Qui vi riporto alcune informazioni fondamentali:
Distro:
"Raspbian GNU/Linux 9 (stretch)"
Release: 9.9
Versione kernel:
Linux raspberrypi 4.19.57-v7+
Report di Journalctl:
lug 20 09:16:48 raspberrypi kernel: rpi_firmware_get_throttled: 3 callbacks suppressed
lug 20 09:16:48 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:16:50 raspberrypi kernel: rpi_firmware_get_throttled: 4 callbacks suppressed
lug 20 09:16:50 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:16:58 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:17:01 raspberrypi CRON[2158]: pam_unix(cron:session): session opened for user root by (uid=0)
lug 20 09:17:01 raspberrypi CRON[2162]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
lug 20 09:17:01 raspberrypi CRON[2158]: pam_unix(cron:session): session closed for user root
lug 20 09:17:02 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:17:08 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:17:25 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:24:00 raspberrypi kernel: rpi_firmware_get_throttled: 5 callbacks suppressed
lug 20 09:24:00 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:24:04 raspberrypi kernel: rpi_firmware_get_throttled: 5 callbacks suppressed
lug 20 09:24:04 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:24:13 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:24:17 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:25:27 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
lug 20 09:25:27 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
lug 20 09:26:20 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:26:38 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:28:33 raspberrypi org.a11y.atspi.Registry[979]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
lug 20 09:28:41 raspberrypi python3[2662]: io/hpmud/jd.c 678: timeout read_channel sec=6 hp:/net/OfficeJet_4650_series?ip=192.168.1.20
lug 20 09:28:47 raspberrypi python3[2662]: io/hpmud/jd.c 678: timeout read_channel sec=6 hp:/net/OfficeJet_4650_series?ip=192.168.1.20
lug 20 09:28:53 raspberrypi python3[2662]: io/hpmud/jd.c 678: timeout read_channel sec=6 hp:/net/OfficeJet_4650_series?ip=192.168.1.20
lug 20 09:29:02 raspberrypi kernel: rpi_firmware_get_throttled: 4 callbacks suppressed
lug 20 09:29:02 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:29:08 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:29:14 raspberrypi kernel: rpi_firmware_get_throttled: 5 callbacks suppressed
lug 20 09:29:14 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:29:18 raspberrypi kernel: Voltage normalised (0x00000000)
lug 20 09:29:25 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:29:34 raspberrypi /hp-systray[2660]: hp-systray(qt5)[2660]: error: No system tray detected on this system. Unable to start, exiting.
lug 20 09:29:35 raspberrypi kernel: Under-voltage detected! (0x00050005)
lug 20 09:31:23 raspberrypi kernel: CIFS VFS: server 192.168.1.1 of type Samba 3.0.27a returned unexpected error on SMB posix open, disabling posix open suppo
lines 728-765/765 (END)
HP Linux Imaging and Printing System (ver. 3.16.11)
Dependency/Version Check Utility ver. 15.1
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
warning: 2-9.9 version is not supported. Using 2-8.6 versions dependencies to verify and install...
| SYSTEM INFO |
Kernel: 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 GNU/Linux
Host: raspberrypi
Proc: 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 GNU/Linux
Distribution: 2 9.9
Bitness: 32 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.16.11
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for 2 distro 9.9 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.16.11
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip
html=/usr/share/doc/hplip-doc
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.16.11
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: No such file or directory
Current contents of '~/.hplip/hplip.conf' file:
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[fax]
email_address =
voice_phone =
[installation]
date_time = 07/20/19 09:42:35
version = 3.16.11
[last_used]
device_uri = "hp:/net/OfficeJet_4650_series?ip=192.168.1.20"
printer_name = OfficeJet_4650
working_dir = .
[polling]
device_list =
enable = false
interval = 5
[refresh]
enable = false
rate = 30
type = 1
[settings]
systray_messages = 3
systray_visible = 2
[upgrade]
last_upgraded_time = 1557043375
notify_upgrade = false
pending_upgrade_time = 0
<Package-name> <Package-Desc> <Required/Optional> <Min-Version> <Installed-Version> <Status> <Comment>
| Scan Configuration |
scanext Scan-SANE-Extension REQUIRED - 3.16.11 OK -
'/etc/sane.d/dll.d/hpaio' not found.
hpaio HPLIP-SANE-Backend REQUIRED - 3.16.11 OK 'hpaio found in /etc/sane.d/dll.conf'
| COMPILEDEP |
error: libtool libtool - Library building support services REQUIRED - - MISSING 'libtool needs to be installed'
error: make make - GNU make utility to maintain groups of programs REQUIRED 3.0 - MISSING 'make needs to be installed'
gcc gcc - GNU Project C and C++ Compiler REQUIRED - 6.3.0 OK -
| Python Extentions |
cupsext CUPS-Extension REQUIRED - 3.16.11 OK -
hpmudext IO-Extension REQUIRED - 3.16.11 OK -
| General Dependencies |
error: cups-image CUPS image - CUPS image development files REQUIRED - - MISSING 'cups-image needs to be installed'
error: libjpeg libjpeg - JPEG library REQUIRED - - MISSING 'libjpeg needs to be installed'
libpthread libpthread - POSIX threads library REQUIRED - b'2.24' OK -
python3-devel Python devel - Python development files REQUIRED 2.2 3.5.3 OK -
error: libusb libusb - USB library REQUIRED - 1.0 MISSING 'libusb needs to be installed'
error: sane-devel SANE - Scanning library development files REQUIRED - - MISSING 'sane-devel needs to be installed'
cups-ddk CUPS DDK - CUPS driver development kit OPTIONAL - - OK -
error: libcrypto libcrypto - OpenSSL cryptographic library REQUIRED - 1.1.0 MISSING 'libcrypto needs to be installed'
error: python3-pyqt4 PyQt 4- Qt interface for Python (for Qt version 4.x) REQUIRED 4.0 - MISSING 'python3-pyqt4 needs to be installed'
error: python3-pyqt4-dbus PyQt 4 DBus - DBus Support for PyQt4 OPTIONAL 4.0 - INCOMPAT 'python3-pyqt4-dbus needs to be installed'
error: cups-devel CUPS devel- Common Unix Printing System development files REQUIRED - - MISSING 'cups-devel needs to be installed'
python3-reportlab Reportlab - PDF library for Python OPTIONAL 2.0 3.3.0 OK -
sane SANE - Scanning library REQUIRED - - OK -
python3X Python 2.2 or greater - Python programming language REQUIRED 2.2 3.5.3 OK -
python3-pil PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL - 1.1.7 OK -
python3-xml Python XML libraries REQUIRED - 2.2.0 OK -
python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL - - OK -
python3-dbus Python DBus - Python bindings for DBus REQUIRED 0.80.0 1.2.4 OK -
error: libnetsnmp-devel libnetsnmp-devel - SNMP networking library development files REQUIRED 5.0.9 - MISSING 'libnetsnmp-devel needs to be installed'
| External Dependencies |
gs GhostScript - PostScript and PDF language interpreter and previewer REQUIRED 7.05 9.26 OK -
error: dbus DBus - Message bus system REQUIRED - 1.10.28 MISSING 'DBUS may not be installed or not running'
network network -wget OPTIONAL - - OK -
error: cups CUPS - Common Unix Printing System REQUIRED 1.1 - INCOMPAT 'CUPS may not be installed or not running'
xsane xsane - Graphical scanner frontend for SANE OPTIONAL 0.9 0.999 OK -
avahi-utils avahi-utils OPTIONAL - 0.6.32 OK -
scanimage scanimage - Shell scanning program OPTIONAL 1.0 1.0.25 OK -
policykit PolicyKit - Administrative policy framework OPTIONAL - 0.105 OK -
| DISCOVERED SCANNER DEVICES |
device `hpaio:/net/OfficeJet_4650_series?ip=192.168.1.20' is a Hewlett-Packard OfficeJet_4650_series all-in-one
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
OfficeJet_4650
Type: Printer
Device URI: hp:/net/OfficeJet_4650_series?ip=192.168.1.20
PPD: /etc/cups/ppd/OfficeJet_4650.ppd
warning: Failed to read /etc/cups/ppd/OfficeJet_4650.ppd ppd file
PPD Description:
Printer status:
MIB search path: /home/pi/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (SNMPv2-MIB): At line 1 in (none)
Cannot find module (IF-MIB): At line 1 in (none)
Cannot find module (IP-MIB): At line 1 in (none)
Cannot find module (TCP-MIB): At line 1 in (none)
Cannot find module (UDP-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 1 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 1 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 1 in (none)
Cannot find module (DISMAN-SCHEDULE-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-TYPES): At line 1 in (none)
Cannot find module (MTA-MIB): At line 1 in (none)
Cannot find module (NETWORK-SERVICES-MIB): At line 1 in (none)
Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
Cannot find module (SNMPv2-SMI): At line 34 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Cannot find module (SNMPv2-TC): At line 37 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Unlinked OID in UCD-SNMP-MIB: ucdavis ::= { enterprises 2021 }
Undefined identifier: enterprises near line 39 of /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
Unlinked OID in UCD-DISKIO-MIB: ucdDiskIOMIB ::= { ucdExperimental 15 }
Undefined identifier: ucdExperimental near line 19 of /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
Cannot find module (SNMPv2-TC): At line 10 in /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
Unlinked OID in UCD-DLMOD-MIB: ucdDlmodMIB ::= { ucdExperimental 14 }
Undefined identifier: ucdExperimental near line 13 of /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
Unlinked OID in LM-SENSORS-MIB: lmSensors ::= { ucdExperimental 16 }
Undefined identifier: ucdExperimental near line 32 of /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
Did not find 'ucdavis' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DEMO-MIB.txt)
Unlinked OID in UCD-DEMO-MIB: ucdDemoMIB ::= { ucdavis 14 }
Undefined identifier: ucdavis near line 7 of /usr/share/snmp/mibs/UCD-DEMO-MIB.txt
Cannot find module (SNMP-TARGET-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Cannot find module (SNMPv2-SMI): At line 8 in /usr/share/snmp/mibs/NET-SNMP-MIB.txt
Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-MIB.txt)
Unlinked OID in NET-SNMP-MIB: netSnmp ::= { enterprises 8072 }
Undefined identifier: enterprises near line 10 of /usr/share/snmp/mibs/NET-SNMP-MIB.txt
Cannot find module (SNMPv2-TC): At line 21 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpModuleIDs' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpNotifications' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
Unlinked OID in NET-SNMP-AGENT-MIB: nsAgentNotifyGroup ::= { netSnmpGroups 9 }
Undefined identifier: netSnmpGroups near line 545 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactionGroup ::= { netSnmpGroups 8 }
Undefined identifier: netSnmpGroups near line 536 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsConfigGroups ::= { netSnmpGroups 7 }
Undefined identifier: netSnmpGroups near line 515 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
Undefined identifier: netSnmpGroups near line 505 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
Undefined identifier: netSnmpGroups near line 495 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: netSnmpAgentMIB ::= { netSnmpModuleIDs 2 }
Undefined identifier: netSnmpModuleIDs near line 24 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactions ::= { netSnmpObjects 8 }
Undefined identifier: netSnmpObjects near line 55 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsConfiguration ::= { netSnmpObjects 7 }
Undefined identifier: netSnmpObjects near line 54 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsErrorHistory ::= { netSnmpObjects 6 }
Undefined identifier: netSnmpObjects near line 53 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsCache ::= { netSnmpObjects 5 }
Undefined identifier: netSnmpObjects near line 52 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsDLMod ::= { netSnmpObjects 4 }
Undefined identifier: netSnmpObjects near line 51 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsExtensions ::= { netSnmpObjects 3 }
Undefined identifier: netSnmpObjects near line 50 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsMibRegistry ::= { netSnmpObjects 2 }
Undefined identifier: netSnmpObjects near line 49 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsVersion ::= { netSnmpObjects 1 }
Undefined identifier: netSnmpObjects near line 48 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
Undefined identifier: netSnmpNotifications near line 482 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
Undefined identifier: netSnmpNotifications near line 476 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
Undefined identifier: netSnmpNotifications near line 470 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
Cannot find module (SNMP-MPD-MIB): At line 1 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 1 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 1 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 1 in (none)
Cannot find module (IPV6-ICMP-MIB): At line 1 in (none)
Cannot find module (IPV6-MIB): At line 1 in (none)
Cannot find module (IPV6-TCP-MIB): At line 1 in (none)
Cannot find module (IPV6-UDP-MIB): At line 1 in (none)
Cannot find module (IP-FORWARD-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Cannot find module (SNMPv2-TC): At line 12 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Cannot find module (INET-ADDRESS-MIB): At line 13 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'netSnmp' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'InetAddressType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Did not find 'InetAddress' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
Unlinked OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
Undefined identifier: netSnmp near line 16 of /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
Did not find 'netSnmpExamples' in module NET-SNMP-EXAMPLES-MIB (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
Unlinked OID in NET-SNMP-PASS-MIB: netSnmpPassExamples ::= { netSnmpExamples 255 }
Undefined identifier: netSnmpExamples near line 14 of /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
Cannot find module (SNMPv2-TC): At line 16 in /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Did not find 'nsExtensions' in module NET-SNMP-AGENT-MIB (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendGroups ::= { nsExtensions 3 }
Undefined identifier: nsExtensions near line 39 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendObjects ::= { nsExtensions 2 }
Undefined identifier: nsExtensions near line 38 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Unlinked OID in NET-SNMP-EXTEND-MIB: netSnmpExtendMIB ::= { nsExtensions 1 }
Undefined identifier: nsExtensions near line 19 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
Cannot find module (SNMP-NOTIFICATION-MIB): At line 1 in (none)
Cannot find module (SNMPv2-TM): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 16 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot find module (SNMPv2-TC): At line 25 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmGroupName' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessContextPrefix' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessSecurityModel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'vacmAccessSecurityLevel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
Unlinked OID in NET-SNMP-VACM-MIB: netSnmpVacmMIB ::= { netSnmpObjects 9 }
Undefined identifier: netSnmpObjects near line 28 of /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
Cannot adopt OID in UCD-SNMP-MIB: logMatchRegExCompilation ::= { logMatchEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchErrorFlag ::= { logMatchEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCycle ::= { logMatchEntry 11 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCount ::= { logMatchEntry 10 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCounter ::= { logMatchEntry 9 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCount ::= { logMatchEntry 8 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCounter ::= { logMatchEntry 7 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCount ::= { logMatchEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCounter ::= { logMatchEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchRegEx ::= { logMatchEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchFilename ::= { logMatchEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchName ::= { logMatchEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchIndex ::= { logMatchEntry 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAccessEntry ::= { nsVacmAccessTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: extErrFixCmd ::= { extEntry 103 }
Cannot adopt OID in UCD-SNMP-MIB: extErrFix ::= { extEntry 102 }
Cannot adopt OID in UCD-SNMP-MIB: extOutput ::= { extEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: extResult ::= { extEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: extCommand ::= { extEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: extNames ::= { extEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: extIndex ::= { extEntry 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPublic ::= { ucdDemoMIBObjects 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodTable ::= { ucdDlmodMIB 2 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodNextIndex ::= { ucdDlmodMIB 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpConformance ::= { netSnmp 5 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationPrefix ::= { netSnmp 4 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpExperimental ::= { netSnmp 9999 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpEnumerations ::= { netSnmp 3 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpObjects ::= { netSnmp 1 }
Cannot adopt OID in UCD-SNMP-MIB: versionDoDebugging ::= { version 20 }
Cannot adopt OID in UCD-SNMP-MIB: versionSavePersistentData ::= { version 13 }
Cannot adopt OID in UCD-SNMP-MIB: versionRestartAgent ::= { version 12 }
Cannot adopt OID in UCD-SNMP-MIB: versionUpdateConfig ::= { version 11 }
Cannot adopt OID in UCD-SNMP-MIB: versionClearCache ::= { version 10 }
Cannot adopt OID in UCD-SNMP-MIB: versionConfigureOptions ::= { version 6 }
Cannot adopt OID in UCD-SNMP-MIB: versionIdent ::= { version 5 }
Cannot adopt OID in UCD-SNMP-MIB: versionCDate ::= { version 4 }
Cannot adopt OID in UCD-SNMP-MIB: versionDate ::= { version 3 }
Cannot adopt OID in UCD-SNMP-MIB: versionTag ::= { version 2 }
Cannot adopt OID in UCD-SNMP-MIB: versionIndex ::= { version 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatNotification ::= { netSnmpExampleNotificationPrefix 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheStatus ::= { nsCacheEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheTimeout ::= { nsCacheEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCachedOID ::= { nsCacheEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: unknown ::= { ucdSnmpAgent 255 }
Cannot adopt OID in UCD-SNMP-MIB: dragonfly ::= { ucdSnmpAgent 17 }
Cannot adopt OID in UCD-SNMP-MIB: macosx ::= { ucdSnmpAgent 16 }
Cannot adopt OID in UCD-SNMP-MIB: aix ::= { ucdSnmpAgent 15 }
Cannot adopt OID in UCD-SNMP-MIB: hpux11 ::= { ucdSnmpAgent 14 }
Cannot adopt OID in UCD-SNMP-MIB: win32 ::= { ucdSnmpAgent 13 }
Cannot adopt OID in UCD-SNMP-MIB: openbsd ::= { ucdSnmpAgent 12 }
Cannot adopt OID in UCD-SNMP-MIB: bsdi ::= { ucdSnmpAgent 11 }
Cannot adopt OID in UCD-SNMP-MIB: linux ::= { ucdSnmpAgent 10 }
Cannot adopt OID in UCD-SNMP-MIB: irix ::= { ucdSnmpAgent 9 }
Cannot adopt OID in UCD-SNMP-MIB: freebsd ::= { ucdSnmpAgent 8 }
Cannot adopt OID in UCD-SNMP-MIB: netbsd1 ::= { ucdSnmpAgent 7 }
Cannot adopt OID in UCD-SNMP-MIB: hpux10 ::= { ucdSnmpAgent 6 }
Cannot adopt OID in UCD-SNMP-MIB: ultrix ::= { ucdSnmpAgent 5 }
Cannot adopt OID in UCD-SNMP-MIB: osf ::= { ucdSnmpAgent 4 }
Cannot adopt OID in UCD-SNMP-MIB: solaris ::= { ucdSnmpAgent 3 }
Cannot adopt OID in UCD-SNMP-MIB: sunos4 ::= { ucdSnmpAgent 2 }
Cannot adopt OID in UCD-SNMP-MIB: hpux9 ::= { ucdSnmpAgent 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputGroup ::= { nsExtendGroups 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigGroup ::= { nsExtendGroups 1 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOEntry ::= { diskIOTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionEntry ::= { nsTransactionTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpGroups ::= { netSnmpConformance 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpCompliances ::= { netSnmpConformance 1 }
Cannot adopt OID in UCD-SNMP-MIB: mrModuleName ::= { mrEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: mrIndex ::= { mrEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenEntry ::= { nsDebugTokenTable 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStatus ::= { nsExtendConfigEntry 21 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStorage ::= { nsExtendConfigEntry 20 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendRunType ::= { nsExtendConfigEntry 7 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendExecType ::= { nsExtendConfigEntry 6 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCacheTime ::= { nsExtendConfigEntry 5 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendInput ::= { nsExtendConfigEntry 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendArgs ::= { nsExtendConfigEntry 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCommand ::= { nsExtendConfigEntry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendToken ::= { nsExtendConfigEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTable ::= { nsMibRegistry 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpPlaypen ::= { netSnmpExperimental 9999 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpIETFWGEntry ::= { netSnmpIETFWGTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: prErrFixCmd ::= { prEntry 103 }
Cannot adopt OID in UCD-SNMP-MIB: prErrFix ::= { prEntry 102 }
Cannot adopt OID in UCD-SNMP-MIB: prErrMessage ::= { prEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: prErrorFlag ::= { prEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: prCount ::= { prEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: prMax ::= { prEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: prMin ::= { prEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: prNames ::= { prEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: prIndex ::= { prEntry 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodEntry ::= { dlmodTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: memSwapErrorMsg ::= { memory 101 }
Cannot adopt OID in UCD-SNMP-MIB: memSwapError ::= { memory 100 }
Cannot adopt OID in UCD-SNMP-MIB: memUsedRealTXT ::= { memory 17 }
Cannot adopt OID in UCD-SNMP-MIB: memUsedSwapTXT ::= { memory 16 }
Cannot adopt OID in UCD-SNMP-MIB: memCached ::= { memory 15 }
Cannot adopt OID in UCD-SNMP-MIB: memBuffer ::= { memory 14 }
Cannot adopt OID in UCD-SNMP-MIB: memShared ::= { memory 13 }
Cannot adopt OID in UCD-SNMP-MIB: memMinimumSwap ::= { memory 12 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalFree ::= { memory 11 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailRealTXT ::= { memory 10 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalRealTXT ::= { memory 9 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailSwapTXT ::= { memory 8 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalSwapTXT ::= { memory 7 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailReal ::= { memory 6 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalReal ::= { memory 5 }
Cannot adopt OID in UCD-SNMP-MIB: memAvailSwap ::= { memory 4 }
Cannot adopt OID in UCD-SNMP-MIB: memTotalSwap ::= { memory 3 }
Cannot adopt OID in UCD-SNMP-MIB: memErrorName ::= { memory 2 }
Cannot adopt OID in UCD-SNMP-MIB: memIndex ::= { memory 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoMIBObjects ::= { ucdDemoMIB 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTimeout ::= { nsModuleEntry 6 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleModes ::= { nsModuleEntry 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleName ::= { nsModuleEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPriority ::= { nsModuleEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPoint ::= { nsModuleEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmContextName ::= { nsModuleEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsEntry ::= { lmMiscSensorsTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationObjects ::= { netSnmpNotificationPrefix 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpNotifications ::= { netSnmpNotificationPrefix 0 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTable ::= { netSnmpPassExamples 2 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassOIDValue ::= { netSnmpPassExamples 99 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassGauge ::= { netSnmpPassExamples 6 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassCounter ::= { netSnmpPassExamples 5 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassIpAddress ::= { netSnmpPassExamples 4 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTimeTicks ::= { netSnmpPassExamples 3 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassString ::= { netSnmpPassExamples 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpDomains ::= { netSnmpEnumerations 3 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpAgentOIDs ::= { netSnmpEnumerations 2 }
Cannot adopt OID in NET-SNMP-MIB: netSnmpModuleIDs ::= { netSnmpEnumerations 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsEntry ::= { lmFanSensorsTable 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsEntry ::= { lmTempSensorsTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigGroups ::= { netSnmpGroups 7 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionGroup ::= { netSnmpGroups 8 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsAgentNotifyGroup ::= { netSnmpGroups 9 }
Cannot adopt OID in UCD-SNMP-MIB: fileEntry ::= { fileTable 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmStatus ::= { nsVacmAccessEntry 5 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmStorageType ::= { nsVacmAccessEntry 4 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmViewName ::= { nsVacmAccessEntry 3 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmContextMatch ::= { nsVacmAccessEntry 2 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAuthType ::= { nsVacmAccessEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: netSnmpExtendMIB ::= { nsExtensions 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendObjects ::= { nsExtensions 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendGroups ::= { nsExtensions 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsEntry ::= { lmVoltSensorsTable 1 }
Cannot adopt OID in NET-SNMP-MIB: netSnmp ::= { enterprises 8072 }
Cannot adopt OID in UCD-SNMP-MIB: ucdavis ::= { enterprises 2021 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONWrittenX ::= { diskIOEntry 13 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONReadX ::= { diskIOEntry 12 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA15 ::= { diskIOEntry 11 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA5 ::= { diskIOEntry 10 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOLA1 ::= { diskIOEntry 9 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOWrites ::= { diskIOEntry 6 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOReads ::= { diskIOEntry 5 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONWritten ::= { diskIOEntry 4 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIONRead ::= { diskIOEntry 3 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIODevice ::= { diskIOEntry 2 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOIndex ::= { diskIOEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionMode ::= { nsTransactionEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionID ::= { nsTransactionEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenStatus ::= { nsDebugTokenEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenPrefix ::= { nsDebugTokenEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGChair2 ::= { netSnmpIETFWGEntry 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGChair1 ::= { netSnmpIETFWGEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: nsIETFWGName ::= { netSnmpIETFWGEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingTable ::= { nsConfigLogging 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostsEntry ::= { netSnmpHostsTable 1 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodStatus ::= { dlmodEntry 5 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodError ::= { dlmodEntry 4 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodPath ::= { dlmodEntry 3 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodName ::= { dlmodEntry 2 }
Cannot adopt OID in UCD-DLMOD-MIB: dlmodIndex ::= { dlmodEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsValue ::= { lmMiscSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsDevice ::= { lmMiscSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsIndex ::= { lmMiscSensorsEntry 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassEntry ::= { netSnmpPassTable 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmSensors ::= { ucdExperimental 16 }
Cannot adopt OID in UCD-DLMOD-MIB: ucdDlmodMIB ::= { ucdExperimental 14 }
Cannot adopt OID in UCD-DISKIO-MIB: ucdDiskIOMIB ::= { ucdExperimental 15 }
Cannot adopt OID in UCD-SNMP-MIB: dskEntry ::= { dskTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: netSnmpAgentMIB ::= { netSnmpModuleIDs 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsValue ::= { lmFanSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsDevice ::= { lmFanSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsIndex ::= { lmFanSensorsEntry 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsValue ::= { lmTempSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsDevice ::= { lmTempSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsIndex ::= { lmTempSensorsEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchTable ::= { logMatch 2 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchMaxEntries ::= { logMatch 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingEntry ::= { nsLoggingTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: fileErrorMsg ::= { fileEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: fileErrorFlag ::= { fileEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: fileMax ::= { fileEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: fileSize ::= { fileEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: fileName ::= { fileEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: fileIndex ::= { fileEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput2Table ::= { nsExtendObjects 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Table ::= { nsExtendObjects 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigTable ::= { nsExtendObjects 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendNumEntries ::= { nsExtendObjects 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Entry ::= { nsExtendOutput1Table 1 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuNumCpus ::= { systemStats 67 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawGuestNice ::= { systemStats 66 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawGuest ::= { systemStats 65 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSteal ::= { systemStats 64 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawSwapOut ::= { systemStats 63 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawSwapIn ::= { systemStats 62 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSoftIRQ ::= { systemStats 61 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawContexts ::= { systemStats 60 }
Cannot adopt OID in UCD-SNMP-MIB: ssRawInterrupts ::= { systemStats 59 }
Cannot adopt OID in UCD-SNMP-MIB: ssIORawReceived ::= { systemStats 58 }
Cannot adopt OID in UCD-SNMP-MIB: ssIORawSent ::= { systemStats 57 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawInterrupt ::= { systemStats 56 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawKernel ::= { systemStats 55 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawWait ::= { systemStats 54 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawIdle ::= { systemStats 53 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawSystem ::= { systemStats 52 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawNice ::= { systemStats 51 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuRawUser ::= { systemStats 50 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuIdle ::= { systemStats 11 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuSystem ::= { systemStats 10 }
Cannot adopt OID in UCD-SNMP-MIB: ssCpuUser ::= { systemStats 9 }
Cannot adopt OID in UCD-SNMP-MIB: ssSysContext ::= { systemStats 8 }
Cannot adopt OID in UCD-SNMP-MIB: ssSysInterrupts ::= { systemStats 7 }
Cannot adopt OID in UCD-SNMP-MIB: ssIOReceive ::= { systemStats 6 }
Cannot adopt OID in UCD-SNMP-MIB: ssIOSent ::= { systemStats 5 }
Cannot adopt OID in UCD-SNMP-MIB: ssSwapOut ::= { systemStats 4 }
Cannot adopt OID in UCD-SNMP-MIB: ssSwapIn ::= { systemStats 3 }
Cannot adopt OID in UCD-SNMP-MIB: ssErrorName ::= { systemStats 2 }
Cannot adopt OID in UCD-SNMP-MIB: ssIndex ::= { systemStats 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput2Entry ::= { nsExtendOutput2Table 1 }
Cannot adopt OID in UCD-SNMP-MIB: laEntry ::= { laTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheTable ::= { nsCache 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheEnabled ::= { nsCache 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheDefaultTimeout ::= { nsCache 1 }
Cannot adopt OID in UCD-SNMP-MIB: logMatchEntry ::= { logMatchTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: extEntry ::= { extTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigLogging ::= { nsConfiguration 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfigDebug ::= { nsConfiguration 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleString ::= { netSnmpExampleScalars 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleSleeper ::= { netSnmpExampleScalars 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleInteger ::= { netSnmpExampleScalars 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsValue ::= { lmVoltSensorsEntry 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsDevice ::= { lmVoltSensorsEntry 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsIndex ::= { lmVoltSensorsEntry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheEntry ::= { nsCacheTable 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenTable ::= { nsConfigDebug 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugDumpPdu ::= { nsConfigDebug 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugOutputAll ::= { nsConfigDebug 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugEnabled ::= { nsConfigDebug 1 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPassphrase ::= { ucdDemoPublic 4 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoUserList ::= { ucdDemoPublic 3 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPublicString ::= { ucdDemoPublic 2 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoResetKeys ::= { ucdDemoPublic 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatName ::= { netSnmpExampleNotificationObjects 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatRate ::= { netSnmpExampleNotificationObjects 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassExamples ::= { netSnmpExamples 255 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotifications ::= { netSnmpExamples 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleTables ::= { netSnmpExamples 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleScalars ::= { netSnmpExamples 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAccessTable ::= { netSnmpVacmMIB 1 }
Cannot adopt OID in UCD-SNMP-MIB: ucdShutdown ::= { ucdTraps 2 }
Cannot adopt OID in UCD-SNMP-MIB: ucdStart ::= { ucdTraps 1 }
Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsTable ::= { lmSensors 5 }
Cannot adopt OID in LM-SENSORS-MIB: lmVoltSensorsTable ::= { lmSensors 4 }
Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsTable ::= { lmSensors 3 }
Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsTable ::= { lmSensors 2 }
Cannot adopt OID in LM-SENSORS-MIB: lmSensorsMIB ::= { lmSensors 1 }
Cannot adopt OID in UCD-SNMP-MIB: mrEntry ::= { mrTable 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigEntry ::= { nsExtendConfigTable 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostRowStatus ::= { netSnmpHostsEntry 5 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostStorage ::= { netSnmpHostsEntry 4 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostAddress ::= { netSnmpHostsEntry 3 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostAddressType ::= { netSnmpHostsEntry 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostName ::= { netSnmpHostsEntry 1 }
Cannot adopt OID in UCD-SNMP-MIB: prEntry ::= { prTable 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotification ::= { netSnmpExampleNotifications 1 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotificationObjects ::= { netSnmpExampleNotifications 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleNotificationPrefix ::= { netSnmpExampleNotifications 0 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpHostsTable ::= { netSnmpExampleTables 2 }
Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpIETFWGTable ::= { netSnmpExampleTables 1 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassOID ::= { netSnmpPassEntry 3 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassInteger ::= { netSnmpPassEntry 2 }
Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassIndex ::= { netSnmpPassEntry 1 }
Cannot adopt OID in NET-SNMP-VACM-MIB: netSnmpVacmMIB ::= { netSnmpObjects 9 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsVersion ::= { netSnmpObjects 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsMibRegistry ::= { netSnmpObjects 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsExtensions ::= { netSnmpObjects 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDLMod ::= { netSnmpObjects 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCache ::= { netSnmpObjects 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsErrorHistory ::= { netSnmpObjects 6 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsConfiguration ::= { netSnmpObjects 7 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactions ::= { netSnmpObjects 8 }
Cannot adopt OID in UCD-DEMO-MIB: ucdDemoMIB ::= { ucdavis 14 }
Cannot adopt OID in UCD-SNMP-MIB: logMatch ::= { ucdavis 16 }
Cannot adopt OID in UCD-SNMP-MIB: fileTable ::= { ucdavis 15 }
Cannot adopt OID in UCD-SNMP-MIB: ucdTraps ::= { ucdavis 251 }
Cannot adopt OID in UCD-SNMP-MIB: systemStats ::= { ucdavis 11 }
Cannot adopt OID in UCD-SNMP-MIB: mrTable ::= { ucdavis 102 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrs ::= { ucdavis 101 }
Cannot adopt OID in UCD-SNMP-MIB: version ::= { ucdavis 100 }
Cannot adopt OID in UCD-SNMP-MIB: laTable ::= { ucdavis 10 }
Cannot adopt OID in UCD-SNMP-MIB: dskTable ::= { ucdavis 9 }
Cannot adopt OID in UCD-SNMP-MIB: memory ::= { ucdavis 4 }
Cannot adopt OID in UCD-SNMP-MIB: extTable ::= { ucdavis 8 }
Cannot adopt OID in UCD-SNMP-MIB: prTable ::= { ucdavis 2 }
Cannot adopt OID in UCD-SNMP-MIB: ucdSnmpAgent ::= { ucdavis 250 }
Cannot adopt OID in UCD-SNMP-MIB: ucdExperimental ::= { ucdavis 13 }
Cannot adopt OID in UCD-SNMP-MIB: ucdInternal ::= { ucdavis 12 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleEntry ::= { nsModuleTable 1 }
Cannot adopt OID in UCD-SNMP-MIB: dskErrorMsg ::= { dskEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: dskErrorFlag ::= { dskEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsedHigh ::= { dskEntry 16 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsedLow ::= { dskEntry 15 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvailHigh ::= { dskEntry 14 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvailLow ::= { dskEntry 13 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotalHigh ::= { dskEntry 12 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotalLow ::= { dskEntry 11 }
Cannot adopt OID in UCD-SNMP-MIB: dskPercentNode ::= { dskEntry 10 }
Cannot adopt OID in UCD-SNMP-MIB: dskPercent ::= { dskEntry 9 }
Cannot adopt OID in UCD-SNMP-MIB: dskUsed ::= { dskEntry 8 }
Cannot adopt OID in UCD-SNMP-MIB: dskAvail ::= { dskEntry 7 }
Cannot adopt OID in UCD-SNMP-MIB: dskTotal ::= { dskEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: dskMinPercent ::= { dskEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: dskMinimum ::= { dskEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: dskDevice ::= { dskEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: dskPath ::= { dskEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: dskIndex ::= { dskEntry 1 }
Cannot adopt OID in UCD-DISKIO-MIB: diskIOTable ::= { ucdDiskIOMIB 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingGroup ::= { nsConfigGroups 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugGroup ::= { nsConfigGroups 1 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrErrMessage ::= { snmperrs 101 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrErrorFlag ::= { snmperrs 100 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrNames ::= { snmperrs 2 }
Cannot adopt OID in UCD-SNMP-MIB: snmperrIndex ::= { snmperrs 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionTable ::= { nsTransactions 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogStatus ::= { nsLoggingEntry 5 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogMaxLevel ::= { nsLoggingEntry 4 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogType ::= { nsLoggingEntry 3 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogToken ::= { nsLoggingEntry 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogLevel ::= { nsLoggingEntry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendResult ::= { nsExtendOutput1Entry 4 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutNumLines ::= { nsExtendOutput1Entry 3 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputFull ::= { nsExtendOutput1Entry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Line ::= { nsExtendOutput1Entry 1 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutLine ::= { nsExtendOutput2Entry 2 }
Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendLineIndex ::= { nsExtendOutput2Entry 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
Cannot adopt OID in UCD-SNMP-MIB: laErrMessage ::= { laEntry 101 }
Cannot adopt OID in UCD-SNMP-MIB: laErrorFlag ::= { laEntry 100 }
Cannot adopt OID in UCD-SNMP-MIB: laLoadFloat ::= { laEntry 6 }
Cannot adopt OID in UCD-SNMP-MIB: laLoadInt ::= { laEntry 5 }
Cannot adopt OID in UCD-SNMP-MIB: laConfig ::= { laEntry 4 }
Cannot adopt OID in UCD-SNMP-MIB: laLoad ::= { laEntry 3 }
Cannot adopt OID in UCD-SNMP-MIB: laNames ::= { laEntry 2 }
Cannot adopt OID in UCD-SNMP-MIB: laIndex ::= { laEntry 1 }
Communication status: Good
| PERMISSION |
| SUMMARY |
Missing Required Dependencies
error: 'libtool' package is missing/incompatible
error: 'libtool-bin' package is missing/incompatible
error: 'make' package is missing/incompatible
error: 'libcupsimage2' package is missing/incompatible
error: 'libcupsimage2-dev' package is missing/incompatible
error: 'libjpeg62-turbo-dev' package is missing/incompatible
error: 'libusb-1.0.0-dev' package is missing/incompatible
error: 'libsane-dev' package is missing/incompatible
error: 'libssl-dev' package is missing/incompatible
error: 'python3-pyqt4' package is missing/incompatible
error: 'gtk2-engines-pixbuf' package is missing/incompatible
error: 'libcups2-dev' package is missing/incompatible
error: 'cups-bsd' package is missing/incompatible
error: 'cups-client' package is missing/incompatible
error: 'libsnmp-dev' package is missing/incompatible
error: 'snmp' package is missing/incompatible
error: 'libdbus-1-dev' package is missing/incompatible
error: 'cups' package is missing or 'cups' service is not running.
error: 'libcups2' package is missing/incompatible
Missing Optional Dependencies
error: 'python3-dbus.mainloop.qt' package is missing/incompatible
Total Errors: 13
Total Warnings: 0
