I want to use my new pi 4 as my home automation platform, and it shall replace my existing model 3b, which is running everything fine already. I need to plug 3 USB sticks: Z-Wave, zigbee & a receiver for a remote control. In addition, I attached the hifiberry DAC+DSP HAT (https://www.hifiberry.com/blog/announcing-the-dac-dsp/).
Now I've already reinstalled the pi4 like 3 times, fearing that something on the way of the installation went wrong, but I always end up with the pi4 disconnecting after some random time. The LEDs on the LAN port will go off, and the pi4 will become unreachable. I can only fix this by pulling the power cable and plugging it again. The pi4 will work again afterwards, until it eventually dies again some time.
Compared to the pi3, which is running raspbian stretch, I am running raspbian buster on the pi4. That might be the only difference. The rest of the installed software should be the same.
I have no clue how I could find out what is causing this, and I am afraid that the board might be broken. Or could it maybe be the power supply? I've got this one: https://www.reichelt.de/raspberry-pi-ne ... dr::259919
And once thing to note, I also tried to plug the USB-C power cable of my MacBook, however the pi4 didn't even start (LED also off). Shouldn't all USB-C cables be compatible in this regard? Or did I damage the pi4 by plugging my MacBook power supply?
