poker
raspberry pi zero w no camera preview on tv out pin (composit)
Mon Aug 05, 2019 12:53 pm
Hi
I connected a v2 camera to my Raspberry pi zero w and i can see camera preview with hdmi port but when i connect my Raspberry with tv out pin I can't see camera preview with raspivid command and python script using picamera .
What should I do?
Please help.
Re: raspberry pi zero w no camera preview on tv out pin (composit)
Mon Aug 05, 2019 2:21 pm
Hi
What should I do?
Please help.
Is this how you achieved Composite Output ?
https://thepihut.com/blogs/raspberry-pi ... ry-pi-zero
Retired disgracefully.....
6by9
Mon Aug 05, 2019 2:36 pm
You've disconnected the HDMI display, and have the console/GUI visible on the composite out?
The Pi0 will only put the console/GUI on one display at a time, and HDMI and TV out are mutually exclusive.
If the console/GUI is on the composite out, then raspivid's preview should follow that.
poker
Mon Aug 05, 2019 4:24 pm
Hi
What should I do?
Please help.
Yes i achieved Composite Output fully like this
poker
Mon Aug 05, 2019 5:18 pm
yes i have a visible console on composite
but i cant see camera preview on composite if i remove composite and connect hdmi i can see camera preview
it seems that raspbian only render camera to hdmi port is it true?
and how i can change this ?
SanderV2
Wed Sep 18, 2019 10:07 am
Hi All,
I am experincing the exact same issue. I did find a post of someone who seems to have got it working, but it didn't work for me. See link below.
https://hackaday.io/project/12450-raspb ... escription
Did you get it working by any chance?
SanderV2
Wed Sep 18, 2019 2:03 pm
Small update.
I downgraded to Raspbian Stretch and there it works like a charm. So it seems to be an issue with Raspbian Buster.
I have no idea how to solve this so I will stick to Stretch for now.
6by9
Wed Sep 18, 2019 2:14 pm
This is most likely to be something having changed in the firmware, but it would help if you could identify roughly where/when.
- Backup your SD card in case things go bad
- Use "sudo rpi-update" to update your Stretch install to the latest firmware and kernel.
- Reboot.
- Does that fail?
If it does then use "sudo rpi-update <hash>" where <hash> is a commit ID from https://github.com/Hexxeh/rpi-firmware/commits/master to downgrade to an older firmware.
Report back roughly where things change from working to not working.
(The fastest way to go about this is to jump back 20 or so versions at a time. When it starts working, then come forward 10 versions. Depending on whether that works go back or forward 5 commits. Within not very many tests you'll have found where the breakage actually happens).
HermannSW
Wed Sep 18, 2019 2:39 pm
..., but it would help if you could identify roughly where/when.
- Reboot.
- Does that fail?
Thanks for that problem identification procedure -- this information would be good to have in a new pinned thread, perhaps in Troubleshooting forum ...
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://twitter.com/HermannSW
SanderV2
Tue Oct 01, 2019 8:27 am
Updated to the latest version of Stretch and it works like it should. Seems to be an issues specific to Buster.
6by9
Tue Oct 01, 2019 10:01 am
Stretch is no longer being updated, therefore it will be on an old kernel and firmware. Use "vcgencmd version" and "uname -a" to confirm.
Run "sudo rpi-update" on your Stretch install and you will get the latest kernel and firmware. I suspect you'll get the same issue there.
It is highly unlikely to be anything to do with Buster per se.
As requested in the previous instructions, please use rpi-update with a commit hash to identify roughly when things start failing. Engineering time to investigate any issues is in short supply, so if you've done some of the detective work, then we can get to the bottom of the issue far faster.
SanderV2
Wed Oct 02, 2019 4:05 pm
This is exactly what I did and the issue still did not occur.
I will run these commands tomorrow and inform you on the results
SanderV2
Thu Oct 03, 2019 12:35 pm
Below is the terminal after running the commands that were mentioned.
[email protected]:~ $ vcgencmd version
Sep 24 2019 17:39:25
Copyright (c) 2012 Broadcom
version 6820edeee4ef3891b95fc01cf02a7abd7ca52f17 (clean) (release) (start_x)
[email protected]:~ $  uname -a
Linux raspberrypi 4.19.75+ #1270 Tue Sep 24 18:38:54 BST 2019 armv61 GNU/Linux
6by9
Thu Oct 03, 2019 2:22 pm
I don't have a Pi0 with composite header wired in to hand, but testing on a Pi3 with Buster it is working fine.
If you can SSH in, then run raspistill, and whilst it is running run "vcgencmd dispmanx_list" to dump out the list of elements that are on the display. For me with composite connected I get
[email protected]:~ $ vcgencmd dispmanx_list
display:3 format:RGB565 transform:0 layer:-127 720x480 src:0,0,720,480 dst:0,0,720,480 cost:389 lbm:0
display:3 format:YUV420 transform:0 layer:2 1024x768 src:0,0,1024,768 dst:40,0,640,480 cost:1232 lbm:10240
The RGB565 layer is the frame buffer, and the YUV420 layer is the preview window. The fact that they are tagged as "display=3" means they are on the composite output. HDMI would be display=2, and DPI or DSI would be display=0.
CarstenT
Fri Nov 08, 2019 5:59 pm
For what it's worth, I lost the preview after having seen it the first couple of times. The camera sits on a rpi 4b (two hdmi out?) and goes to a fairly new tv with hdmi in. The tv has multible options that somewhat fooled the screen-setup, but that's ok now. I could have got the preview before updating buster, but I'm not sure. I havn't been at this problem for long so just this as an add-on to this thread.
HermannSW
Fri Nov 08, 2019 8:06 pm
From a 6by9 hint in another thread, HDMI1 is 7:
https://www.raspberrypi.org/forums/view ... 4#p1545341
0 = DSI/DPI LCD
2 = HDMI0
3 = SDTV
7 = HDMI1
Return to “Camera board”
