Josuke
convertor from html to PNG in console #RaspberryPi
Wed Jul 24, 2019 4:57 pm
Hello all, I need converter from HTML page into PNG file (it also can be jpeg etc) what I can use thru console in my RaspberryPi
Not working ones converters
-webkit2png
- wkhtmltoimage
both show some kind of nonsens in console
klricks
Re: convertor from html to PNG in console #RaspberryPi
Sat Jul 27, 2019 3:01 am
-webkit2png
- wkhtmltoimage
Pressing [Print Screen] key will create a png image of the desktop screen. (uses scrot)
Or use scrot from the command line or in a script.
From a script you could load the browser in full screen or kiosk mode then take a screen capture after a time delay etc.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
rpdom
Sat Jul 27, 2019 6:57 am
OP specified console, so I assume not running desktop.
There is an option in Firefox that may work.
firefox --screenshot $URL
is supposed to save a screenshot of the $URL page in the current directory. I don't know if it works on a system without desktop.
Josuke
Wed Jul 31, 2019 9:04 pm
If I have raspbian as OS is it work or not&
Andyroo
Wed Jul 31, 2019 9:58 pm
-webkit2png
- wkhtmltoimage
What do they show - it may be easier to fix these than find another solution...
Need Pi spray - these things are breeding in my house...
Andyroo
Sat Sep 07, 2019 1:00 pm
Josuke
Sat Sep 07, 2019 5:36 pm
-webkit2png
- wkhtmltoimage
webkit2png is not working because its for IOS LOL
wkhtmltoimage installed with wkhtmltopdf ) well to convert html site to pdf its working(command -> wkhtmltopdf http://google.com google.pdf) but then I am trying to convert html to image (command wkhtmltoimage http://google.com google.jpeg) this shows
"bash: /usr/local/bin/wkhtmltoimage: cannot execute binary file: Exec format error"
Andyroo
Sat Sep 07, 2019 5:59 pm
Josuke wrote:
Sat Sep 07, 2019 4:35 pm
Bad URL
Mods must have had a tidy - it was fine when posted :lol:
How did you install these - it reads like you have a total mix of x86, ARM and iOS install files?
What version of the operating system are you using?
Josuke
Fri Sep 13, 2019 11:23 am
Well I found solution it is Cutycapt
OS ->Raspberry Pi newest(on ) 13/06/2018 version ( Raspbian v->July 2019)
Raspberry PI-> Raspberry Pi Model B V1.1
Installation guide :
1)
$ sudo apt-get update
$ sudo apt-get upgrade
2)
$ sudo apt-get install cutycapt
3)
4)
PROFIT!
How to use it:
CutyCapt support formats ->SVG, PDF, PS, PNG, JPEG, TIFF, GIF btw have support of javascript and you can convert HTML files(it can be file in your Pi) to image. More info-> $cutycapt --help
type this in console for test:
$ cutycapt --url=http://www.google.com --out=google.png
AWARE!
output image will be placed in working directory and THE MOST important CutyCapt by some mean "squeezes" output image
better use like that (output image will be 1920x1080)
$ cutycapt --url=http://www.google.com --out=google.png --min-width=1920 --min-height=1080
Source of info ->http://xmodulo.com/convert-html-web-pag ... linux.html
Potential fix of libraries ->http://edwinhernandez.com/2013/05/26/in ... tu-12-0-4/
Josuke
Fri Sep 13, 2019 11:24 am
Bad URL
Found the answer
