I've recently purchased a Raspberry Pi 4 4GB. Unfortunately I cannot get any video output in any way.
It is definitely not a boot problem, because I enabled SSH and it connects without a problem.
The LEDs don't indicate any problem either.
I tried the HDMI output, both ports (but only HDMI-0 should work anyway), enabled hdmi_safe option, tried config_hdmi_boost with higher values, nothing helped.
I tried the composite video output too, no luck either.
If I take the same SD card out and put it in my Raspberry Pi 2 B+ I get both HDMI and composite video.
I have the latest Raspbian Buster image on the SD card and used apt to update everything to the latest version.
I also tried NOOBS.
Is it possible that I got a faulty unit? Is there a way to test it?
Any idea/help is appreciated.
