kasek
Fan shim and case question
Sat Aug 10, 2019 8:35 am
Hey was thinking of getting the fan shim and have already ordered the smraza case: https://www.amazon.ca/gp/product/B07TX9 ... 42FQ&psc=1
I know the fan can mount to the fan whole will the fan shim pcb board fit with this case anyone know? I'm aware ill need to slightly modify the case to access the switch if i want it
gordon77
Re: Fan shim and case question
Sat Aug 10, 2019 2:30 pm
If you are thinking about this fan shim https://shop.pimoroni.com/products/fan- ... xoQAvD_BwE then it MAY fit if the case has similar clearance to the Pibow one shown.
Note the clearance in the pic below where the fan shim pcb fits.
kasek
Sat Aug 10, 2019 4:15 pm
thanks for the response, it seems like it might because the case looks similar to that one, only difference is accessing the switch if i wanted to but small modification should fix that
