redhawk
RAM drive??
Wed Dec 05, 2012 12:15 am
Is it possible to have a mountable RAM drive device and how do I define one i.e. to use 1MB of system RAM??
Richard S.
Tafkas
Re: RAM drive??
Wed Dec 05, 2012 12:47 am
You can just use /run/shm for that. It is already built-in.
NickMon68
Re: RAM drive??
Wed Dec 05, 2012 9:54 am
What are you using the Ram drive for ?
Poor little Pi not got enough as it is !
:D
Would a USB stick not be more useful
redhawk
Re: RAM drive??
Wed Dec 05, 2012 10:40 am
I want an area of disk space where I can constantly change the contents i.e. webcam image refresh, access log files for web server etc.
Since flash memory has limited write cycles before going bad having a RAM drive would eliminate this problem because the writes are in RAM only.
After some searching on Google I found the following that works on my PI:
mkdir /ram
mkfs -q /dev/ram1 1024
mount /dev/ram1 /ram
RAM drive now exists in /ram if you need RAM drive again after a reboot just repeat the same commands except for mkdir /ram
Now if only I had the PI 512MB model B I would have loads more RAM to play with. :)
While on the subject of RAM there appears to be other RAM devices present i.e. /dev/ram1 /dev/ram2 /dev/ram3 ... /dev/ram15.
Can anyone explain the difference between /dev/ram1 and /dev/ram2 ??
Richard S.
steev
Re: RAM drive??
Wed Dec 05, 2012 12:18 pm
They are just multiple ramdisks you can use. Each one is 16 MB by default, but the memory isn't reserved until you format them.
I think these days it's usually better to use tmpfs or ramfs, though:
http://www.thegeekstuff.com/2008/11/ove ... s-on-linux
Like Tafkas said above, there is already a tmpfs on /dev/shm/ which you can use.
NickMon68
Re: RAM drive??
Thu Dec 06, 2012 2:29 pm
is /dev/shm loaded on the pi ?
If so its a Ram disk, lost on boot..
Return to “Raspbian”
