rlx
Pi NOIR Camera Tinted Images
Mon Aug 12, 2019 9:10 pm
Hello everybody,
I have a Raspberry Pi 3 with a NOIR camera which I use as an amateur surveillance system (with MotionEye) when I am away on longer trips.
Everything worked quite OK for some time, but the last time I was away for the weekend, I was seeing images through the live video feed which looked like the screenshot below.
The color flickers between red, pink, then normal again.
Has anyone seen this?
Do I need to replace my camera?
Appreciate any help :)
Screenshot 2019-08-12 at 23.00.17.png (200.39 KiB) Viewed 321 times
itsmedoofer
Re: Pi NOIR Camera Tinted Images
Mon Aug 12, 2019 11:13 pm
It could be that the ribbon is not seated properly I see the same from time to time, seems to happen even if the camera is static. A disconnect and wipe of the pads fixes it.
6by9
Tue Aug 13, 2019 7:59 am
https://www.raspberrypi.org/forums/view ... 3&t=245994
(it's even a sticky at the top of this forum!)
rlx
Tue Aug 13, 2019 7:44 pm
Thanks for the hint!
Now the problem is, I am not calling 'raspistill' directly, I have MotionEye installed, which probably uses raspistill (or a Python package that does, since it's written in Python, as far as I am aware).
Is there any systemwide config file for globally setting that parameter for raspistill?
Sorry, if these are stupid questions, but I am not that deep into every Pi detail.
Andyroo
Tue Aug 13, 2019 7:55 pm
You could try https://github.com/raspberrypi/firmware ... -508256302
If you are stuck on Systemd a quick Google will show you what to do.
Need Pi spray - these things are breeding in my house...
rlx
Thu Aug 15, 2019 7:49 am
Awesome, thank you so much! :)
Return to “Camera board”
