I've been struggling with having FFmpeg run on Pi Zero W, as a newbie I can't say where the root of the problem whether its the compilation configuration of the FFmpeg or maybe the syntax of the command line itself..
The current configuration is:
Raspberry Pi Zero Wireless
Set GPU memory to 256
Running OS:
FFmpeg version and configuration:Linux raspberrypi 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Command to copy 30 seconds clip from the 10 second mark:ffmpeg version N-94582-gd0fa1a58da Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 8 (Raspbian 8.3.0-6+rpi1)
configuration: --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-omx --enable-omx-rpi --enable-nonfree
libavutil 56. 33.100 / 56. 33.100
libavcodec 58. 55.100 / 58. 55.100
libavformat 58. 31.101 / 58. 31.101
libavdevice 58. 9.100 / 58. 9.100
libavfilter 7. 58.100 / 7. 58.100
libswscale 5. 6.100 / 5. 6.100
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
Hyper fast Audio and Video encoder
sudo ffmpeg -ss 00:00:10 -t 00:00:30 -i GOPR2546.MP4 -c:v libx264 -c:a copy out.MP4The result is an empty out.MP4 file... I've tried different configuration but never got it to work.ffmpeg version N-94582-gd0fa1a58da Copyright (c) 2000-2019 the FFmpeg developers
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x210d360] Using non-standard frame rate 59/1
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'GOPR2546.MP4':
Metadata:
major_brand : mp41
minor_version : 538120216
compatible_brands: mp41
creation_time : 2019-08-20T11:09:41.000000Z
firmware : HD7.01.01.80.00
Duration: 00:01:00.84, start: 0.000000, bitrate: 45293 kb/s
Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 45043 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 119.88 tbc (default)
Metadata:
handler_name : GoPro AVC
encoder : GoPro AVC encoder
timecode : 11:20:21:32
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default)
Metadata:
handler_name : GoPro AAC
Stream #0:2(eng): Data: none (tmcd / 0x64636D74) (default)
Metadata:
handler_name : GoPro TCD
Stream #0:3(eng): Data: bin_data (gpmd / 0x646D7067), 41 kb/s (default)
Metadata:
handler_name : GoPro MET
Stream #0:4(eng): Data: none (fdsc / 0x63736466), 13 kb/s (default)
Metadata:
handler_name : GoPro SOS
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
Illegal instruction
the one minute input file i'm using to test can be downloaded here
Thank you all in advance!!
Ram
