roadrunner35
install gawk on raspbian
Sat Aug 10, 2019 1:48 pm
Hi ther I'm a new user to this forumalbeit not new to linux , used to be an unix admin prior to having a stroke I'm trying to install gawk on my Raspberry pi 4B+ (OSis raspbian stretch) and I do the following steps:
-sudo apt-get update
- sudo apt -get upgrade
and finally:
-sudo apt install gawk with the following result:
Reading package lists... Done
Building dependency tree
Package gawk is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'gawk' has no installation candidate
I have managed to find and down load the following"package":
gawk_4.1.4+dfsg-1_armhf.deb
and have tried:
$sudo dpkg -i ./gawk_4.1.4+dfsg-1_armhf.deb with the following result:
regarding ./gawk_4.1.4+dfsg-1_armhf.deb containing gawk, pre-dependency problem:
gawk pre-depends on libsigsegv2 (>= 2.9)
libsigsegv2 is not installed.
dpkg: error processing archive ./gawk_4.1.4+dfsg-1_armhf.deb (--install):
pre-dependency problem - not installing gawk
and it seems that apt cannot find the libsigsegv2 either, so I am at a complete loss here, all help will be greatly appreciated
jbudd
Re: install gawk on raspbian
Sat Aug 10, 2019 2:05 pm
My Pi 3B with stretch already has gawk but I tried uninstalling and reinstalling it and libsigsegv2 - no problem.
On my Pi 4B (buster) sudo apt-get install gawk worked too.
Edit - The Pi does come with awk
$ ls -l /etc/alternatives/awk
lrwxrwxrwx 1 root root 13 Jun 20 17:42 /etc/alternatives/awk -> /usr/bin/mawk
Mawk is a cut down version of awk. Do you have scripts that don't work with mawk?
Sat Aug 10, 2019 2:15 pm
Confused
There is no 4B+ Raspberry Pi ??
Raspbian Stretch only supports up to 3A+ / 3B+ / CM3+
RPi 4B 4GB (SSD Boot)..
roadrunner35
Sat Aug 10, 2019 2:40 pm
Sorry, my bad it is a 3B+ with stretch, but problem still persists with installing gawk
awk,nawk and mawk are installed on my system, but no gawk and I really want the new features of gawk, so std. awk does not work for methe damn stroke does quite often make me being not too accurate like stating 4B+ instead of 3B+problem is that I've just just been reading about the 4B, so that's the first that comes to my fingertips aty the keyboard. Can any one suggest how to make apt be able to locate and install gawk:
pi@raspberrypi:~ $ apt search gawk
Sorting... Done
Full Text Search... Done
mawk/now 1.3.3-17 armhf [installed,local]
a pattern scanning and text processing language
pi@raspberrypi:~ $
----- so apt seems to find awk and not gawk
-I have managed to pull a binary file out of the .deb file (Don't ask me how I did it, can't remember, but invoking it gives the following result:
:~/Downloads/usr/bin $ ./gawk
./gawk: error while loading shared libraries: libsigsegv.so.2: cannot open shared object file: No such file or directory
pi@raspberrypi:~/Downloads/usr/bin $
jbudd
Sat Aug 10, 2019 2:58 pm
This is what I get on Stretch:
The following additional packages will be installed:
libsigsegv2
Suggested packages:
gawk-doc
gawk libsigsegv2
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 536 kB of archives.
After this operation, 2,154 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive-bm.raspbian.org/raspbian stretch/main armhf libsigsegv2 armhf 2.10-5 [28.4 kB]
Get:2 http://archive-bm.raspbian.org/raspbian stretch/main armhf gawk armhf 1:4.1.4+dfsg-1 [508 kB]
You say you ran sudo apt-get update.
Maybe you have something unusual in /etc/apt/sources.list?
klricks
Sat Aug 10, 2019 3:09 pm
I had no problem installing gawk on 3B+ Raspbian Buster.
Ernst
Sat Aug 10, 2019 3:34 pm
I had no problem installing gawk on 3B Raspbian Stretch.
pi@raspis:~ $ gawk
-bash: gawk: command not found
pi@raspis:~ $ sudo apt install gawk
Suggested packages:
  gawk-doc
  gawk
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 508 kB of archives.
After this operation, 2,104 kB of additional disk space will be used.
Get:1 http://debian.bio.lmu.de/raspbian/raspbian stretch/main armhf gawk armhf 1:4.1.4+dfsg-1 [508 kB]
Fetched 508 kB in 0s (594 kB/s)
Selecting previously unselected package gawk.
(Reading database ... 36694 files and directories currently installed.)
Preparing to unpack .../gawk_1%3a4.1.4+dfsg-1_armhf.deb ...
Unpacking gawk (1:4.1.4+dfsg-1) ...
Setting up gawk (1:4.1.4+dfsg-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
pi@raspis:~ $
The road to insanity is paved with static ip addresses
scruss
Sat Aug 10, 2019 4:22 pm
sudo apt update
sudo apt install libsigsegv2
should fix it unless something else is not right with your system.
I went back to a very old system running Jessie, and the installation process worked.
mawk's a full implementation and quite fast, too. gawk handles UTF-8 better: by no means well, but better than other awk interpreters.
Pronouns: he/him
roadrunner35
Sat Aug 10, 2019 4:54 pm
SOLVED: yup there was a problem with /etc/apt/sources.list I have at some point tried to install vscode and I think that have messed things upI had another SD card with an old Stretch installation, so I just copied the Sources.list from that
so now gawk invokes as expected Thankyou for the Hint , I would never have figured this out without your help:
pi@raspberrypi:/etc/apt $ gawk -W v
GNU Awk 4.1.4, API: 1.1 (GNU MPFR 3.1.5, GNU MP 6.1.2)
Copyright (C) 1989, 1991-2016 Free Software Foundation.
Return to “Beginners”
