Sulforaphane
Not able to share files to a portable drive on my Raspberry Pi.
Mon Sep 09, 2019 12:21 pm
I am not able to transfer files from my windows machine to a portable drive connected to my Raspberry Pi on the network through Samba. I am however able to view and read them.
The drive is mounted to /disks/ and has following permissions:
drwxrwxrwx 1 root root 131072 Jan  1  1970 DRIVENAME
Anyone know what's up?
topguy
Re: Not able to share files to a portable drive on my Raspberry Pi.
Mon Sep 09, 2019 12:35 pm
See what "mount" reports, also look at the content of the directory ?
Sulforaphane
Mon Sep 09, 2019 12:36 pm
What is the command for that?
topguy
Mon Sep 09, 2019 1:04 pm
mount
and...
ls -al /disks/DRIVENAME
Sulforaphane
Mon Sep 09, 2019 1:33 pm
mount
and...
Oh! Here is the mount.
/dev/sda3 on /disks/DRIVENAME type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096)
Inside the drive, everything is pretty much listed as "root" except:
drwxr-xr-x 4 pi   pi     4096 Sep  8 19:09  ..
Sulforaphane
Tue Sep 10, 2019 5:47 am
Update:
Apparently it's not a matter of permissions, as I am able to transfer small files.
Only big files give me an issue. I've done some digging, and it seems to be how Debian handles ExFAT drives and allocation.
The drive is ExFAT so I can use it on a Windows device also, but do any of you know a solution to this problem?
Tue Sep 10, 2019 5:51 am
Reformat it as NTFS and install ntfs3g on the Pi. It won't be fast, but it will work.
Unreadable squiggle
Sulforaphane
Tue Sep 10, 2019 7:09 am
Is there any way to make ExFAT work with transferring large files cross-platform?
topguy
Tue Sep 10, 2019 9:37 am
And by large files you mean 4GB+ size files ??
Sulforaphane
Tue Sep 10, 2019 5:53 pm
Also 2 GB
Andyroo
Tue Sep 10, 2019 7:50 pm
exFat should not have an issue with files larger the 4Gb, Fat32 yes but not exFat.
FAT32 tops out with files at 4 GB in size and hard drives that are 8 TB or less.
ExFat is silly with 16EB files and 128PB volumes :roll:
The only box I’ve played with ExFat on (Debian) needed
sudo apt install exfat-utils exfat-fuse
to run - unsure about a Pi...
Sulforaphane
Tue Sep 10, 2019 10:30 pm
Running both. Still having an issue. Gotta wonder what is causing the issue...
