tuadru
Problems with flashing img on SD card
Tue Aug 06, 2019 10:48 am
Im trying to flash my custom android things image to sd card so I can boot it on raspberry pi 3 later and I am using android things setup utility to do so. The error occurs at validating, it comes to 100% and after that it shows this error:
Validation error
Error: error running etcher-cli: error running Ethcer-cli: exit status 2
Stopping adb server...
Stopped adb server...
Ive tried with different sd card and default image that is given as an option in the console but still the same error persists.
Does anyone know what this could be about?
pcmanbob
Re: Problems with flashing img on SD card
Tue Aug 06, 2019 9:30 pm
A quick web search found the following error codes
Exit codes:
0 - Success
1 - General Error
2 - Validation Error
3 - Cancelled
So I guess you have a validation error.
Return to “Android”
