[email protected]:~ $ sudo apt-get update
Err:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out
Err:2 http://archive.raspberrypi.org/debian buster InRelease
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:5). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:5). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:9). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:7). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:6). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:6). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:7). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:88:26::1). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:8). - connect (101: Network is unreachable) Could not connect to archive.raspberrypi.org:80 (93.93.135.188), connection timed out Could not connect to archive.raspberrypi.org:80 (46.235.227.11), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.214), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.39), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.230), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.104), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.211), connection timed out Could not connect to archive.raspberrypi.org:80 (46.235.231.111), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.133), connection timed out
Reading package lists... Done
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/buster/InRelease Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:5). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:5). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:9). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:7). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:6). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:82:1000:13:0:6). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:7). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:88:26::1). - connect (101: Network is unreachable) Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:0:80:1000:13:0:8). - connect (101: Network is unreachable) Could not connect to archive.raspberrypi.org:80 (93.93.135.188), connection timed out Could not connect to archive.raspberrypi.org:80 (46.235.227.11), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.214), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.39), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.230), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.130.104), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.211), connection timed out Could not connect to archive.raspberrypi.org:80 (46.235.231.111), connection timed out Could not connect to archive.raspberrypi.org:80 (93.93.128.133), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Even ping is working properly.
