witteherder
SSD juist inschalen met Gparted
Wed Jul 31, 2019 1:53 pm
Ik wilde deze handleiding volgen http://www.makerspace-uk.co.uk/setting- ... sktop-kit/
Bij deze stap loop ik vast:
From this it can be seen that the copied file system only uses a fraction of the SSD, leaving the major proportion of the device unallocated. In order to use this space, all we needed to do was to resize the ext4 partition to make use of this unallocated space on the SSD. This is done using gparted, by selecting the ext4 partition, selecting ‘Partition’, ‘Resize/Move Partition’, then resizing the ext4 partition to use all the unallocated space on the SSD.
Gparted 1
Ik krijg namelijk ext4 niet vergoot
Gparted 2
Wat doe ik verkeerd of wat moet ik aanpassen en hoe in Gparted?
Raspberry Pi 3B+
Domoticz V4.10717
Toon 2 Rooted User
Firmware version: 5.9.6
7 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
Return to “Nederlands”
