shern
USB-C monitor with Raspberry PI 4
Mon Sep 09, 2019 4:22 pm
Hi.
Bought a PI 4 today, but needed to order the offical power supply from raspberry because my regular usb-c connector didn't work (read about the usb-c issue after I bought it). So while waiting on the power adaptor I was wondering if it is possible to use AOC I1601FWUX monitor with the PI?
The problem is that the power and video from the monitor is a usb-c, and the usb-c on the PI is just for power.
Is there a good solution for this?
Thanks in advance.
Re: USB-C monitor with Raspberry PI 4
Mon Sep 09, 2019 4:51 pm
Hi.
Thanks in advance.
The RPi 4B USB-C connector is Power Input, so not able to power the Monitor or carry a Video Signal:
https://eu.aoc.com/en/monitors/i1601fwux
trejan
Mon Sep 09, 2019 5:11 pm
This monitor uses one of the USB-C alternate modes which changes it to carry DisplayPort so not compatible with the Pi which outputs HDMI. You'd need some kind of HDMI to DisplayPort adapter that understood USB-C negotiation. It won't be cheap if it even exists at all.
Return to “Beginners”
