XueHai8
Pi4B - Power light stays on after shutdown
Sat Aug 24, 2019 6:15 am
One of the niceties of the Pi Zero is that when you shut it down,
sudo shutdown -h now
, it turns all the lights off when its powered down completely: the Red Power light goes out as well. So you KNOW that its really off.
No other Pi models do that, including the new Pi4B.
Just wish it did. Maybe it can be added?
Or its just hardware and can't be changed.
Re: Pi4B - Power light stays on after shutdown
Sat Aug 24, 2019 6:40 am
What Red Power light? The Pi Zero doesn't have a red LED. Only the Green one.
The Power light on all of the other models can be controlled by software (apart from the original Pi A and Pi B where it was hard wired to the power), but I suspect that the GPIO that drives it might revert to an "on" state when the Pi shuts down.
Unreadable squiggle
drgeoff
Sat Aug 24, 2019 7:13 am
No RPi model goes off. They stop running but are still consuming some power. The only way to reduce that power to zero is to remove the power feed.
Sat Aug 24, 2019 7:23 am
https://www.raspberrypi.org/documentati ... /#pi-power
RPi 4B 4GB (SSD Boot)..
