ValterFukuoka
RPIZero arm1176jzf-s machine code...
Fri Sep 13, 2019 12:23 am
Hi, I am compiling NodeJS module WebRTC (node-wrtc) from source to target the armv6zk (arm1176jzf-s), the RPIZero CPU.
As part of the compilation, it is necessary to compile WebRTC code itself to target the armv6zk.
Both codes, the NodeJS module and WebRTC, are compiled with flags/arguments march="armv6zk" and mtune"arm1176jzf-s"...
The WebRTC compilation toolkit provides a compiler which accept the flag "use_neon=false", that I am using to invoke the compilation...
I tested the result on a RPIZero, it works OK!
The code is also working on a RPI3, which is expected...
On the RPIZero, I am ONLY interested in using WebRTC DataChannel, which is a small part of the whole, and don't have any intention of using audio or video streaming... so, the generated code is working on the RPIZero from the DataChannel function point of view...
I found a "concern", and this is the topic of the present message...
Inside the WebRTC code, out of 2871 generated binaries, 12 of them (listed below) have VFPv3 and NEON machine code!?!?
The following is the output from "readelf -A":
./third_party/boringssl/boringssl_asm/sha512-armv4.o
Attribute Section: aeabi
File Attributes
  Tag_CPU_name: "arm1176jzf-s"
  Tag_CPU_arch: v6
  Tag_CPU_arch_profile: Application
  Tag_ARM_ISA_use: Yes
  Tag_THUMB_ISA_use: Thumb-1
  Tag_FP_arch: VFPv3
  Tag_Advanced_SIMD_arch: NEONv1
  Tag_CPU_unaligned_access: None
  Tag_Virtualization_use: TrustZone
./third_party/boringssl/boringssl_asm/ghashv8-armx32.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/sha1-armv4-large.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/x25519-asm-arm.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/ghash-armv4.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/aesv8-armx32.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/bsaes-armv7.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/armv4-mont.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
  ./third_party/boringssl/boringssl_asm/chacha-armv4.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
  ./third_party/boringssl/boringssl_asm/poly1305_arm_asm.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/boringssl/boringssl_asm/sha256-armv4.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
./third_party/opus/opus/celt_pitch_xcorr_arm_gnu.o
File Attributes
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
Looking at the names of the files, the "asm" part probably implicates that these are assembly instructions targeting VFPv3 and NEONv1 machine code...
My question is:
Does the arm1176jzf-s (Raspi Zero) have the ability to run (emulate) VFPv3 and NEONv1?
What happens when these specifics portion of the code is called (in a RPIZero)?
Is there any other way to interpret the abouve output of readelf utility?
Does anybody have any experience with similar situation?
Thanks in advance,
Valter
ValterFukuoka
Re: RPIZero arm1176jzf-s machine code...
Fri Sep 13, 2019 6:46 pm
Looking at Chromium inside a Buster RaspberryPI Zero, there seems to be 2 versions; one is probably the v6 version, and the other is marked v7...
The v6 version, also, gives the same result that I am talking about above...
"VFPv3" and "NEONv1" instructions... while the v7 shows arm-v7 cpu-name/arch...
pi@raspberrypi:/usr/lib/chromium-browser $ readelf -A chromium-browser
File Attributes
  Tag_CPU_name: "6"
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv3
  Tag_ABI_PCS_GOT_use: GOT-indirect
  Tag_ABI_PCS_wchar_t: 4
  Tag_ABI_FP_rounding: Needed
  Tag_ABI_FP_denormal: Needed
  Tag_ABI_FP_exceptions: Needed
  Tag_ABI_FP_number_model: IEEE 754
  Tag_ABI_align_needed: 8-byte
  Tag_ABI_enum_size: int
  Tag_ABI_VFP_args: VFP registers
  Tag_CPU_unaligned_access: v6
  Tag_ABI_FP_16bit_format: IEEE 754
pi@raspberrypi:/usr/lib/chromium-browser $ readelf -A chromium-browser-v7
File Attributes
  Tag_CPU_name: "ARM v7"
  Tag_CPU_arch: v7
  Tag_THUMB_ISA_use: Thumb-2
  Tag_FP_arch: VFPv4
  Tag_Advanced_SIMD_arch: NEONv1 with Fused-MAC
So, what is the meaning of this last piece of information?
Is the RPIZero arm1176jzf-s able to run "VFPv3" and "NEONv1" instruction, native or by emulation?
Or, the current Buster Chromium compilation for RPIZero is getting the same results that I am describing on the first post? On the same pieces of code (borinssl related)?
For reference, below is the readelf -A result for the galculator...
pi@raspberrypi:/usr/bin $ readelf -A galculator
File Attributes
  Tag_CPU_name: "6"
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv2
  Tag_ABI_align_preserved: 8-byte, except leaf SP
  Tag_ABI_HardFP_use: Deprecated
Also, current Buster Firefox-esr readelf -A output...
pi@raspberrypi:/usr/lib/firefox-esr $ readelf -A firefox-esr
File Attributes
  Tag_CPU_name: "6"
  Tag_CPU_arch: v6
  Tag_FP_arch: VFPv2
Firefox-esr and Chromium shows different data... Firefox shows "VFPv2" and DOES NOT show "NEONv1"...
Thanks,
Valter
ValterFukuoka
Wed Sep 25, 2019 10:31 am
Just want to say that I am building a little tutorial here (github) about the compilation steps for the Node WRTC Module for the Raspberry PI Zero:
https://github.com/t2age/webrtc-armv6
I still not have an answer for the question above, but I have decided to try some sort of "brute force" method, by creating a small set of tests scripts (node/javascript) that, by running correctly will serve to satisfy the functionality of the module compiled, at least to a certain degree...
In this way, I can be sure that, for this particular task, the compilation is working well...
The compiled result is currently good for WebRTC DataChannel, and, it is working with WebTorrent as well (on the RPIZero)...
Regards,
Valter
Return to “Advanced users”
