yogawenno
problem connect epsolar-tracer to raspberry pi
Thu Aug 01, 2019 3:39 pm
hey guys, please help me to solve this problem
i have code
from pymodbus.client.sync import ModbusSerialClient as ModbusClient
client = ModbusClient(method = 'rtu', port = '/dev/ttyACM0', baudrate = 115200)
client.connect()
result = client.read_input_registers(0x3100,1,unit=1)
print("result = ")
print (result)
solarVoltage = float(result.registers[0] /100.0)
solarCurrent = float(result.registers[1] /100.0)
batteryVoltage = float(result.registers[4] /100.0)
chargeCurrent = float(result.registers[5] /100.0)
print("solar voltage : ",solarVoltage)
print("solar current : ",solarCurrent)
print("battery volatage : ",batteryVoltage)
print("charge current : ",chargeCurrent)
client.close()
when i run this code, i get error like this
result =
Modbus Error: [Input/Output] Modbus Error: [Invalid Message] Incomplete message received, expected at least 2 bytes (0 received)
File "yutub.py", line 9, in
AttributeError: 'ModbusIOException' object has no attribute 'registers'
i use rasberry pi 3 model b and epever tracer1210A
can anybody can help me to fix this problem?
thanks !
ghp
Re: problem connect epsolar-tracer to raspberry pi
Thu Aug 01, 2019 5:26 pm
There are various options listed how to connect this device. How do you connect ?
Found https://www.epsolarpv.com/upload/cert/f ... L-V1.0.pdf, page 22. Or is there a better documentation available ?
yogawenno
Fri Aug 02, 2019 2:34 pm
i use this cable https://www.tokopedia.com/snapshot_prod ... =537423544 to connect mppt to raspberry pi
I've tried it on software called "solar station monitor" on windows, and it works fine. all data from mppt is displayed there correctly.
now i want to try it on raspberry pi and get that problem
ghp
Fri Aug 02, 2019 3:20 pm
Can't access this link, there seems to be a password needed.
If you can connect to windows, then it is most possibly USB based.
The USB serial adapter in Linux usually are named /dev/ttyUSB0. Connect the device and in a terminal, check command
ls /dev/ttyUSB*
. Then in your code change /dev/ttyACM0 into /dev/ttyUSB0
yogawenno
Fri Aug 02, 2019 4:24 pm
ls /dev/ttyUSB*
on raspberry pi has not detected /dev/ttyUSB0 directory. there is only /dev/ttyACM0. is that a problem?
this is my rs485 to usb converter
rs485 to usb converter.png (214.29 KiB) Viewed 2760 times
ghp
Fri Aug 02, 2019 5:01 pm
Hmm, nice looking cable. Assume in windows device manager, Serial connections, there is a 'COM'-device visible.
On pi, unplug cable, wait a few secs, then do a " ls /dev/tty* ". Plug in cable, wait few secs, and do again " ls /dev/tty* ". Differences ?
If no differences, the cable has no appropriate driver in linux.
If a new device shows up: this is the name to use.
yogawenno
Fri Aug 02, 2019 11:32 pm
when i plug the cabble it looks /dev/ttyACM0 that didn't exist before. When I try on Windows, there is a driver(xr21v1410) that must be installed to read the 'COM' port that is already connected with mppt
Is that also needed when use raspberry Pi?
ghp
Sat Aug 03, 2019 7:01 am
Hello, the /dev/ttyACM0 is available on my system too.
With 'lsusb', you find out some more details about vendorid, productid of usb devices. Here the partial output on a system with an arduino uno and a common FTDI chip
Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 005: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)
With vendorID, productID you can check if drivers are available.
yogawenno
Sun Aug 04, 2019 3:06 pm
this is a vendorid list from my raspi
Bus 001 Device 005: ID 1a2c:407e China Resource Semico Co., Ltd
Bus 001 Device 004: ID 10c4:8108 Cygnal Integrated Products, Inc.
Bus 001 Device 006: ID 04e2:1411 Exar Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 006: ID 04e2:1411 Exar Corp. is vendor of my tracer
yogawenno
Sun Aug 04, 2019 4:30 pm
this is a address list from my tracer "solar-elektro.cz/data/dokumenty/1733_modbus_protocol.pdf" . or maybe there a mistake in entering the address?
ghp
Sun Aug 04, 2019 5:33 pm
The cable has an USB device build in, but unfortunately I can't find more information for this vendor-product.
Found a page which provides a driver for this sort of devices https://github.com/kasbert/epsolar-trac ... _common-1a
And someone who wired the device directly. https://community.blynk.cc/t/epsolar-tr ... itor/10596
Perhaps a question better asked in https://www.raspberrypi.org/forums/viewforum.php?f=44
yogawenno
Mon Aug 05, 2019 8:04 am
my problem has been solved. thank you for helping me in solving my problem :)
Mon Aug 05, 2019 8:26 am
Please could you post details or a link to the solution of your problem, just in case someone else has a similar problem and is seeking a solution.
Unreadable squiggle
yogawenno
Mon Aug 05, 2019 11:10 am
Problems with my device with drivers that are not installed (exar kernel driver)
I followed these instructions https://github.com/buba447/solartracer- ... /README.md to install the drivers that I need
Re: problem connect epsolar-tracer to raspberry pi [SOLVED]
Mon Aug 05, 2019 11:48 am
Thank you :-)
Now you can edit your first post on this subject and add "[SOLVED]" to the subject line like I have for this reply. :-)
Unreadable squiggle
angomes
Sat Mar 28, 2020 10:48 am
Hey bro,
I'm having exactly the same issue as you did, I need to install the driver for my USB to rs485 adapter, but I tried to follow the instruction on the ink you added there but can't make it past the fist command line, when I do sudo bundle and sudo make I get (sudo: bundle: command not found) just for the record I have 0 experience with raspberry pi.
could you please explain-me step by step how you installed the drivers needed.
I would really appreciate it.
Return to “Python”
