RoccoJones
Is the B+ too old for Raspian?
Mon Sep 02, 2019 3:58 pm
I have a B+ and I installed whatever the Raspian was 2 years ago on it so I could use it as an NFS server. I haven't done an apt-get upgrade in a while, so I just did, then I got a bunch of seg faults. I tried fixing this and that, and in the end, I can't even ssh in because it just says "Connection to rpinfs closed." It looks like I'm just going to have to do a reinstall, but is there any point? Is the B+ just too old for this?
Re: Is the B+ too old for Raspian?
Mon Sep 02, 2019 4:14 pm
Get a new SDCard, build Buster on it. Mount your old SDCard in a USB reader on the new system and lift the pieces you need.
Buster has been running on my 2014 B+ since the launch of the 4B.
RaTTuS
Contact: Twitter YouTube
Mon Sep 02, 2019 4:16 pm
another buster vote for my original pi
lsb_release -a ; cat /proc/cpuinfo
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
processor       : 0
model name      : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS        : 947.22
Features        : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 0002
Serial          : 00000000134e058d
Covfefe
RoccoJones
Mon Sep 02, 2019 4:30 pm
Why do I need another SD card? I don't think my old one's been overused (though it would explain a few things. How can I confirm?)
DirkS
Mon Sep 02, 2019 4:47 pm
Only to make it easier to save / retrieve stuff from your old install.
If nothing needs saving then you can just overwrite your old OS
Mon Sep 02, 2019 5:00 pm
It means you can back out the change if it goes wrong or you forget something that's important.
Trashing a running system isn't a good idea.
RoccoJones
Mon Sep 02, 2019 5:50 pm
Ah, well that's what capturing the partitions is for. That doesn't account for the boot sector though, does it?
So, Buster it is. Is there any reason I shouldn't use Buster Lite? Like I said, it's main role is as an NFS server, but I can always install that after, can't I?
Mon Sep 02, 2019 6:03 pm
Boot sector? There is no boot sector for the Pi. There is the MBR/partition table, the /boot partition and the / partition. That is it.
Even the MBR is unused apart from the partition information. No boot code in there at all.
Unreadable squiggle
RoccoJones
Mon Sep 02, 2019 11:11 pm
Oh that's just great! I tried burning a new image, but it keeps booting the old system! So I guess it is worn out. I ran badblokcs and got
Pass completed, 7707648 bad blocks found. (0/0/7707648 errors)
So what I'm trying to say is I guess I need a new SD card, but I'm not sure how to shop for one for a RPi. I've never had to buy one, because the ones I've bought came w/one.
Gavinmc42
Mon Sep 02, 2019 11:48 pm
SD card can be got from anywhere these days.
Supermarkets, office supplies, camera shops, ………...
I usually use 16GB Sandisk A1 or bigger, currently using 128GB on a Pi4
The A1 is the important bit, that means designed for lots of little read/writes.
If you only use it for a server, try PiCore and any old 256-512MB card :D
I find those in old phones/MP3 players, most are SLC, single layer cell flash, they last a bit longer.
I'm dancing on Rainbows.
Tue Sep 03, 2019 7:14 am
Buster Lite is perfect for an NFS server. There's no reason an NFS server would need a desktop.
Unreadable squiggle
RoccoJones
Tue Sep 03, 2019 1:27 pm
Oh, maybe I should point out that the shared files won't be on the SD card. I have an external magnetic drive for that. In fact, considering that the SD card I have didn't last forever, I'm going to be trying to get all the rw parts of the file system on to the HDD.
Oh and my 4-year-old was delighted by your avi, btw :)
Gavinmc42
Wed Sep 04, 2019 7:05 am
I keep the avatar to remind the kid that being called a "Pink Fuffy Unicorn" is NOT being bullied ;)
Talk about over reaction.
Return to “Raspberry Pi OS”
