Bicky
Arduino does not recieve value from raspberry pi
Tue Jul 30, 2019 4:15 am
Hello friends, I have been trying to transfer co-ordinates from picamera of raspberry pi to arduino .It was running smoothly in python 2.7.But in python 3+ i had to encode the value using encode() function to before serial write .
But now the arduino does not receive any value at all.
Serial.read in arduino shows -1 value .
Can someone tell me what to do? :( :(
This is my raspi code:
import io
from picamera.array import PiRGBArray
from picamera import PiCamera
import time
import sys
sys.path.append("/usr/local/lib/python3.5/site-packages")
import cv2
import serial
import numpy as np
camera = PiCamera()
camera.resolution = (640, 480)
camera.framerate = 32
rawCapture = PiRGBArray(camera, size=(640, 480))
port = "/dev/ttyUSB0"
s1 = serial.Serial(port,9600)
time.sleep(0.1)
for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
	image = frame.array
	hsv = cv2.cvtColor(image,cv2.COLOR_BGR2HSV)
	lower_range = np.array([110,50,50])
	upper_range = np.array([130,255,255])
	mask = cv2.inRange(hsv, lower_range, upper_range)
	#cv2.imshow("Frame",image)
	key = cv2.waitKey(1) & 0xFF
	ret,thresh = cv2.threshold(mask,127,225,0)
	im2,contours,hierarchy = cv2.findContours(thresh,1,2)
	#cnt = contours[0]
	M = cv2.moments(thresh)
	if M['m00']!=0:
		cx = int(M['m10']/M['m00'])
		cy = int(M['m01']/M['m00'])
		cv2.circle(image, (cx, cy), 10, (255, 0, 0), -1)
		print cx
		z= str(cx)+'a'
		s1.write(z.enocde())
	else:
		cx, cy = 0, 0
	cv2.imshow("TERMINATOR",image)
	rawCapture.truncate(0)
	if key == ord("q"):
		break
cv2.destroyAllWindows()
This is my code in arduino :
#include <Servo.h>
//#include <SoftwareSerial.h>
//SoftwareSerial data_serial(52 , 36); // RX, TX
//SoftwareSerial data_serial2(9, 11); // RX, TX
char m[10];
char n;
int count;
int i=0;
float value;
const int Oina1 = 12;
const int Oina2 = 13;
const int Oina3 = 9;
const int Oina4 = 8;
const int Oinb1 = 6;
const int Oinb2 = 7;
const int Oinb3 = 3;
const int Oinb4 = 2;
int Oena1=11;
int Oena2=10;
int Oenb1=5;
int Oenb2=4;
int spray=14;
Servo servo01;
Servo servo02;
Servo servo03;
Servo servo04;
Servo servo05;
Servo servo06;
int servo1Pos, servo2Pos, servo3Pos, servo4Pos, servo5Pos, servo6Pos; // current position
int servo1PPos, servo2PPos, servo3PPos, servo4PPos, servo5PPos, servo6PPos; // previous position
void setup() {
  pinMode(Oina1,OUTPUT);
  pinMode(Oina2,OUTPUT);
  pinMode(Oina3,OUTPUT);
  pinMode(Oina4,OUTPUT);
  pinMode(Oinb1,OUTPUT);
  pinMode(Oinb2,OUTPUT);
  pinMode(Oinb3,OUTPUT);
  pinMode(Oinb4,OUTPUT);
  pinMode(Oena1,OUTPUT);
  pinMode(Oena2,OUTPUT);
  pinMode(Oenb1,OUTPUT);
  pinMode(Oenb2,OUTPUT);
 pinMode(spray,OUTPUT);
  servo02.attach(22);
  servo03.attach(23);
  servo05.attach(24);
  servo06.attach(25);
  servo2PPos = 100;
  servo02.write(servo2PPos);
  servo3PPos = 10;
  servo03.write(servo3PPos);
  servo5PPos = 10;
  servo05.write(servo5PPos);
  servo6PPos = 100;
  servo06.write(servo6PPos);
  Serial.begin(9600);
 // Serial.begin(9600);
void loop() {
  if(Serial.available()){
  n=Serial.read();
 if(n =='b'){
  value=atof(m);
   Serial.println("y-axis:");
  Serial.println(value);
  i=0;
  m[0]=0;
  m[1]=0;
  m[2]=0;
  m[3]=0;
else{
m[i]=n;
i++;
  if(value>=180 && value<=400){
    while(value>=180 && value<=400){
      Stop();
    pick();
  sideways();
void pick(){
 for(int i=100;i<=160;i++){
    servo02.write(i);
    delay(20);
 for(int j=10;j<=50;j++){
    servo03.write(j);
   delay(20);
 for(int k=10;k<=50;k++){
    servo05.write(k);
  delay(20);
 for(int l=100;l>=0;l--){
     servo06.write(l);
   delay(20);
void sideways()
  analogWrite(Oena1,50);
  analogWrite(Oena2,50);
   analogWrite(Oenb1,50);
  analogWrite(Oenb2,50);
  digitalWrite(Oina1,HIGH);
  digitalWrite(Oina2,LOW);
    digitalWrite(Oina3,LOW);
  digitalWrite(Oina4,HIGH);
   digitalWrite(Oinb1,LOW);
  digitalWrite(Oinb2,LOW);
    digitalWrite(Oinb3,LOW);
  digitalWrite(Oinb4,LOW);
void frontways()
  digitalWrite(Oina1,LOW);
  digitalWrite(Oina4,LOW);
   digitalWrite(Oinb1,HIGH);
    digitalWrite(Oinb3,HIGH);
void Stop()
This is my pi and Arduino setup:
dshaw619
Re: Arduino does not recieve value from raspberry pi
Tue Jul 30, 2019 4:48 am
Should
actually be
 s1.write(z.encode())
p.s. It greatly helps to put your code (especially Python which is sensitive to indentation) between code tags (click "Code" on formatting menu when creating your post, then paste in your code).
Bicky
Tue Jul 30, 2019 6:32 am
Sorry , it is encode() in the main program . It still doesn't work .
MrYsLab
Tue Jul 30, 2019 3:16 pm
Try:
s1.write(bytes([ord(data)]))
ghp
Tue Jul 30, 2019 5:46 pm
Hello, your code is
	        z= str(cx)+'a'
What is the range of cx ? Please add
   	        z= str(cx)+'a'
		print ("z is", z)
and give some of the results here. I assume that the byte arrays transferred are something like b"123.4a".
Your arduino code has some problems. (A1) You add an 'a' to the number sent. In arduino, you check for a 'b'. This does not match.
(A2) There is a while loop in the code:
if (value >= 180 && value <= 400) {
    while (value >= 180 && value <= 400) {
So if the value goes between 180 and 400, the loop never terminates ?
(A3) Instead of using atof, the atoi function could be more appropriate (when values are integer).
(A4) When values can be float, consider huge values like 34.333333333 which easily extend your 10 byte m-array. This is where in python you should limit the length AND in C you extend the array to say 40 bytes and you limit the length:
const int LENGTH = 40 ;
char m[LENGTH +1];  // for terminating '\0'
char n;
int i = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  if (Serial.available()) {
    n = Serial.read();
    Serial.println("got");
    Serial.println(n);
    if (n == 'b') {
      value = atof(m);
      i = 0;
      for ( int k = 0; k < LENGTH +1; k++)
        m[k] = 0;
    else {
      if (i < LENGTH){
        m[i] = n;
        i++;
Last not least: Test your arduino code using the serial monitor.
Good luck !
Edit: you use USB serial (from a PC?) and the serial pins on the arduino in parallel. As there is only one serial on atmel328, this could be a problem. In my projects, I use mostly USB serial only.
Bicky
Wed Jul 31, 2019 10:50 pm
But in Arduino serial.read shows that the Arduino is not receiving any value at all.
It prints -1
ghp
Thu Aug 01, 2019 4:45 am
The photo shows that you use two serial adapters in parallel,
- a usb to digital from the raspberry
- the usb cable, most possibly to a pc or laptop.
Take a look to the schematics https://content.arduino.cc/assets/UNO-TH_Rev3e_sch.pdf. Both of these inputs go into (TXD)PD1, (RXD)PD0 pins of the processor, decoupled by RN4B, RN4A. Most possibly the digital inputs will win, but you never know unless measuring the levels.
My proposal is:
Step 1: disconnect the wires from the arduino to the usb-digital converter (unpower the assembly first). Then use the serial monitor of your arduino software , set to 9600bd, and type in some values like "123.4b", the 'b' is according to your sketch posted. This should work, you should see the arduino send data back.
Step 2: disconnect the usb cable from arduino, and reconnect to raspberry. Arduino will be powered from raspberry now. Do not start your python code. Use "minicom" with your USB serial device and you should see same behavior as in Step 1. minicom might not be available in your system, install with 'sudo apt-get install minicom'.
Step 3: stop minicom, start your python code. The serial input from arduino into raspberry is not visible, but your arduino should react to the codes sent.
Step 4: You can extend your python code with a thread which reads the data from serial and just prints to console to see the printouts of arduino.
ankith26
Fri Aug 09, 2019 3:24 pm
I know i am replying a bit late but i shall try to solve the problem.
try
s.encode('ascii')
You have to tell python to encode data in ascii cos it does it in utf8 by default.
And arduino uses ascii
BTW,
I noticed you are using port /dev/ttyUSB0..
Check whether arduino is on same port.
Cos in my case it has always been /dev/ttyACM0 ...
Why not directly connect arduino to raspberry pi via usb cable.. That will help
Your code appears to have some bugs i can notice..
You would want to also solve those to make your project work
I sat thinking for 5 minutes on what to put here. Finally I put something like this.
Check out my github page @ https://github.com/ankith26
ankith26
Fri Aug 09, 2019 3:44 pm
Here is some sample code i had used in a project few months ago
This helped me acheive 2 directional messaging.
Arduino side:-
void setup() {
   Serial.begin(9600); // begin transmission
void loop() {
  String val;
  while (Serial.available() > 0) {
    val = val + (char)Serial.read(); // read data byte by byte and store it
  Serial.print(val); // send the received data back to raspberry pi
Raspberry side:-
import serial
port = "/dev/ttyACM0"#put your port here
baudrate = 9600
ser = serial.Serial(port, baudrate)
def tell(msg):
    msg = msg + '\n'
    x = msg.encode('ascii') # encode n send
    ser.write(x)
def hear():
    msg = ser.read_until() # read until a new line
    mystring = msg.decode('ascii')  # decode n return
    return mystring
while True:
    val = input() # take user input
    tell(val) # send it to arduino
    var = hear() # listen to arduino
    print(var) #print what arduino sent
The raspberry pi sends a string, arduino reads it and sends it back to raspberry pi which prints it after reading it.
Return to “Python”
