joeboy69
How to separate the body of the email in Gmail (like 1 email 1 body)?
Fri Aug 16, 2019 11:43 am
I have been doing a detection system using RPi Zero W. I have done it fully but there are still some minor issues. Could someone help me with the codes (if needed)? I will provide the codes and screenshots here below. Thanks in adv :)
Situation: If the RPi system send mail to Gmail, it seems the body of the email keep on bulking up on the upcoming emails and it makes the email to be so messy with the same sentences again and again. I'm not sure, what to add up with the Python codes.
Code:
mail['From'] = fromaddr
mail['To'] = toaddr
mail['Subject'] = "[Intruder Alert] Motion Detected!"
body = "Who is the Intruder? Find the attachment for the Intruder's picture!"
Code:
def sendMail(data):
    mail.attach(MIMEText(body, 'plain'))
    print (data)
    # open the file to be sent
    dat = '%s.jpg' %data
    print (dat)
    attachment = open(dat, 'rb')
    # instance of MIMEBase and named as p
    p = MIMEBase('application', 'octet-stream')
    # To change the payload into encoded form
    p.set_payload(attachment.read())
    attachment.close()
    # encode into base64
    encoders.encode_base64(p)
    p.add_header('Content-Disposition', "attachment; filename= %s" %dat)
    # attach the instance 'p' to instance 'mail'
    mail.attach(p)
    server = smtplib.SMTP('smtp.gmail.com', 587)
    server.starttls()
    server.login(fromaddr, "-password-")
    text = mail.as_string()
    server.sendmail(fromaddr, toaddr, text)
    server.quit()
Gmail screenshot (the congested body):
pcmanbob
Re: How to separate the body of the email in Gmail (like 1 email 1 body)?
Fri Aug 16, 2019 12:20 pm
As you have not shown us your compete code its hard to say what the problem might be.
So here is an example of a working python program that sends an email each time on of my pi's boots
import time
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
import subprocess
def send_email(subject,body,email_send):
    email_user = "[email protected]"
    email_password = "xxxxxxxxxx"
    msg = MIMEMultipart()
    msg["From"] = email_user
    msg["To"] = email_send
    msg["Subject"] = subject
    msg.attach(MIMEText(body,"plain"))
    text = msg.as_string()
    server = smtplib.SMTP("smtp.gmail.com",587)
    server.starttls()
    server.login(email_user,email_password)
    server.sendmail(email_user,email_send,text)
    server.quit()
subject = "Garage Pi IP"
p = subprocess.Popen("hostname -I", stdout=subprocess.PIPE, shell=True)
(output, err) = p.communicate()
status = p.wait()
data = str(output)
result = data.split("'")
data = result[1]
result = data.split(" ")
body = "Garage temperature Pi Just Booted \n" + time.strftime("%a %b %d %Y %H:%M:%S") + " \n IP : " + result[0]
email_send = "send [email protected]"
all email address/passwords removed.
also look at this which has some code to send image as attachment . https://stackoverflow.com/questions/130 ... ing-python
joeboy69
Fri Aug 16, 2019 2:11 pm
@pcmanbob bro, here i provide my whole codings. please have a check.
import RPi.GPIO as gpio
import picamera
import time
import telepot
from subprocess import call
import glob
import os
import smtplib
from email.mime.base import MIMEBase
from email import encoders
from email.mime.image import MIMEImage
fromaddr = "email1gmail.com"    # change the email address accordingly
toaddr = "[email protected]"
mail = MIMEMultipart()
mail['To'] = toaddr
pir=4
#HIGH=1
#LOW=0
gpio.setwarnings(False)
gpio.setmode(gpio.BCM)
gpio.setup(pir, gpio.IN, gpio.PUD_DOWN)            # initialize GPIO Pin as input
data=""
previous_state = False
current_state = False
chat_id = -1
token = "token"
bot = telepot.Bot('api-token')
print (bot.getMe())
def sendMail(data):
    print (data)
    print (dat)
    attachment.close()
    mail.attach(p)
    server.starttls()
    server.quit()
def capture_image():
    data= time.strftime("%d_%b_%Y_%H_%M_%S")
    camera.start_preview()
    #time.sleep(5)
    print (data)
    camera.capture('%s.jpg'%data)
    camera.stop_preview()
    #time.sleep(1)
    sendMail(data)
    newest = max(glob.iglob('*.jpg'), key=os.path.getctime)
    bot.sendMessage(chat_id=enter chat id, text="[Intruder Alert] Motion Detected 5 seconds ago!")
    bot.sendPhoto(chat_id=enter chat id, photo=open('/home/pi/Desktop/New/%s'%newest,'rb'), caption="Here's the intruder's picture!")
camera = picamera.PiCamera()
camera.rotation=360
camera.awb_mode= 'auto'
camera.brightness=65
while True:
    time.sleep(1)
    previous_state = current_state
    current_state = gpio.input(pir)
    #print("Current State : %s" % current_state)
    if current_state != previous_state:
        new_state = "ACTIVATED" if current_state else "DEACTIVATED"
        print("SENSOR %s is %s" % (pir, new_state))
        if new_state == "ACTIVATED":
            print("Detected Activity")
            capture_image()
pcmanbob
Fri Aug 16, 2019 3:50 pm
If you compare my program and your program you don't actually pass the body , to or from email address or subject lines to the sendmail function .
anything that is defined in the main program that you want to use in a function has to be passed to the function when its called.
So in my program you can see I pass the subject,body and email_send variables when I call the function using the line
either that or you need to include all these variables in the function as shown in the example I linked to.
the answer is there which every way you decide to do it you just need to read and compare the examples to your code.
ghp
Fri Aug 16, 2019 6:08 pm
Hello, the problem with the growing text could be that the mail object is build in main code once, and in sending the mail some text is attached each time.
mail['To'] = toaddr
def sendMail(data):
Think that moving the object creation into the sendMail function will result in a fresh object used each time.
def sendMail(data):
    mail['To'] = toaddr
Return to “Python”
