, over /dev/hidraw1 i see some buffer data coming when scanned but getting below error
#!/usr/bin/python
import sys
import requests
import json
api_key = "" # https://upcdatabase.org/
def barcode_reader():
print('from barcode reader')
"""Barcode code obtained from 'brechmos'
https://www.raspberrypi.org/forums/viewtopic.php?f=45&t=55100"""
hid = {4: 'a', 5: 'b', 6: 'c', 7: 'd', 8: 'e', 9: 'f', 10: 'g', 11: 'h', 12: 'i', 13: 'j', 14: 'k', 15: 'l',
16: 'm',
17: 'n', 18: 'o', 19: 'p', 20: 'q', 21: 'r', 22: 's', 23: 't', 24: 'u', 25: 'v', 26: 'w', 27: 'x', 28: 'y',
29: 'z', 30: '1', 31: '2', 32: '3', 33: '4', 34: '5', 35: '6', 36: '7', 37: '8', 38: '9', 39: '0', 44: ' ',
45: '-', 46: '=', 47: '[', 48: ']', 49: '\\', 51: ';', 52: '\'', 53: '~', 54: ',', 55: '.', 56: '/'}
hid2 = {4: 'A', 5: 'B', 6: 'C', 7: 'D', 8: 'E', 9: 'F', 10: 'G', 11: 'H', 12: 'I', 13: 'J', 14: 'K', 15: 'L',
16: 'M',
17: 'N', 18: 'O', 19: 'P', 20: 'Q', 21: 'R', 22: 'S', 23: 'T', 24: 'U', 25: 'V', 26: 'W', 27: 'X', 28: 'Y',
29: 'Z', 30: '!', 31: '@', 32: '#', 33: '$', 34: '%', 35: '^', 36: '&', 37: '*', 38: '(', 39: ')', 44: ' ',
45: '_', 46: '+', 47: '{', 48: '}', 49: '|', 51: ':', 52: '"', 53: '~', 54: '<', 55: '>', 56: '?'}
fp = open('/dev/hidraw1', 'rb')
#fp = open('/dev/ttyUSB0', 'rb')
#print(fp)
ss = ""
shift = False
done = False
while not done:
## Get the character from the HID
buffer = fp.read(8)
print(buffer)
for c in buffer:
print(c)
print(" ".join("{:02X}".format(c) for c in buffer))
if ord(c) > 0:
print(ord(c))
## 40 is carriage return which signifies
## we are done looking for characters
if int(ord(c)) == 40:
done = True
break;
## If we are shifted then we have to
## use the hid2 characters.
if shift:
## If it is a '2' then it is the shift key
if int(ord(c)) == 2:
shift = True
## if not a 2 then lookup the mapping
else:
ss += hid2[int(ord(c))]
shift = False
## If we are not shifted then use
## the hid characters
else:
shift = True
else:
ss += hid[int(ord(c))]
return ss
def UPC_lookup(api_key, upc):
'''V3 API'''
print(upc)
# url = "https://api.upcdatabase.org/product/%s/%s" % (upc, api_key)
# headers = {
# 'cache-control': "no-cache",
# response = requests.request("GET", url, headers=headers)
# print("-----" * 5)
# print(upc)
# print(json.dumps(response.json(), indent=2))
# print("-----" * 5 + "\n")
if __name__ == '__main__':
try:
while True:
#print('hi')
UPC_lookup(api_key, barcode_reader())
except KeyboardInterrupt:
pass
