trejan wrote: ↑Fri Aug 23, 2019 7:36 pm
xsw2_2wsx wrote: ↑Fri Aug 23, 2019 6:59 pm
It's also worth noting that the accelerometer makes noises and LED is blinking when rpi is booting up, it stops when it asks for username.
What? Makes noises and has a LED? Is this a flight controller module? The common ADXL345 breakout boards don't have anything that can create a noise or have an LED. You need to link to the specific module you're using.
Also you should be using 3.3V not 5V.
Thanks for your response,
Im actually not sure what exact model is it, its the cheapest i could find. The title says: "ADXL345 3-axis accelerometer - AVR, Arduino, STM32"
and the description is :
Power consumption scales automatically with bandwidth
User-selectable resolution
Single tap / Double tap detection
Activity / Inactivity monitoring
Free-Fall detection
Full resolution, where resolution increases with g range, up to 13-bit resolution at ±16 g (maintaining 4 mg/LSB scale factor in all g ranges)
SPI (3- and 4-wire) and I2C digital interfaces
Flexible interrupt modes mappable to either interrupt pin
Measurement ranges selectable via serial command
Bandwidth selectable via serial command
10,000 g shock survival
Specyfications:
Current: Ultralow as low as 23 µA in measurement mode and 0.1 µA in standby mode at VS = 2.5 V (typical)
Patent pending, embedded memory management system with FIFO technology minimizes host processor load
Supply voltage: 4.0 to 6 VDC
I/O voltage range: 1.7 V to 3.6V
Working temperature: −40°C to +85°C
Size: 3 mm × 5 mm × 1 mm
(end of description)
The seller also states that for the i2c interface to be enabled a CS pin needs to be high, so i hooked it up to 3.3v (same as power).
He also states that I2C address of the device can be changed between 0x1D and 0x53, also with a special pin (SDO).
The LED is clearly there and its clearly the device that makes the noise.
Just to make sure that the accelerometer is making that sound, i disconected power and rebooted pi. No sound, but LED was on for a short period of time. (The CS pin was also disconected, only pins left were ground, SCL and SDA)
Would a picture/recording help?
Thanks again.
