dpawson
rpi 4 + sense hat, mechanical assembly
Mon Aug 12, 2019 11:55 am
Hearing of the heat issues I added a fan. 5V using usb.
Which necessitated stand offs, and ribbon cable.
Which meant a mounting system (styrene, 2mm).
Result is not pretty. It runs cool and works. Ribbon is M-F, oddly the connectors
don't fit in between the stand offs - pcb holes too tight (Eben?).
https://drive.google.com/open?id=1HxpJT ... mY3tTszmX shows the ribbon path
which makes the bodge even worse.
pcmanbob
Re: rpi 4 + sense hat, mechanical assembly
Mon Aug 12, 2019 1:06 pm
Looking at your picture if you turned both plugs round the cable would come out on the outside, you could then dismantle one of the plugs and shorten the cable so as to reduce the spare cable left hanging out side the pi.
the cable would then follow the path shown by the yellow line
dpawson
Mon Aug 12, 2019 3:27 pm
Let me stare at the picture.... then make notes....
then try it :-)
Took me ages to figure out pin 1 to pin 1
Tks for the suggestion (pass it on to @rpi?)
dpawson
Mon Aug 12, 2019 5:39 pm
Yep, that worked.
https://flic.kr/s/aHsmG4HTF1
Once I'd got my head around the 180 shift :-)
Much neater.
