RedPanther
Raspberry Pi distributed computer project(UPDATED)
Thu Sep 12, 2019 11:11 pm
Welcome to my project build!
I’m newer to the whole working with code and terminal commands, but I’ve made it this far by doing simple research and actually learning from what I do. I’ve been into working on gaming computers for years, so this is a fun new area to me!
Here’s what I’ve got so far:
1- Raspberry Pi 3B+(powered from desktop power supply 5v via factory micro usb power slot)
1- 220W desktop power supply
1- 32Gb SD card for boot and recovery
1- Powered 4-port usb3 hub(powered via power supply 5v) for connecting HDDs
1- 500Gb 2.5” HDD(powered via power supply, connected via sata to usb3) Root FileSystem
1- 4Tb 2.5” HDD(“”””””) for PLEX media server
1- 1Tb 2.5” HDD(“”””””) for local network file storage and exchange
1- 1Tb 2.5” HDD(powered and connected via built in usb3.1) for personal file storage
3- 80mm 12v fans(powered via power supply)
The idea behind this project was to build a simple simple server using my Pi, and not need a separate power supply for every device. Well, I got carried away with what I had laying around, and spent $45 for connectors. Three adapters to convert sata ports on HDDs to usb3, and a powered usb3 hub.
This build is currently two days into full testing, and has held up amazingly! As long as it’s only used for it’s intended purpose, that is. These little things aren’t great for computing power, so I came up with an idea to fix that in the near future. Until then, I usually connect via SSH from a Raspberry Pi ZeroW(which I connect to via VNC from my phone) to manage my whole setup.
I posted here because I know I am going to run into a lot of bumps along the way, and not know where to turn. So, what better place to come and share my journey.
For all those still following along, this project is FAR from over!
As I mentioned above, I still have more plans for this! In the future, I am going to be getting four more 2.5" HDDs(which I already have slots for in my case), another powered 4-port usb3 hub, 1200 Watt power supply to handle all of the 5v load, bigger fans, 7 Raspberry Pi 4s(4Gb variants, if I don't wait for a new version, in which case I will be temporarily installing three more 3B+s), and an actual desktop case to hide everything in eventually.
Yes, I said seven. My plan is to build a super computer/server using Pis. Because, why not? I'm sure you heard years ago about super computers being built from multiple PS3s somehow connected together. I've spent a lot of time here lately discovering just how that all works with these little Pi computers, and I would like to pull it together myself! Why? The possibilities are endless if you have a properly built computer. I learned that from years of gaming on PCs. Building a super computer of my own opens many more doors for programming and learning even more with these small boards we love so much. The main controller would initially be a Raspberry Pi 3B+, which would later be replaced by a 4 or newer model.
I still have an overall dislike for the Raspberry Pi 4B after realizing most of their updates were minimal and so far, not much of an improvement. The only reason the 4B is good at this point, in my opinion, is because it now has a more capable processor, 2 actual usb3 ports, and true Gb ethernet. While that may enough for most of you, software glitches and an extra 0.1 Ghz of processing power and 3Gb more RAM, in my experience, don't make a practical long term investment opportunity. I would rather wait for an updated model featuring an even faster processor, and still have the same 4Gb of RAM as the 4B(or more???).
If you've made it this far, there are a lot of details I did not get into here. Feel free to keep this thread alive if you have any questions! I am learning this all as I go, as far as the coding and programming, but I'm willing to help anyone with what I've done so far!
RedPanther
Fri Sep 13, 2019 9:49 pm
After having posted this, I set up a Plex server for my household on the Raspberry Pi3B+. While it did great for streaming directly to phones, laptops, and even a Roku, streaming from my phone to Chromecast was another story. The movies were choppy, buffered a lot, and barely played some movies for more than a couple seconds before needing to buffer again.
Lesson learned for running my mouth about an RPi4B not being a good investment.
I decided today to upgrade the main board in my server to the RPi 4 B 4Gb. With everything set up the same as it was on my 3B+, the 4B has not disappointed for running Plex, MiniDLNA, Samba, SSH and VNC on demand at all times. I even tested the same movies on the new system over Plex, and they play considerably longer before needing to buffer with slightly better quality.
I also got another Raspberry 3B+ while I was out today. I figured since I finally have a decently sized server set up, I am ready to work on incorporating my other two Pi’s into the mix, and work on a small distributed computing system.
The goal of this project is to have a fully functioning Linux based desktop environment, home and remote media server, household personal storage(local cloud server with independent user directories, each accessible by only the user assigned), personal smart voice control assistant, and a system more than capable of running intensive tasks in an efficient manner.
The 4B will be the system that calls the tasks to be run, then distribute the task to be processed on the other two boards, and send all output back to the 4B.
Onto the part I’m going to need help the most with, where would I begin with using the 4B as the main system which distributes tasks to my other two 3B+‘s? I don’t want to avoid using all processing and memory from the 4B, so I don’t want a simple SSH connection. I want to build a program on my 4B to help with distributing processes evenly based on task intensity. At some point I would like to have several “clusters” of paired Pi’s, each functioning in parallel, connected to the main board to make an even more powerful distributed system. The idea is to have the main board decide how many “clusters” need to be activated to perform a task.
I’ve rambled a lot here, but if you’re still with me and you’ve been into this sort of thing before, maybe you could help get me along. I’m looking for a starting point at the moment
LTolledo
Re: Raspberry Pi 3B+ Server
Sat Sep 14, 2019 12:34 am
Below is my just completed RPi4B-2G NAS
in ITX case
with 2 x 8TB 3.5" HDDs
ext4 formatted
samba shared
using simple HDD redundancy (instead of RAID)
Raspbian Buster Lite in 8GB microSD
main PSU is a single 12v 5A
12v 50x50x15 fan for HDD/case cooling
picture was taken while copying all files from a 4TB RAID1 NAS.....
will get better image when copying is finished
Some people be like:
RedPanther
Re: Raspberry Pi distributed computer project
Sat Sep 14, 2019 5:26 am
Here is a brief write up on setting up a MiniDLNA media server by me. I hope it’s as easy and painless to follow as possible!
https://www.raspberrypi.org/forums/view ... 4#p1535864
One more is never enough ;)
ejolson
Sun Sep 15, 2019 4:15 am
Yes, Building a super computer of my own opens many more doors for programming and learning even more with these small boards we love so much.
I built a super-cheap cluster using five Pi Zero computers, a Pi B+ and a USB hub. Getting the software to perform a parallel computation is the main difficulty with supercomputers and a Pi cluster provides a remarkable development platform for such code. More information on how I set things up and some sample programs are available in the following thread:
https://www.raspberrypi.org/forums/view ... 9&t=199994
RedPanther
Sun Sep 15, 2019 6:05 am
I’ll have to read this over when I get a chance. I’m in process of doing system upgrades at the moment and figuring out placement for clusters in my case
RedPanther
Mon Sep 16, 2019 4:34 pm
If you've made it this far into my build, I recently went through some system upgrades. Over the weekend I was able to fully rewire a 300W power supply(will get upgraded again when i get more Pi's), upgrade to Raspberry Pi 4B, and finished getting my case together. My case now has enough room for about twelve more Pi's. I still need to add USB ports, power and shutdown switches, and lights for Power, HDD activity, and CPU activity all to the front of the case. I’ll also be adding HDMI, Ethernet, and more USB ports to the back of the case.
ejolson
Tue Sep 17, 2019 4:07 am
It looks like things are coming together. Are you are making your own case? What is the case made of? Is it made from wood? Or is it made with some special type of plastic?
RedPanther
Tue Sep 17, 2019 5:46 am
I am building my own case. I am using flat rolled plastic. Corners are held together with brackets, all inside seams will be sealed, and a side panel will be removable for ease of access
RedPanther
Tue Sep 24, 2019 4:37 pm
UPDATE: Recently found out my wife is pregnant, so I've began using my other Pi's for small projects(video and sound monitoring). I have not stopped working on my main project, but going is a lot slower now. However, I have made some updates to current case to allow for better airflow and temperature control. My main board (4B) runs nearly 24/7 as a PLEX, NFS, Samba, and DLNA occasionally feeding one or two clients at a time (720p governed connection). It also maintains an open Chromium window for Pandora music streaming to my connected stereo system.
80mm fan pulling in, 7-port (6 regular 1 powered) USB 3.0 hub
Bluetooth/wired speaker, 80mm fan pulling in, 120mm fan pulling out, 300W desktop power supply
Pi 4B mounted in rear corner under 80mm fan in front of 120mm fan
This setup has proven to be very effective at keeping my 4B cool. The board idles around 30-35 degrees Celsius, and maintains about 52-59 degrees Celsius under 100% processor load. Without the fans powered on to cool the board, temps quickly rise to about 45-53 at idle.
RedPanther
Tue Sep 24, 2019 4:39 pm
Shot of my 4B running just a bit ago with one PLEX client connected @ 720p and two Chromium windows open
ejolson
Tue Sep 24, 2019 4:50 pm
Congratulations! A couple years ago I wanted a Pi-based baby monitor. However, due to time constraints, we settled on some random add-based app for an Android phone. I'm sure a Pi would have worked better.
Do you think a Pi-based baby monitor will soon become part of this distributed computer project?
RedPanther
Tue Sep 24, 2019 5:08 pm
I am currently holding off on my distributed system to work on a 3B+ based baby monitor that is motion and sound activated. At some point, yes, the functions of this mini project will be incorporated into the distributed system.
I have done a decent amount of digging around, I bought a couple Google AIY voice kits at micro center the other day for $2.99usd each. So I’ve been toying with the idea of adding full motion and sound detection to the distributed project. I would like to use my distributed system (once it’s finished) as an AI hub for a list of purposes.
My current holdbacks: I’m still never to all of this, so I need to learn a lot! I’ve tried using several options I’ve found online to distribute my system to no avail. Google AIY is not open source, so I need to look into other ways of voice control. I’m also going to be incorporating gesture control into this system(when I walk through the door, start the coffee maker, or similar ideas).
I know I may have to code and design my own “AI Assisstant” to properly handle everything over a distributed system, but these are the goals, made simple
RedPanther
Re: Raspberry Pi distributed computer project(UPDATED)
Tue Sep 24, 2019 5:11 pm
I may have to start a new thread for the baby monitor project, but as of current the 3B+ sits in a 4B box (yes, the box it comes in at the store) with a small fan mounted to the front pulling hot air out of the box and a Pi camera sticking out of the top. I still need to add and incorporate the microphone, and find a good way to do live motion and sound detection, while also streaming a live feed to other devices over local and remote networks. The system is currently running on Raspbian Buster, and I've recently debated downgrading to Stretch for more compatibility with programs that make these ideas possible.
EDIT: Here's what the project looks like right now. It will get a nice custom built box case in the coming week or two.
Baby monitor project
Return to “Advanced users”
