FAGould
Bluetooth Headset not working on RPi4B
Fri Sep 13, 2019 12:17 pm
I originally posted this issue a few days ago on the Arch Linux topic, link below, in this RPF forum and have had 83 views to this time but no replies.
https://www.raspberrypi.org/forums/view ... 0#p1531340
That issue has turned out to be the same for both ALARM and Raspbian. Below is a link to the bluetooth audio that skips and lags over bluetooth headset whether I have Wi-Fi on or disabled. These same headset work correctly on Apple Mac OSX. I could obviously pair and connect the headset with ALARM bluetooth raspberry pi from github but the audio always sounds like the recording at the link below.
https://drive.google.com/open?id=1NuJAx ... wUGKsZqHHN
I have searched all old posts for RPi3B and Zero but none of their solutions work on RPi4B. In testing different values in code, there were no changes to the audio. I cannot find any information about the Bluetooth/Wi-Fi chips used by RPi4B, so I have no idea if the modules loaded are correct versus RPi3B.
Can someone help me with this problem?
mahjongg
Re: Bluetooth Headset not working on RPi4B
Fri Sep 13, 2019 2:51 pm
Deleted post in ARC, because duplicates are not allowed here, next time ask a moderator to move your post.
Douglas6
Fri Sep 13, 2019 3:34 pm
I have not heard of any complaints regarding audio streaming on the Pi4. I have not tried streaming from my Pi4, but I have tested streaming TO it, and it's been working fine. I doubt if it's due to a module mismatch.
You didn't mention much about your system. You're not using PulseAudio, are you? Bluetooth can be subject to environmental impact from other Bluetooth or Wi-Fi devices, etc. I would remove your Pi from any case it might be in, remove any fans or other attachments, and take the Pi on a picnic to the middle of a large, open field, away from power lines. See if that helps.
FAGould
Fri Sep 13, 2019 8:11 pm
This site is so frustrating when told by a moderator to do something but there is no suggestions how to do that something. Where do I request a moderator move a reported issue?
Then the next person posts questions that my deleted post contained. I'm using pulseaudio, alarm-bluetooth-raspberrypi, and blueman. I am playing back an m4a file using vlc. I included my install instructions below and also on https://superuser.com/questions/1479002 ... headphones. I have disabled Wi-Fi and removed a UPS HAT to test if those caused the problem but nothing has worked or changed the audio from skipping and lagging. It always sounds the same no matter what I do.
sudo pacman -S pulseaudio-alsa pulseaudio-bluetooth bluez-utils bluez-hid2hci bluez-libs bluez-plugins bluez-cups blueman
systemctl start bluetooth
systemctl enable bluetooth
bluetoothctl  # Just to test install, 'power on' -> No controller
cd /home/fgould/build
git clone https://github.com/RoEdAl/alarm-bluetooth-raspberrypi.git
cd alarm-bluetooth-raspberrypi/
nano PKGBUILD 	# change dependency to linux-raspberrypi4
makepkg -Asri
I believe the problem is in the alarm-bluetooth-raspberrypi code (below: bcmbt-overlay.dts) where it might be addressing a different driver than on the RPi3 models that this supposedly works. I was hoping someone in this forum could help guide me to the right chipset/driver.
       compatible = "brcm,bcm2708";
        [email protected] {
                target-path = "uart0";
                __overlay__ {
                        bluetooth {
                                compatible = "brcm,bcm43438-bt";
                                max-speed = <2000000>; /* You can experiment with this */
                                /* Other elements omitted, pins may be different on different PI models */
Douglas6
Fri Sep 13, 2019 8:25 pm
I'm afraid I have nothing to say regarding an Arch distro. I tend to stick with Raspbian, and I would not use PulseAudio, Blueman, or alarm-bluetooth-raspberrypi (whatever that does). The standard Raspbian comes with everything you need for Bluetooth streaming audio, and in my experience, it works quite well.
To move a post, you can report on it by clicking the flag icon, and ask a moderator to move it in the comments.
I'm sorry I can't be of more help.
gothaf
Fri Sep 13, 2019 8:59 pm
I confirm that A2DP is practically unusable on my Pi4 also, running RaspbianXFCE. Audio stutters badly all the time and switching the wifi off does absolutely nothing.
