pumpkinpi
Solved but don't know why: RPi Display Goes Black at Boot
Fri Jul 19, 2019 3:19 am
I have an RPi 3B and have had it powering an RPi display for a few years. I recently reimaged my card using dd from another Pi+display combo that was working perfectly and tried to boot the system with both the source and the reimaged card. The display turns on when I boot the pi, shows the for red raspberries and then promptly goes black before showing me any text during boot. The pi boots perfectly fine because I can SSH into it and it seems to be fully functional, but the display stays off.
I know for sure it is not a power issue. I have used this power supply for a long time successfully and tried swapping to a new higher current one and also tried powering the display and pi separately. All with the same result.
I tried the reimage with a couple different cards. Same behaviour.
System is running Raspbian Stretch and is up to date.
Any tips on what I can investigate?
Thanks!
PPi
pumpkinpi
Re: RPi Display Goes Black at Boot
Sat Jul 20, 2019 12:00 pm
So, last night I hit on the rather obvious idea of just writing a new card and seeing if the screen comes on and works. It does. So, it is not a hardware issue. I will mark this on as "solved but don't know why".
dwmreg
Re: Solved but don't know why: RPi Display Goes Black at Boot
Sun Jul 21, 2019 3:25 am
I"m seeing this on my pi3b+ and 4b. Did you use a fresh recent version of the Raspberry PI OS downloadable from this site?
I think it has a major video bug of some kind. Some quirk.
HawaiianPi
Sun Jul 21, 2019 3:29 am
I recently reimaged my card using dd from another Pi+display combo that was working ...
Next time try the SD Card Copier utility that's included with Desktop version of Raspbian.
pumpkinpi
Sun Jul 21, 2019 10:27 am
Oh, that is a really good idea. Thanks!
