThread::staticThread(void*) ()
#7 0xf7f4e494 in start_thread (arg=0xe574a0d0) at pthread_create.c:486
#8 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 14 (Thread 0xe2ec50d0 (LWP 1839)):
#0 0xf7f5557c in futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xe2ec4970, expected=0, futex_word=0x2b8c400) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f5557c in __pthread_cond_wait_common (abstime=0xe2ec4970, mutex=0x0, cond=0x2b8c3d8) at pthread_cond_wait.c:539
#2 0xf7f5557c in __pthread_cond_timedwait (cond=0x2b8c3d8, mutex=0x0, abstime=0xe2ec4970) at pthread_cond_wait.c:667
#5 0x00b52730 in PERIPHERALS::CEventScanner::Process() ()
#6 0x008725f8 in CThread::Action() ()
#7 0x008734f8 in CThread::staticThread(void*) ()
#8 0xf7f4e494 in start_thread (arg=0xe2ec50d0) at pthread_create.c:486
#9 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 13 (Thread 0xec7fe0d0 (LWP 1810)):
#0 0xf7f58088 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xef6049bc) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f58088 in do_futex_wait ([email protected]=0xef6049bc, abstime=0x0) at sem_waitcommon.c:115
#2 0xf7f581f4 in __new_sem_wait_slow (sem=0xef6049bc, abstime=0x0) at sem_waitcommon.c:282
#3 0xf6cf8b60 in vchiu_queue_pop () at /opt/vc/lib/libvchiq_arm.so
#4 0xf013ed70 in ilcs_task () at /opt/vc/lib/libopenmaxil.so
#5 0xf6cddcb0 in vcos_thread_entry (arg=0xef604878) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#6 0xf7f4e494 in start_thread (arg=0xec7fe0d0) at pthread_create.c:486
Thread 12 (Thread 0xe4f490d0 (LWP 1835)):
#0 0xf7f5557c in futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xe4f48a6c, expected=0, futex_word=0x39979c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f5557c in __pthread_cond_wait_common (abstime=0xe4f48a6c, mutex=0x0, cond=0x3997998) at pthread_cond_wait.c:539
#2 0xf7f5557c in __pthread_cond_timedwait (cond=0x3997998, mutex=0x0, abstime=0xe4f48a6c) at pthread_cond_wait.c:667
#3 0xf7d17714 in CEC::CCECClient::Process() () at /usr/lib/arm-linux-gnueabihf/libcec.so.4
#4 0xf7d1b848 in P8PLATFORM::CThread::ThreadHandler(void*) () at /usr/lib/arm-linux-gnueabihf/libcec.so.4
#5 0xf7f4e494 in start_thread (arg=0xe4f490d0) at pthread_create.c:486
Thread 11 (Thread 0xee3fd0d0 (LWP 1808)):
#0 0xf7f58088 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xf6d32384 <cecservice_notify_available_event+24>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f58088 in do_futex_wait ([email protected]=0xf6d32384 <cecservice_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:115
#2 0xf7f581f4 in __new_sem_wait_slow (sem=0xf6d32384 <cecservice_notify_available_event+24>, abstime=0x0) at sem_waitcommon.c:282
#3 0xf6d18720 in cecservice_notify_func () at /opt/vc/lib/libbcm_host.so
#4 0xf6cddcb0 in vcos_thread_entry (arg=0xf6d32398 <cecservice_notify_task>) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#5 0xf7f4e494 in start_thread (arg=0xee3fd0d0) at pthread_create.c:486
Thread 10 (Thread 0xf11530d0 (LWP 1802)):
#0 0xf7f5557c in futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xf1152950, expected=0, futex_word=0x2b70e80) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f5557c in __pthread_cond_wait_common (abstime=0xf1152950, mutex=0x0, cond=0x2b70e58) at pthread_cond_wait.c:539
#2 0xf7f5557c in __pthread_cond_timedwait (cond=0x2b70e58, mutex=0x0, abstime=0xf1152950) at pthread_cond_wait.c:667
#6 0x00ce9e68 in ActiveAE::CActiveAE::Process() ()
#9 0xf7f4e494 in start_thread (arg=0xf11530d0) at pthread_create.c:486
Thread 9 (Thread 0xecfff0d0 (LWP 1809)):
#0 0xf7f551a0 in futex_wait_cancelable (private=0, expected=0, futex_word=0xef604854) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 0xf7f551a0 in __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0xef604828) at pthread_cond_wait.c:502
#2 0xf7f551a0 in __pthread_cond_wait ([email protected]=0xef604828, mutex=0x0, [email protected]=0xef60480c) at pthread_cond_wait.c:655
#3 0xf6cddd94 in _timer_thread (arg=0xef604808) at /home/dom/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:722
#4 0xf7f4e494 in start_thread (arg=0xecfff0d0) at pthread_create.c:486
#5 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 8 (Thread 0xe0ec10d0 (LWP 1844)):
#0 0xf7fb5620 in strcmp (p1=<optimized out>, p2=<optimized out>) at strcmp.c:39
#1 0xf7fa3d60 in _dl_map_object (loader=0xef64a678, name=0xdfe8a72e "libresolv.so.2", type=<optimized out>, trace_mode=<optimized out>, mode=-2147483648, nsid=0) at dl-load.c:2186
#2 0xf7fa9270 in openaux (a=0xe0ebf9d0) at dl-deps.c:64
#3 0xf645e508 in __GI__dl_catch_exception (exception=0xe0ebfe88, [email protected]=0xe0ebf9c4, operate=0xf6493000, args=0xe0ebf9c4, [email protected]=0xe0ebf9d0) at dl-error-skeleton.c:196
#4 0xf7fa9564 in _dl_map_object_deps ([email protected]=0xef64a678, [email protected]=0x0, [email protected]=0, [email protected]=0, open_mode=<optimized out>, [email protected]=-2147483648) at dl-deps.c:248
#5 0xf7faf124 in dl_open_worker (a=0xe0ec0038) at dl-open.c:271
#6 0xf645e508 in __GI__dl_catch_exception (exception=0xe0ec00b0, [email protected]=0xe0ec002c, operate=0xf6493000, args=0xe0ec002c, [email protected]=0xe0ec0030) at dl-error-skeleton.c:196
#7 0xf7faec04 in _dl_open (file=0xe0ec02c8 "libnss_dns.so.2", mode=-2147483646, caller_dlopen=0xf6444b58 <nss_load_library+340>, [email protected]=-2, argc=3, argv=0xff8295d4, env=0x39a29b8) at dl-open.c:599
#8 0xf645d880 in do_dlopen (ptr=0xe0ec02a4) at dl-libc.c:96
#9 0xf645e508 in __GI__dl_catch_exception (exception=0x0, [email protected]=0xe0ec0250, operate=0xf6493000, args=0xe0ec0250, [email protected]=0x39a8ca0) at dl-error-skeleton.c:196
#10 0xf645e5c8 in __GI__dl_catch_error (objname=0xe0ec0284, [email protected]=0xe0ec027c, errstring=0xe0ec0288, [email protected]=0xe0ec0280, mallocedp=0xe0ec0283, [email protected]=0xe0ec027b, operate=<optimized out>, args=0xe0ec02a4, [email protected]=0xe0ec029c) at dl-error-skeleton.c:215
#11 0xf645d9cc in dlerror_run (operate=<optimized out>, [email protected]=0xe0ec029c) at dl-libc.c:46
#12 0xf645da70 in __GI___libc_dlopen_mode ([email protected]=0xe0ec02c8 "libnss_dns.so.2", mode=mo[email protected]=-2147483646) at dl-libc.c:195
#13 0xf6444b58 in nss_load_library ([email protected]=0x39a8c80) at nsswitch.c:369
#14 0xf64454f0 in __GI___nss_lookup_function ([email protected]=0x39a8c80, fct_name=<optimized out>) at nsswitch.c:477
#15 0xf6406ea4 in gaih_inet ([email protected]=0xef5879e8 "mirrors.kodi.tv", [email protected]=0xe0ec0590, req=<optimized out>, [email protected]=0xe0ec0580, [email protected]=0xe0ec058c, [email protected]=0xe0ec0628) at ../sysdeps/posix/getaddrinfo.c:764
#16 0xf6407d4c in __GI_getaddrinfo (name=<optimized out>, service=<optimized out>, hints=<optimized out>, pai=0xe0ec0a70) at ../sysdeps/posix/getaddrinfo.c:2265
#17 0xf7526f5c in () at /usr/lib/arm-linux-gnueabihf/libcurl.so.4
Thread 7 (Thread 0xe16c20d0 (LWP 1843)):
#0 0xf64196ac in __GI___select (timeout=0x1, exceptfds=0x0, writefds=0x0, readfds=0xe16c1940, nfds=45) at ../sysdeps/unix/sysv/linux/select.c:41
#1 0xf64196ac in __GI___select (nfds=45, readfds=0xe16c1940, writefds=0x0, exceptfds=0x0, timeout=0xe16c1880) at ../sysdeps/unix/sysv/linux/select.c:37
#2 0x00b67b28 in SOCKETS::CSocketListener::Listen(int) ()
#3 0x00b5eeac in EVENTSERVER::CEventServer::Run() ()
#4 0x00b5f01c in EVENTSERVER::CEventServer::Process() ()
#7 0xf7f4e494 in start_thread (arg=0xe16c20d0) at pthread_create.c:486
Thread 6 (Thread 0xf19ff0d0 (LWP 1801)):
#0 0xf64209d0 in epoll_wait (epfd=<optimized out>, events=0xf19fe9d0, maxevents=1, timeout=200) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#1 0x006aa65c in CLibInputHandler::Process() ()
#2 0x008725f8 in CThread::Action() ()
#3 0x008734f8 in CThread::staticThread(void*) ()
#4 0xf7f4e494 in start_thread (arg=0xf19ff0d0) at pthread_create.c:486
Thread 5 (Thread 0xed9ff0d0 (LWP 1800)):
#0 0xf7f5557c in futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xed9fe948, expected=0, futex_word=0x2a4bb40) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 0xf7f5557c in __pthread_cond_wait_common (abstime=0xed9fe948, mutex=0x0, cond=0x2a4bb18) at pthread_cond_wait.c:539
#2 0xf7f5557c in __pthread_cond_timedwait (cond=0x2a4bb18, mutex=0x0, abstime=0xed9fe948) at pthread_cond_wait.c:667
#6 0x006a97f8 in CLirc::Process() ()
#9 0xf7f4e494 in start_thread (arg=0xed9ff0d0) at pthread_create.c:486
Thread 4 (Thread 0xe26c40d0 (LWP 1842)):
#0 0xf7f58e98 in __lll_lock_wait ([email protected]=0x39a8af0, private=0) at lowlevellock.c:46
#2 0xf7e343e8 in () at /usr/lib/arm-linux-gnueabihf/libavahi-common.so.3
Thread 3 (Thread 0xf237e0d0 (LWP 1798)):
#0 0xf7f551a0 in futex_wait_cancelable (private=0, expected=0, futex_word=0x2aca290) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 0xf7f551a0 in __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x2aca268) at pthread_cond_wait.c:502
#2 0xf7f551a0 in __pthread_cond_wait (cond=0x2aca268, mutex=0x0) at pthread_cond_wait.c:655
#3 0xf652ec94 in std::condition_variable::wait(std::unique_lock<std::mutex>&) () at /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
#4 0x008720f8 in void std::_V2::condition_variable_any::wait<XbmcThreads::CRecursiveMutex>(XbmcThreads::CRecursiveMutex&) ()
#5 0x00c45298 in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#8 0xf7f4e494 in start_thread (arg=0xf237e0d0) at pthread_create.c:486
Thread 2 (Thread 0xe5f4b0d0 (LWP 1833)):
#0 0xf64196ac in __GI___select (timeout=0xd86, exceptfds=0x0, writefds=0x0, readfds=0x0, nfds=0) at ../sysdeps/unix/sysv/linux/select.c:41
#1 0xf64196ac in __GI___select (nfds=0, readfds=0x0, writefds=0x0, exceptfds=0x0, timeout=0xe5f48db0) at ../sysdeps/unix/sysv/linux/select.c:37
#2 0x00c7e65c in XFILE::CCurlFile::CReadState::FillBuffer(unsigned int) ()
#3 0x00c7eab0 in XFILE::CCurlFile::CReadState::Connect(unsigned int) ()
#4 0x00c807cc in XFILE::CCurlFile::Open(CURL const&) ()
#5 0x00c8e7a0 in XFILE::CFile::Open(CURL const&, unsigned int) ()
#6 0x00c8ec60 in XFILE::CFile::Open(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int) ()
#7 0x00c8ab7c in XFILE::CFileCache::Open(CURL const&) ()
#8 0x00c8e720 in XFILE::CFile::Open(CURL const&, unsigned int) ()
#9 0x00c8ec60 in XFILE::CFile::Open(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int) ()
#10 0x009ea1a4 in ADDON::CRepository::FetchChecksum(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&) ()
#11 0x009eb2c4 in ADDON::CRepository::FetchIfChanged(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::vector<std::shared_ptr<ADDON::IAddon>, std::allocator<std::shared_ptr<ADDON::IAddon> > >&) const ()
#12 0x009eb574 in ADDON::CRepositoryUpdateJob::DoWork() ()
#13 0x00831e48 in CJobWorker::Process() ()
#14 0x008725f8 in CThread::Action() ()
#15 0x008734f8 in CThread::staticThread(void*) ()
#16 0xf7f4e494 in start_thread (arg=0xe5f4b0d0) at pthread_create.c:486
#17 0xf6420578 in () at ../sysdeps/unix/sysv/linux/arm/clone.S:73
Thread 1 (Thread 0xf2381c60 (LWP 1769)):
#1 0x006955cc in CProcessInfoPi::CProcessInfoPi() ()
#2 0x00695770 in CProcessInfoPi::Create() ()
#3 0x006e52f8 in CProcessInfo::CreateInstance() ()
#4 0x0073cf60 in CVideoPlayer::CVideoPlayer(IPlayerCallback&) ()
#5 0x00cca928 in CPlayerCoreConfig::CreatePlayer(IPlayerCallback&) const ()
#6 0x00cc9474 in CPlayerCoreFactory::CreatePlayer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, IPlayerCallback&) const ()
#7 0x00a12e50 in CApplicationPlayer::CreatePlayer(CPlayerCoreFactory const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, IPlayerCallback&) ()
#8 0x00a153bc in CApplicationPlayer::OpenFile(CFileItem const&, CPlayerOptions const&, CPlayerCoreFactory const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, IPlayerCallback&) ()
#9 0x00a0db6c in CApplication::PlayFile(CFileItem, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool) ()
#10 0x00a45348 in PLAYLIST::CPlayListPlayer::Play(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, bool, bool) ()
#11 0x00a45964 in PLAYLIST::CPlayListPlayer::Play() ()
#12 0x00a45c38 in PLAYLIST::CPlayListPlayer::OnApplicationMessage(KODI::MESSAGING::ThreadMessage*) ()
#13 0x008a31b0 in KODI::MESSAGING::CApplicationMessenger::ProcessMessage(KODI::MESSAGING::ThreadMessage*) ()
#14 0x008a3504 in KODI::MESSAGING::CApplicationMessenger::ProcessMessages() ()
#15 0x00a0fe50 in CApplication::Process() ()
#16 0x00a5d200 in CXBApplicationEx::Run(CAppParamParser const&) ()
#17 0x0088eef0 in XBMC_Run ()
#18 0x00519abc in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
2019-11-01 01:08:43.207 T:4063763552 NOTICE: -----------------------------------------------------------------------
2019-11-01 01:08:43.207 T:4063763552 NOTICE: Starting Kodi (18.4 Git:20191027-06c77692ee). Platform: Linux ARM 32-bit
2019-11-01 01:08:43.207 T:4063763552 NOTICE: Using Release Kodi x32 build
2019-11-01 01:08:43.207 T:4063763552 NOTICE: Kodi compiled 2019-10-27 by GCC 8.3.0 for Linux ARM 32-bit version 4.18.20 (266772)
2019-11-01 01:08:43.207 T:4063763552 NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 64-bit version 4.19.75-v8+
2019-11-01 01:08:43.214 T:4063763552 NOTICE: FFmpeg version/source: 4.0.4-Kodi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: 4 CPU cores available
2019-11-01 01:08:43.214 T:4063763552 NOTICE: ARM Features: Neon enabled
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://envhome/ is mapped to: /home/pi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-11-01 01:08:43.214 T:4063763552 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-11-01 01:08:43.214 T:4063763552 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8
2019-11-01 01:08:43.214 T:4063763552 NOTICE: Local hostname: multimedia-pi
2019-11-01 01:08:43.214 T:4063763552 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-11-01 01:08:43.214 T:4063763552 NOTICE: -----------------------------------------------------------------------
2019-11-01 01:08:43.223 T:4063763552 INFO: loading settings
2019-11-01 01:08:43.226 T:4063763552 NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-11-01 01:08:43.243 T:4063763552 DEBUG: CSkinSettings: no <skinsettings> tag found
2019-11-01 01:08:43.247 T:4063763552 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-11-01 01:08:43.247 T:4063763552 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
2019-11-01 01:08:43.247 T:4063763552 WARNING: CSettingsManager: missing version attribute
2019-11-01 01:08:43.248 T:4063763552 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-11-01 01:08:43.248 T:4063763552 NOTICE: Default Video Player: VideoPlayer
2019-11-01 01:08:43.248 T:4063763552 NOTICE: Default Audio Player: paplayer
2019-11-01 01:08:43.248 T:4063763552 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-11-01 01:08:43.248 T:4063763552 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-11-01 01:08:43.341 T:4063763552 NOTICE: PulseAudio: Server found running - will try to use Pulse
2019-11-01 01:08:43.352 T:4063763552 NOTICE: Running database version Addons27
2019-11-01 01:08:43.454 T:4063763552 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: inputstream.adaptive v2.3.22 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: inputstream.rtmp v2.0.5 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.local v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: peripheral.joystick v1.4.7 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: pvr.hts v4.4.18 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: pvr.iptvsimple v3.5.8 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.57 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-11-01 01:08:43.455 T:4063763552 NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: skin.estouchy v2.0.26 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: skin.estuary v2.0.25 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.addon v18.4.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.json v10.3.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-11-01 01:08:43.456 T:4063763552 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-11-01 01:08:43.483 T:4063763552 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-11-01 01:08:43.511 T:4044697808 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2019-11-01 01:08:43.512 T:4044697808 NOTICE: Found 2 Lists of Devices
2019-11-01 01:08:43.512 T:4044697808 NOTICE: Enumerated PI devices:
2019-11-01 01:08:43.512 T:4044697808 NOTICE: Device 1
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_deviceName : HDMI
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_displayName : HDMI
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_displayNameExtra:
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_channels : FL, FR
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-11-01 01:08:43.512 T:4044697808 NOTICE: Device 2
2019-11-01 01:08:43.512 T:4044697808 NOTICE: m_deviceName : Analogue
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayName : Analogue
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayNameExtra:
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_channels : FL, FR
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_sampleRates : 48000
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_streamTypes : No passthrough capabilities
2019-11-01 01:08:43.513 T:4044697808 NOTICE: Device 3
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_deviceName : Both
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayName : HDMI and Analogue
2019-11-01 01:08:43.513 T:4044697808 NOTICE: Enumerated PULSE devices:
2019-11-01 01:08:43.513 T:4044697808 NOTICE: Device 1
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_deviceName : Default
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayName : Default
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2019-11-01 01:08:43.513 T:4044697808 NOTICE: Device 2
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_deviceName : alsa_output.usb-_C_2011-2013_TeleVox_USB-SPDIF_V1.11_0040119-00.analog-stereo
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayName : USB-SPDIF V1.11 Analog Stereo
2019-11-01 01:08:43.513 T:4044697808 NOTICE: m_displayNameExtra: Analog Output (PULSEAUDIO)
2019-11-01 01:08:43.606 T:4063763552 NOTICE: Raspberry PI firmware version: Sep 24 2019 17:36:31
Copyright (c) 2012 Broadcom
version cd3add54955f8fa065b414d8fc07c525e7ddffc8 (clean) (release) (start_x)
2019-11-01 01:08:43.606 T:4063763552 NOTICE: ARM mem: 844MB GPU mem: 180MB MPG2:0 WVC1:0
2019-11-01 01:08:43.606 T:4063763552 NOTICE: Config:
arm_64bit=1
arm_freq=1500
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=500
hdmi_channel_map=8
init_uart_clock=0x2dc6c00
lcd_framerate=60
mask_gpu_interrupt0=1024
mask_gpu_interrupt1=0x10000
max_framebuffers=2
pause_burst_frames=1
program_serial_random=1
hdmi_drive:0=2
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_force_hotplug:0=1
hdmi_group:0=1
hdmi_mode:0=16
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
device_tree=-
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
2019-11-01 01:08:44.225 T:4063763552 WARNING: CDRMUtils::FindPlane - could not find plane
2019-11-01 01:08:44.226 T:4063763552 WARNING: CDRMUtils::InitDrm - failed to set drm master, will try to authorize instead: Permission denied
2019-11-01 01:08:44.226 T:4063763552 NOTICE: CDRMUtils::InitDrm - successfully authorized drm magic
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 60.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 59.940063 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 50.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 30.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 29.970032 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 25.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 24.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1920x1080 with 1920x1080 @ 23.976025 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1600x1200 with 1600x1200 @ 60.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1280x1024 with 1280x1024 @ 75.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1280x1024 with 1280x1024 @ 60.000000 Hz
2019-11-01 01:08:45.027 T:4063763552 NOTICE: Found resolution 1280x960 with 1280x960 @ 85.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1280x960 with 1280x960 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1152x864 with 1152x864 @ 75.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1280x720 with 1280x720 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1280x720 with 1280x720 @ 59.940063 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1024x768 with 1024x768 @ 85.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1024x768 with 1024x768 @ 75.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1024x768 with 1024x768 @ 70.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 832x624 with 832x624 @ 74.925079 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 800x600 with 800x600 @ 85.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 800x600 with 800x600 @ 75.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 800x600 with 800x600 @ 72.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 800x600 with 800x600 @ 56.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 720x480 with 720x480 @ 59.940063 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 720x480 with 720x480 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 640x480 with 640x480 @ 85.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 640x480 with 640x480 @ 75.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 640x480 with 640x480 @ 73.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 640x480 with 640x480 @ 67.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Previous line repeats 1 times.
2019-11-01 01:08:45.028 T:4063763552 NOTICE: Found resolution 720x400 with 720x400 @ 70.000000 Hz
2019-11-01 01:08:45.030 T:4063763552 NOTICE: EGL_VERSION = 1.4
2019-11-01 01:08:45.030 T:4063763552 NOTICE: EGL_VENDOR = Mesa Project
2019-11-01 01:08:45.030 T:4063763552 NOTICE: EGL_EXTENSIONS = EGL_ANDROID_blob_cache EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_WL_bind_wayland_display
2019-11-01 01:08:45.030 T:4063763552 NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_wayland EGL_EXT_platform_x11 EGL_MESA_platform_gbm EGL_MESA_platform_surfaceless EGL_EXT_platform_device
2019-11-01 01:08:45.033 T:4063763552 NOTICE: Checking resolution 16
2019-11-01 01:08:45.159 T:4063763552 WARNING: CGBMUtils::DestroySurface - surface already destroyed
2019-11-01 01:08:45.201 T:4063763552 NOTICE: GL_VENDOR = Broadcom
2019-11-01 01:08:45.201 T:4063763552 NOTICE: GL_RENDERER = V3D 4.2
2019-11-01 01:08:45.201 T:4063763552 NOTICE: GL_VERSION = OpenGL ES 3.0 Mesa 19.2.0-rc1
2019-11-01 01:08:45.201 T:4063763552 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
2019-11-01 01:08:45.201 T:4063763552 NOTICE: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT_texture_border_clamp GL_KHR_context_flush_control GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_EXT_float_blend GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_MESA_shader_integer_functions GL_KHR_parallel_shader_compile GL_EXT_texture_query_lod
2019-11-01 01:08:45.875 T:3873124560 NOTICE: Running database version Addons27
2019-11-01 01:08:45.876 T:3873124560 NOTICE: Running database version ViewModes6
2019-11-01 01:08:45.878 T:3873124560 NOTICE: Running database version Textures13
2019-11-01 01:08:45.883 T:3873124560 NOTICE: Running database version MyMusic72
2019-11-01 01:08:45.891 T:3873124560 NOTICE: Running database version MyVideos116
2019-11-01 01:08:45.894 T:3873124560 NOTICE: Running database version TV32
2019-11-01 01:08:45.896 T:3873124560 NOTICE: Running database version Epg12
2019-11-01 01:08:45.909 T:4063763552 NOTICE: start dvd mediatype detection
2019-11-01 01:08:45.949 T:4063763552 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.25)
2019-11-01 01:08:46.358 T:4063763552 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-11-01 01:08:46.450 T:4063763552 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-11-01 01:08:46.450 T:4063763552 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-11-01 01:08:46.452 T:4063763552 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-11-01 01:08:46.454 T:4063763552 NOTICE: Loaded playercorefactory configuration
2019-11-01 01:08:46.455 T:4063763552 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-11-01 01:08:46.455 T:4063763552 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-11-01 01:08:46.462 T:4063763552 NOTICE: initialize done
2019-11-01 01:08:46.462 T:4063763552 NOTICE: Running the application...
2019-11-01 01:08:46.470 T:4063763552 NOTICE: starting zeroconf publishing
2019-11-01 01:08:46.473 T:3781959888 NOTICE: ES: Starting UDP Event server on port 9777
2019-11-01 01:08:46.473 T:3781959888 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-11-01 01:08:46.476 T:4063763552 ERROR: CMMALPool::CMMALPool Failed to create component vc.ril.video_decode
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
