s710
Issues with thd remote control on raspbian buster
Mon Aug 12, 2019 8:21 pm
I was using my remote control previously on my raspbian stretch installation, however, after a fresh installation of raspbian buster it no longer seems to work. When plugging the USB dongle I see this in /var/log/syslog:
Aug 12 21:14:41 homepi kernel: [453391.757980] usb 1-1.2: new full-speed USB device number 7 using xhci_hcd
Aug 12 21:14:41 homepi kernel: [453391.893813] usb 1-1.2: New USB device found, idVendor=1915, idProduct=1001, bcdDevice= 1.00
Aug 12 21:14:41 homepi kernel: [453391.893842] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 12 21:14:41 homepi kernel: [453391.893855] usb 1-1.2: Product: Smart Control
Aug 12 21:14:41 homepi kernel: [453391.893867] usb 1-1.2: Manufacturer: 123 COM
Aug 12 21:14:41 homepi kernel: [453391.904141] input: 123 COM Smart Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:1915:1001.0007/input/input8
Aug 12 21:14:41 homepi kernel: [453391.969052] hid-generic 0003:1915:1001.0007: input,hidraw0: USB HID v1.01 Keyboard [123 COM Smart Control] on usb-0000:01:00.0-1.2/input0
Aug 12 21:14:41 homepi kernel: [453391.973925] input: 123 COM Smart Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:1915:1001.0008/input/input9
Aug 12 21:14:41 homepi kernel: [453391.974406] hid-generic 0003:1915:1001.0008: input,hidraw1: USB HID v1.01 Mouse [123 COM Smart Control] on usb-0000:01:00.0-1.2/input1
Aug 12 21:14:41 homepi kernel: [453391.980351] input: 123 COM Smart Control Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:1915:1001.0009/input/input10
Aug 12 21:14:41 homepi kernel: [453392.048347] input: 123 COM Smart Control System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:1915:1001.0009/input/input11
Aug 12 21:14:41 homepi kernel: [453392.048668] hid-generic 0003:1915:1001.0009: input,hidraw2: USB HID v1.01 Device [123 COM Smart Control] on usb-0000:01:00.0-1.2/input2
Aug 12 21:14:41 homepi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Aug 12 21:14:41 homepi mtp-probe: bus: 1, device: 7 was not an MTP device
Aug 12 21:14:42 homepi systemd-udevd[27110]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 12 21:14:42 homepi systemd-udevd[27149]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 12 21:14:42 homepi systemd-udevd[27146]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 12 21:14:42 homepi systemd-udevd[27143]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 12 21:14:42 homepi systemd-udevd[27147]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 12 21:14:42 homepi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Aug 12 21:14:42 homepi mtp-probe: bus: 1, device: 7 was not an MTP device
Could someone help me out to get this to work again?
I also tried:
pi@homepi:~ $ th-cmd --socket /var/run/triggerhappy.socket --add /dev/input/event0
send_command: Transport endpoint is not connected
pi@homepi:~ $ th-cmd --socket /var/run/triggerhappy.socket --add /dev/input/event1
pi@homepi:~ $ th-cmd --socket /var/run/triggerhappy.socket --add /dev/input/event2
pi@homepi:~ $ th-cmd --socket /var/run/triggerhappy.socket --add /dev/input/event3
Without success.
