model 14
Python in Raspbian Lite treats input() as a number.
Wed Sep 11, 2019 10:16 pm
I have been learning Python on my Windows computer (V 3.7.4). I just started working with Python on my new RPi 4B (V 2.7.16) using Raspbian Lite. The windows version treats a variable input from input() as a string, the version on my Pi treats it as a number. I ran the following code on each version:
n = input() I input 3
m = input() I input 4
print(n + m)
I got 34 from the version on windows and 7 on the Pi.
I would appreciate some help.
Thanks.
joelostinspace
Re: Python in Raspbian Lite treats input() as a number.
Wed Sep 11, 2019 10:52 pm
what do do you get in idle? How do convert types?
>>> n= input()
3
>>> n
'3'
>>> type(n)
I would rather live in a world where my life is surrounded by mystery than a world so small that my mind could comprehend it.
--- Harry Emerson Fosdick
model 14
Wed Sep 11, 2019 11:43 pm
I use Idle on my Windows computer. My results are as you show. n is a str.
For the Pi I get: >>>> n 3, type(n) 'int'
Crazy, huh?
Andyroo
Wed Sep 11, 2019 11:57 pm
Play safe and define the variable first by setting it to 0 before use?
Need Pi spray - these things are breeding in my house...
pcmanbob
Thu Sep 12, 2019 7:49 am
The reason for the difference between python 2 and python 3 is that,
python 2 input() evaluates the input in the execution context in which it is called, so if you enter a number its treated as a number.
python 3 input() was removed and you now only have raw_input() that has been renamed as input(), so now every input is treated as a string.
https://sebastianraschka.com/Articles/2 ... -via-input
hippy
Thu Sep 12, 2019 10:05 am
The simple answer is to use Python 3 on the Pi, then your code will work the same on both.
Use "python3 yourfile.py" rather than "python yourfile.py".
bensimmo
Thu Sep 12, 2019 11:37 am
As above, use Python3.
You fallen on the very very common confusion with having to type python3.
Though take what you have learned with you. If/when you come across Python2 only code.
model 14
Thu Sep 12, 2019 12:18 pm
Thanks for the help. I am now using Python3.
Return to “Python”
