File "/home/pi/.local/lib/python3.7/site-packages/pyglet/__init__.py", line 352, in __getattr__
return getattr(self._module, name)
AttributeError: 'NoneType' object has no attribute 'add_file'
During handling of the above exception, another exception occurred:
File "grafica.py", line 16, in <module>
pyglet.font.add_file('digital-7.ttf')
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/__init__.py", line 358, in __getattr__
__import__(import_name)
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/font/__init__.py", line 73, in <module>
from pyglet.font.freetype import FreeTypeFont
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/font/freetype.py", line 42, in <module>
from pyglet.font import base
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/font/base.py", line 53, in <module>
from pyglet.gl import *
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/gl/__init__.py", line 237, in <module>
import pyglet.window
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/window/__init__.py", line 1871, in <module>
gl._create_shadow_window()
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/gl/__init__.py", line 209, in _create_shadow_window
_shadow_window = Window(width=1, height=1, visible=False)
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/window/xlib/__init__.py", line 171, in __init__
super(XlibWindow, self).__init__(*args, **kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/window/__init__.py", line 641, in __init__
self._create()
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/window/xlib/__init__.py", line 265, in _create
self.context.set_vsync(self._vsync) # XXX ?
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/gl/xlib.py", line 255, in set_vsync
glxext_mesa.glXSwapIntervalMESA(interval)
File "/home/pi/.local/lib/python3.7/site-packages/pyglet/gl/lib.py", line 64, in MissingFunction
raise MissingFunctionException(name, requires, suggestions)
pyglet.gl.lib.MissingFunctionException: glXSwapIntervalMESA is not exported by the available OpenGL driver. MESA_swap_control is required for this functionality.
Errore di segmentazione
Tutto ciò mi fa pensare ad un problema di driver openGL, ma ho visto alcuni che fanno girare minecraft su Raspberry, quindi mi sembra molto strano che minecraft funzioni e pyglet no.
Qualche soluzione a questo problema?
