Bobik
RPi 2 B+ reboots on USB drive connect
Wed Aug 21, 2019 10:52 pm
I have a fresh install of current Raspbian on RPi 2 B+.
When I connect or disconnect USB drive formatted to ExFAT it will restart immediately.
Is there a way how to let work with USB drives?
RonR
Re: RPi 2 B+ reboots on USB drive connect
Wed Aug 21, 2019 11:12 pm
Do you have support for exFAT installed?:
apt-get install exfat-fuse exfat-utils
jbudd
Wed Aug 21, 2019 11:41 pm
A USB hard drive? It sounds like the drive demands more power to spin up then your power supply / Pi can supply.
RonR
Thu Aug 22, 2019 12:32 am
Verifying there is adequate power is never a bad idea, but rebooting (assuming restart means reboot) on disconnecting the USB drive doesn't sound like a power supply issue.
Thu Aug 22, 2019 6:10 am
There is no RPi 2B+ please clarify model.
The USB Hard Drive any details ?
Power Supply you are using ?
Retired disgracefully.....
Thu Aug 22, 2019 6:31 am
Connecting a power hungry peripheral like a hard disk while the Pi is running is not recommended. Ideally it should be connected before the Pi is powered on. When the disk starts it will take a lot of power for a short time, which can be a struggle for the power supply and cause the voltage to drop momentarily. This can cause the Pi to crash or restart.
Bobik
Thu Aug 22, 2019 9:30 am
Yes, I was able to read that drive after that enforced restart.
Bobik
Thu Aug 22, 2019 9:33 am
It is small Kensington thumb drive, I doubt it will consume significantly more than SD card.
Btw, it also restarts when I disconnect the drive (after SW unmount).
Bobik
Thu Aug 22, 2019 9:39 am
Thu Aug 22, 2019 9:43 am
No idea what you are trying to convey but does not answer the questions I have asked :?
Bobik
Thu Aug 22, 2019 9:46 am
I have no idea what happened :-)
Sorry for mistake. It has 2011.12 printed on board.
Power adapter is 10W from Apple.
USB drive is some small Kensington thumb flash drive.
Thu Aug 22, 2019 9:52 am
You can't plug a high power USB 2.0 device into a RPi1B (000E) the in-rush current overwhelms the power supply chip on the board and the voltage drop will cause a reboot. It's OK to remove USB devices. That reboot even happens if I connect a USB WiFi dongle or a Wemos while the RPi is running.
You have to plug-in the device before booting. With my Wemos I can unplug the USB-A to microUSB cable from it, insert the USB-A into the RPi then insert the microUSB into the Wemos (the current loss in the cable saves the day).
Things got better with the 2014 (new form factor) B+ onwards which has better USB power management. All five of my RPi1Bs, my original Zero (with a WiFi dongle) and my 2014 A+ exhibit this behaviour.
This is a doctor free zone.
Re: RPi 1B reboots on USB drive connect
Thu Aug 22, 2019 10:09 am
https://www.raspberrypi.org/documentati ... /README.md
So it is not a RPi 2B+ it is a very ancient early RPi 1B, please change the Title, thank you !
https://raspi.tv/wp-content/uploads/201 ... 6_1500.jpg
Last edited by fruitoftheloom on Thu Aug 22, 2019 1:35 pm, edited 1 time in total.
drgeoff
Thu Aug 22, 2019 11:59 am
Has Dougie discovered a new phenomenon? Current getting lost in a cable.
Burngate
Re: RPi 1 reboots on USB drive connect
Thu Aug 22, 2019 5:18 pm
That does explain the problem with disconnection, though, unlike everyone else's explanation.
After all, where can the current that's already flowing go when you disconnect the drive?
