robertr356
MacBook Pro Integrated Keyboard and Trackpad Not Working
Sat Jul 20, 2019 6:43 pm
I’m a beginner with Raspberry Pi and I’m trying to set it up on my MacBook Pro (2017). I have the Raspberry Pi on a USB and I’m able to launch it, however when I reach the desktop, I’m not able to use the integrated keyboard and trackpad that is on my laptop. I can connect, through USB, a wired mouse and keyboard and then it works fine, however it produces a lot of clutter in my work space. Is there any way I can enable and use the integrated keyboard and trackpad on my MacBook?
Thanks,
- Robert
Re: MacBook Pro Integrated Keyboard and Trackpad Not Working
Sat Jul 20, 2019 8:45 pm
Thanks,
- Robert
Raspberry Pi is a Single Board Computer !
Therefore what Operating System are you talking about, a link to the download would be good.
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
robertr356
Fri Aug 02, 2019 7:22 pm
Thanks,
- Robert
I’m running Linux, and unfortunately I do not have a direct link to the download because I’m using Raspberry Pi for a project and was only given a USB that had it.
Andyroo
Fri Aug 02, 2019 7:42 pm
How do you connect to the Pi? Is it RealVNC or some other program on the Mac?
Can you run the following on the Pi and post the results here:
uname -a
cat /etc/os-release
If you are using RealVNC it is possible that it is set to view only mode - I’m not at my Mac for a few hours but maybe this will help https://www.realvnc.com/en/connect/docs ... wonly.html
Note: This can be set on the Mac and/or the Pi so check both ends
drgeoff
Fri Aug 02, 2019 8:17 pm
I suspect that the OP's sentence "I have the Raspberry Pi on a USB and I’m able to launch it, however when I reach the desktop, I’m not able to use the integrated keyboard and trackpad that is on my laptop." means a cable between USB port on the Mac and the power input socket on the RPi.
Fri Aug 02, 2019 8:25 pm
OR maybe he is actually running x86 Debian with Raspberry Pi Desktop from USB Stick ???
