Thank you, I'll investigate this. Side note, is a pi zero powerful enough to process the snips engine?Andyroo wrote: ↑Wed Aug 07, 2019 2:27 pmApologies - link is https://docs.snips.ai/getting-started/q ... spberry-pi
Probably not as they recommend a RPi 3. I was thinking of doing the processing somewhere else with the RPi Zero in each room but if your budget stretches to having a 3/3+/4 in each room then that'd probably be the best solution.
