Hello, I have a problem with the usb scanner. When I connect the scanner when raspberry is already running, everything works, I can read from the file / dev / hidraw0. However, when the scanner is connected during startup, no /dev/hidraw* file appears ... What can I do to make raspberry scan the device again.
PS The script is written in python and the os is Raspbian Buster
Can anyone help?
