Today I decided to do an update, I have a "if it aint broke, let's brake it" mythology apparently.
I just ran a `sudo apt upgrade` got the following list of packages to upgrade:
base-files/stable 10.3+rpi1+deb10u1 armhf [upgradable from: 10.3+rpi1]
bzip2/stable 1.0.6-9.2~deb10u1 armhf [upgradable from: 1.0.6-9.1]
console-setup-linux/stable 1.193~deb10u1 all [upgradable from: 1.191]
console-setup/stable 1.193~deb10u1 all [upgradable from: 1.191]
dirmngr/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
docker-ce-cli/buster 5:19.03.2~3-0~raspbian-buster armhf [upgradable from: 5:19.03.1~3-0~raspbian-buster]
docker-ce/buster 5:19.03.2~3-0~raspbian-buster armhf [upgradable from: 5:19.03.1~3-0~raspbian-buster]
e2fsprogs/stable 1.44.5-1+deb10u1 armhf [upgradable from: 1.44.5-1]
gnupg-l10n/stable 2.2.12-1+rpi1+deb10u1 all [upgradable from: 2.2.12-1+rpi1]
gnupg-utils/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gnupg/stable 2.2.12-1+rpi1+deb10u1 all [upgradable from: 2.2.12-1+rpi1]
gpg-agent/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpg-wks-client/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpg-wks-server/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpg/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpgconf/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpgsm/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
gpgv/stable 2.2.12-1+rpi1+deb10u1 armhf [upgradable from: 2.2.12-1+rpi1]
keyboard-configuration/stable 1.193~deb10u1 all [upgradable from: 1.191]
libbabeltrace1/stable 1.5.6-2+deb10u1 armhf [upgradable from: 1.5.6-2]
libbz2-1.0/stable 1.0.6-9.2~deb10u1 armhf [upgradable from: 1.0.6-9.1]
libcom-err2/stable 1.44.5-1+deb10u1 armhf [upgradable from: 1.44.5-1]
libcryptsetup12/stable 2:2.1.0-5+deb10u2 armhf [upgradable from: 2:2.1.0-5]
libext2fs2/stable 1.44.5-1+deb10u1 armhf [upgradable from: 1.44.5-1]
libglib2.0-0/stable 2.58.3-2+deb10u1 armhf [upgradable from: 2.58.3-2]
libglib2.0-bin/stable 2.58.3-2+deb10u1 armhf [upgradable from: 2.58.3-2]
libglib2.0-data/stable 2.58.3-2+deb10u1 all [upgradable from: 2.58.3-2]
libldap-2.4-2/stable 2.4.47+dfsg-3+rpi1+deb10u1 armhf [upgradable from: 2.4.47+dfsg-3+rpi1]
libldap-common/stable 2.4.47+dfsg-3+rpi1+deb10u1 all [upgradable from: 2.4.47+dfsg-3+rpi1]
libncurses6/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
libncursesw5/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
libncursesw6/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
libnss3/stable 2:3.42.1-1+deb10u1 armhf [upgradable from: 2:3.42.1-1]
libpam-systemd/stable 241-7~deb10u1+rpi1 armhf [upgradable from: 241-5+rpi1]
libss2/stable 1.44.5-1+deb10u1 armhf [upgradable from: 1.44.5-1]
libsystemd0/stable 241-7~deb10u1+rpi1 armhf [upgradable from: 241-5+rpi1]
libtinfo5/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
libtinfo6/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
libudev1/stable 241-7~deb10u1+rpi1 armhf [upgradable from: 241-5+rpi1]
libwbclient0/stable 2:4.9.5+dfsg-5+deb10u1+rpi1 armhf [upgradable from: 2:4.9.5+dfsg-5]
ncurses-base/stable 6.1+20181013-2+deb10u1 all [upgradable from: 6.1+20181013-2]
ncurses-bin/stable 6.1+20181013-2+deb10u1 armhf [upgradable from: 6.1+20181013-2]
ncurses-term/stable 6.1+20181013-2+deb10u1 all [upgradable from: 6.1+20181013-2]
systemd-sysv/stable 241-7~deb10u1+rpi1 armhf [upgradable from: 241-5+rpi1]
udev/stable 241-7~deb10u1+rpi1 armhf [upgradable from: 241-5+rpi1]
unzip/stable 6.0-23+deb10u1 armhf [upgradable from: 6.0-23]
usb.ids/stable 2019.07.27-0+deb10u1 all [upgradable from: 2019.04.23-1]
After the reboot the Pi4 won't boot. When it powers on, red light stays on, green light blinks for 1-2 seconds and then turns off. Whats strange is that none of the USB devices power on either, usually their light would come up right away.
I removed the sd card and i did get the correct number of blinking lights coming up (4 green blinks) so the bootloader seems ok.
I then reflashed my sd card (with balenaEtcher) with a fresh copy Raspbian Lite, still same deal. Also disconnected all devices from the board except for network cable.
Any ideas on what's happening / what other things i can do to trouble shoot this.
